POV-Ray : Newsgroups : povray.general : Partial Output Options Server Time
31 Jul 2025 01:45:36 EDT (-0400)
  Partial Output Options (Message 1 to 7 of 7)
Subject: Partial Output Options
Date: 21 Jan 2003 11:10:06
Message: <web.3e2d7027f1c1584e31ece9d0@news.povray.org>
I can't open images built by povray when I use The Partial Output Options (
-StartColumn or the others).
I use png format and try to see images with electric eye (Cannot load image)
or with the Gimp (a part of image is loaded but there is a warning that the
image is corrupted).
Is it possible to convert images to normal files ?
Thanks
Subject: Re: Partial Output Options
Date: 21 Jan 2003 11:25:07
Message: <web.3e2d737a509d521631ece9d0@news.povray.org>
INVALID_ADDRESS wrote:
My Address is valid, I think there is a bug
I'm using the web interface.
MSc in ASc
University of Manchester
mor### [at] csmanacuk
Date: 21 Jan 2003 12:01:19
Message: <3e2d7cdf$1@news.povray.org>
POV-Ray uses the PNG reference implementation (libpng) to create its PNG
files.  If some programs cannot read image files generated by the PNG
reference implementation, I would recommend to report it to the authors of
those programs as bug.
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Jan 2003 12:19:09
Message: <3E2D810D.EEBF760B@gmx.de>
To be fair it should be noted that POV-Ray cannot read png files from a
partial/interrupted render as image maps/heightfields/... either.  The
libpng function to load whole images ('png_read_image()') has problems
with them.  Reading the image line by line ('png_read_row()') helps (this
is what i did for HCR-Edit and what POV does in 'Read_Rendered_Part()' for
continuing interrupted renders).
Maybe i should post a bug report concerning this? ;-)
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 21 Jan 2003 13:06:49
Message: <3e2d8c39@news.povray.org>
In article <3E2D810D.EEBF760B@gmx.de> , Christoph Hormann
Yes.
    Thorsten
Date: 21 Jan 2003 13:10:08
Message: <web.3e2d8bee509d521631ece9d0@news.povray.org>
Yep,
But only povray uses partial images, So it's normal that other software
can't read such files.
Povray should build the whole image (complete the partial image with
transparent or black pixel)
Khi2
Date: 21 Jan 2003 13:38:41
Message: <3e2d93b1@news.povray.org>
In article <web.3e2d8bee509d521631ece9d0@news.povray.org> , "Khi2"
No, they are completely valid PNG files.
That is not possible.  It would require to generate PNG image as a whole in
the end.  If you interrupt a render it could no longer be continued this
way.
    Thorsten
