POV-Ray : Newsgroups : povray.general : # of objects in a model Server Time
12 Sep 2025 13:52:17 EDT (-0400)
  # of objects in a model (Message 1 to 8 of 8)
Subject: # of objects in a model
Date: 16 Jan 2003 17:05:04
Message: <web.3e272b5a2c0a881a0c272b50@news.povray.org>
I've been building a pretty complex model using numerous #while loops and
macros. Is there a way to tell how many parts are in the final model?
POV tells me there are 1047 frame level objects, but what does that mean?
(It was over 1100 before I added a macro that I estimate added another
200-300 pieces.)
My guesstimate so far is about 3700 parts, but I'd really like to have a
precise number.
Thanks.
RG - remember, its not whether you win or lose, its how many endorsement
contracts you signed before the season ended
Subject: Re: # of objects in a model
Date: 16 Jan 2003 17:09:09
Message: <3e272d85@news.povray.org>
Put just the model in a scene by itself, without any other objects (like
ground planes or whatever). The "number of frame level objects" should then
be an accurate count of the number of objects in the model.
 - Slime
[ http://www.slimeland.com/ ]
Date: 16 Jan 2003 19:16:31
Message: <3e274b5f$1@news.povray.org>
"Slime" <slm### [at] slimelandcom> wrote in message
news:3e272d85@news.povray.org...
then
Well, it wouldn't. At least, not always.
Roughly speaking, "number of frame-level objects" is the number of
primitives plus the number of intersections and other compound objects
*except* unions. POV-Ray's parser splits unions (including nested unions, to
any depth) until it "hits" a primitive, or a non-union compound object. It
is the result of this process that defines that number... And the reason
behind this is very strong: building an efficient bounding slabs' tree.
As an illustration, try making the following scene: turn your complex model
into, say, a stone one by making an intersection of your model and large
enough sphere; assign stone texture to that intersection; add a point light.
Render the scene and see how many "frame level objects" you've got. Voila --
just one. If you make a complex enough model with intersection being at its
root, and then try to render it (so that this model occupies entire camera
view), chances are it will render for ages. The rendering performance
distinction between unions and other compounds is so big that that might as
well be in the VFAQ and/or manual...
So, if I understood your question correctly, you are not supposed to get an
easy unswer. If your model, say, contains a golf ball made as an
intersection of a sphere with N smaller ones (e.g. created using #while),
your ball will always count as a single frame-level object.
Date: 16 Jan 2003 20:03:46
Message: <3e275672$1@news.povray.org>
I had heard this before. I was wondering, how does it handle, say:
intersection {
sphere{...}
union {
sphere{...}
sphere{...}
without retaining the union? (assume all three spheres intersect.)
 - Slime
Date: 16 Jan 2003 20:16:09
Message: <3e275959$1@news.povray.org>
> intersection {
> sphere{...}
> union {
> sphere{...}
> sphere{...}
As I wrote, "parser splits ... until it hits ... non-union compound object".
That is, since the union you draw as an example is *within* intersection
(which is one of the "non-union compound objects" I was referring to), it
will be retained.
Date: 16 Jan 2003 20:41:37
Message: <3e275f51$1@news.povray.org>
object".
> will be retained.
Ooh, OK. So not all unions are split. Makes more sense.
 - Slime
Date: 17 Jan 2003 01:06:17
Message: <pan.2003.01.17.06.05.01.719347.302@gte.net>
On Thu, 16 Jan 2003 16:59:55 -0500, gonzo quoth:
> and macros. Is there a way to tell how many parts are in the final
> model?
> mean? (It was over 1100 before I added a macro that I estimate added
> another 200-300 pieces.)
> precise number.
In order to do this, you'll need to replace all "difference",
"intersection", and "merge" keywords with "union", then render.  The
resulting model won't look anything like your original model, but the
"frame level objects" count will be the number of parts in the model.
A "frame level" object is any object that is in the "top level" of the
scene; that is, not part of a difference, merge, or intersection, and that
is not a bounding or clipping object.
Mark
Date: 17 Jan 2003 03:00:06
Message: <web.3e27b6e267d12d4d3f329d050@news.povray.org>
That's about what I was figuring from reading the above. I could tell it had
something to do with the CSG operations but wasn't sure which ones...
Ok, that's clearer. That explains why I could add a macro and the number
went down.
Thanks much everybody!
I had tried modeling things like this in other programs, but it got too
complex in a hurry. Thanks to POV it's now possible! WHEEEEEE!!!!
RG - just because I'm paranoid doesn't mean everyone's not out to get me
