POV-Ray : Newsgroups : povray.general : 3d splines with uniform intervals ??? Server Time
31 Jul 2025 19:50:55 EDT (-0400)
  3d splines with uniform intervals ??? (Message 1 to 10 of 21)
Subject: 3d splines with uniform intervals ???
Date: 12 Jan 2003 11:25:06
Message: <web.3e21957b8d140aa98a0521b50@news.povray.org>
Does anyone know how I can make a 3d spline in POV 3.5 that allows the
spline parameter (ie. distance along spline) to be completely evenly spaced
along the length of the spline. This was standard using the MegaPov
splines, which defined the total spline length as between 0 and 1.
It seems to me that assigning individual t-values to pts on the spline will
invariably prevent smooth motion along a spline (as in the POV example file
splinefollow.pov).
Thanks in advance.
Mike E.
Subject: Re: 3d splines with uniform intervals ???
Date: 12 Jan 2003 11:39:46
Message: <3e219a52@news.povray.org>
Try the spline include file by Chris Colefax. It has a sampling method
which allows placing points at even distances along a spline.
Date: 12 Jan 2003 13:18:28
Message: <cjameshuff-4E03CC.13075812012003@netplex.aussie.org>
In article <web.3e21957b8d140aa98a0521b50@news.povray.org>,
No it wasn't. As far as I can recall, it wasn't even the case with the
other spline patch, the buggy one with the ugly syntax that didn't get
into 3.5. You are probably thinking of Chris Colefax's spline include.
It would be possible to make a macro that builds a new spline with
constant "speed" from an existing spline or from an array of points,
though. I have done experiments with this in the past. Or it could be
patched directly into the spline feature for convenience and speed, but
it isn't necessary.
http://tag.povray.org/
Date: 12 Jan 2003 16:48:14
Message: <3e21e29e@news.povray.org>
I found a file called "spline evenly spaced objects.pov" in my povray
directory, I think I picked it up from the newsgroups a while ago, can't
remember who made it though..
This places evenly spaced objects along a spline, but perhaps you can use it
to get an idea on how to achive what you need?
If you know, or are, the person that wrote this, please shout out loud to
give some proper credit here!
-Peter
#include "transforms.inc"
#include "shapes.inc"
#include "strings.inc"
#macro Time_To_Length_Converter(Spline,Min,Max,Accuracy)
  #local Conversion=function{spline{
    #local Last=Spline(Min);
    #local Length=0;
    #local C=Min;
    #while (C<=Max)
      #local C=min(C,Max);
      #local Point=Spline(C);
      #local Length=Length+vlength(Point-Last);
      #local Last=Point;
      C , <1,0,0>*Length
      #local C=C+Accuracy;
  function(T){Conversion(T).x}
#macro Spline_With_Linear_Movement(Spline,Min,Max,Accuracy)
  spline{
    #local Length=0;
    #local C=Min;
    #while (C<=Max)
      #local Last=Point;
      Length , Point+<0,0,0>
#declare MySpline = spline {
   cubic_spline
   -1,<-1,1,0>,
   0,<0,1,0>,
   0.3, <2,0.7,-2>,
   0.6,<3,-0.8,-3>,
   0.85,<0,-0.8,-3.5>,
   1,<-1,-0.8,-3.72>,
   1.1,<-2,-0.8,-3.75>
#declare MySplineLinear = Spline_With_Linear_Movement(MySpline,0,1,0.001);
#declare f_MySplineLength = Time_To_Length_Converter(MySpline,0,1,0.001);
#declare MySplineLength = f_MySplineLength(1);
#declare MyObject = cone {0 .2 <0,0,.2> 0.15 pigment{rgb 1}};
#declare Step=MySplineLength/20;
#declare All=union{
  #declare Count=0;
  #while (Count<=MySplineLength-Step)
    object {
      MyObject
      pigment { rgb <1,.3,.7>}
      Spline_Trans(MySplineLinear, Count, y, 0.1, 0.1)
    #declare Count=Count+Step;
  rotate x*90
object{Center_Object(All,1)translate z*5}
background{1}
light_source{<0,10,-125> 1}
object {
Center_Object(
union{
#local Q = 0;
#while (Q < 1)
sphere {MySpline(Q),0.1 pigment {rgb <1,1,0>} rotate x*90}
#local Q = Q+0.02;
,1)
translate z*5
Date: 12 Jan 2003 23:15:04
Message: <web.3e223c736e508e7a130c700f0@news.povray.org>
Christopher James Huff wrote:
>In article <web.3e21957b8d140aa98a0521b50[at]news.povray.org>,
>it isn't necessary.
I'm interested in your statement, "it isn't necessary". Is there something
simple that I am missing? How would you move something along a spline at a
constant speed? A real world example for instance - in the Pov3.5 example
file "splinefollow.pov", how could I make the planes move around that spline
at a constant speed?
Thanks for your quick response
Mike E.
Date: 13 Jan 2003 20:43:15
Message: <cjameshuff-99BF94.20430313012003@netplex.aussie.org>
In article <web.3e223c736e508e7a130c700f0@news.povray.org>,
I mean it doesn't require anything that isn't possible in POV.
Make a macro that creates a new spline that follows the original spline,
but has time values calculated to keep the speed constant. Split the
original into separate intervals, figure out the length of an interval
and the entire spline...it really isn't difficult if you are familiar
with coding. I'll dig out my old experiments, if I have time.
Date: 13 Jan 2003 21:18:01
Message: <3E237326.21C46595@pacbell.net>
There are a lot of things -possible- in POV-Ray IF, you have an IQ over 200,
you know math at the quantum physics level and you can program like God, but
there are some things that it would be nice if POV-Ray could just do for you
without having to do all the mental gymnastics. What you might call program
bloat I call ease of use.
Ken Tyler
Date: 13 Jan 2003 21:52:09
Message: <cjameshuff-84D63F.21520613012003@netplex.aussie.org>
In article <3E237326.21C46595@pacbell.net>, Ken <tyl### [at] pacbellnet>
It doesn't require quantum physics math or God-like programming skills,
and I didn't call it code bloat. It would be nice if it was built-in,
just for the increased speed, efficiency, and precision, but it is not
impossible or even extremely difficult for someone with some coding
experience.
Date: 13 Jan 2003 22:00:00
Message: <3E237CFF.A2913741@pacbell.net>
> experience.
Is it too late for me to add a smiley to my last post?
Ken Tyler
Date: 13 Jan 2003 22:40:26
Message: <cjameshuff-2F3646.22402213012003@netplex.aussie.org>
In article <3E237CFF.A2913741@pacbell.net>, Ken <tyl### [at] pacbellnet>
Yes.
