POV-Ray : Newsgroups : povray.general : Problems with the sum() and prod(). (Bug in v3.5 ?) Server Time
23 Aug 2025 01:04:15 EDT (-0400)
  Problems with the sum() and prod(). (Bug in v3.5 ?) (Message 1 to 10 of 20)
Subject: Problems with the sum() and prod(). (Bug in v3.5 ?)
Date: 9 Jan 2003 21:10:03
Message: <web.3e1e2ad581e209a5b417814a0@news.povray.org>
If I have understood the documentation
for the new sum() and prod() functions
right, then POV-Ray v3.5 for Windows
behaves very oddly in some cases.
I have observed two different beahiours:
1)
When I run some code with these
functions, POV-Ray just "hangs" and
does not finish parsing, even if the
calculations are very short. In this
state it does not react when I press
the Stop button.
When I try to close it down, then it
says "POV-Ray is currently rendering -
do you want to stop ?".
If I answer Yes, then POV-Ray closes
down as it should. If I answer No,
then POV-Ray just continues to "hang".
The Pause button is working OK.
2)
When I run some other code with these
functions, POV-Ray finishes but
produces wrong results.
Can anyone confirm this behaviour ?
I have inserted my test code below.
The relevant documentation is here:
http://www.povray.org/documentation/view/140/
(Section 6.1.6.1)
My PC runs Win98SE and has a 166MHz MMX
Pentium processor with 96MB of RAM.
Tor Olav
#version 3.5;
// Test of sum() function
// Hangs. Should have given 1.233701
 #declare Fn = function(x) { sum(i, 1, 2, atan2(1, 1)*atan2(1, 1)) }
// Hangs. Should have given 0
// #declare Fn = function(x) { sum(i, 1, 2, pow(x, i) + pow(x, i)) }
// #declare Fn = function(x) { sum(i, 1, 2, pow(x, 2)*pow(x, 2)) }
// Hangs. Should have given 4
// #declare Fn = function(x) { sum(i, 1, 2, pow(1, 2) + pow(1, 2)) }
// Finishes, but with wrong result: 66 instead of 17
// #declare Fn = function(x) { sum(i, 1, 2, pow(i, 2)*pow(i, 2)) }
// Finishes, but with wrong result: 2.826822 instead of 1.534895
// #declare Fn = function(x) { sum(i, 1, 2, sin(i)*sin(i)) }
// Finishes, but with wrong result: 2 instead of 0
// #declare Fn = function(x) { sum(i, 1, 2, sin(x)*sin(x)) }
// Test of prod() function
// Hangs. Should have given 0.380504
// #declare Fn = function(x) { prod(i, 1, 2, atan2(1, 1)*atan2(1, 1)) }
// #declare Fn = function(x) { prod(i, 1, 2, pow(x, i) + pow(x, i)) }
// #declare Fn = function(x) { prod(i, 1, 2, pow(x, 2)*pow(x, 2)) }
// #declare Fn = function(x) { prod(i, 1, 2, pow(1, 2) + pow(1, 2)) }
// Finishes, but with wrong result: 128 instead of 16
// #declare Fn = function(x) { prod(i, 1, 2, pow(i, 2)*pow(i, 2)) }
// Finishes, but with wrong result: 1.653644 instead of 0.585451
// #declare Fn = function(x) { prod(i, 1, 2, sin(i)*sin(i)) }
// Finishes with correct result: 0, but gives wrong result for Fn(1)
// #declare Fn = function(x) { prod(i, 1, 2, sin(x)*sin(x)) }
// #declare SumFn = function(A, B) { A + B } // Uncomment for tests below
// Hangs. Should have given 18
// #declare Fn = function(x) { sum(i, 1, 2, SumFn(i, 1)*SumFn(i, 2)) }
// Finishes, but with wrong result: 3 instead of 4
// #declare Fn = function(x) { sum(i, 1, 2, SumFn(x, 1)*SumFn(x, 2)) }
// Finishes, but with wrong result: 4 instead of 7
// #declare Fn = function(x) { sum(i, 1, 2, SumFn(x, 1)*SumFn(i, 2)) }
// Hangs. Should have given 72
// #declare Fn = function(x) { prod(i, 1, 2, SumFn(i, 1)*SumFn(i, 2)) }
// Finishes, but with wrong result: 2 instead of 4
// #declare Fn = function(x) { prod(i, 1, 2, SumFn(x, 1)*SumFn(x, 2)) }
// Finishes, but with wrong result: 3 instead of 12
// #declare Fn = function(x) { prod(i, 1, 2, SumFn(x, 1)*SumFn(i, 2)) }
#debug "\n"
#debug str(Fn(0), 0, -1)
#debug "\n\n"
Subject: Re: Problems with the sum() and prod(). (Bug in v3.5 ?)
Date: 10 Jan 2003 10:33:22
Message: <3e1ee7c2$1@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:web.3e1e2ad581e209a5b417814a0@news.povray.org...
> 1)
> the Stop button.
> 2)
> (Section 6.1.6.1)
> Tor Olav
Hello Tor Olav,
I get identical results and have a 450MHz MMX
PIII with 1 GB RAM.
I've tried some different things and I think if a function gives
0 as answer, the sum_function uses 1 instead, for:
#declare Fn = function(x) { sum(i, 1, 2, pow(x, 2)) }
with x =0:        2 instead of 0,
 and sum(i,1,8,pow(x,2))     gives 8 as answer.
There may be wrong more things, but this is what I
discovered so far.
Jaap Frank
Date: 10 Jan 2003 10:36:56
Message: <3e1ee898@news.povray.org>
Forgot to tell: I use Windows ME..
Date: 10 Jan 2003 13:36:16
Message: <Xns92FFC7EA67D58torolavk@204.213.191.226>
"Jaap Frank" <jjf### [at] xs4allnl> wrote in news:3e1ee7c2$1@news.povray.org:
>> 1)
>> the Stop button.
>> 2)
>> (Section 6.1.6.1)
>> Tor Olav
> Hello Tor Olav,
> PIII with 1 GB RAM.
> discovered so far.
Thank you for verifying this Jaap.
I'm not sure if this is the same
bug as the one described here:
http://news.povray.org/povray.bugreports/26015/
Can anyone tell if it is ?
And have some with a Mac or a
Linux PC tried the examples that
I posted ?
Tor Olav
Date: 10 Jan 2003 13:59:33
Message: <3E1F1814.B8F7D711@gmx.de>
> I posted ?
Tested on Linux and found the same problems.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Jan 2003 14:03:33
Message: <3e1f1905@news.povray.org>
In article <Xns### [at] 204213191226> , Tor Olav Kristensen
No it has absolutely nothing to do with it.
Anyway, I recall discussing this particular problem somewhere with someone
before.  Don't bother about trying to find a pattern in what happens, from a
user perspective you don't stand a chance.  Just don't use those tow
functions for now.
    Thorsten
e-mail: tho### [at] trfde
Date: 10 Jan 2003 16:45:12
Message: <web.3e1f3e34b49a0ea9b417814a0@news.povray.org>
>functions for now.
OK.
I was hoping that these functions could
come in handy in some parametric surface
macros I'm experimenting with.
Do you want me to post a bug report to
povray.bugreports ?
Tor Olav
Date: 10 Jan 2003 17:03:37
Message: <3e1f4339$1@news.povray.org>
In article <web.3e1f3e34b49a0ea9b417814a0@news.povray.org> , "Tor Olav
> povray.bugreports ?
Nope, because that would let people find out about those functions in the
first place. No need to worry anybody ;-)  You seem to be only the second
person to even try them in almost half a year!
    Thorsten
Date: 10 Jan 2003 17:14:04
Message: <3e1f45ac@news.povray.org>
  Ignorance is bliss. :P
Date: 10 Jan 2003 17:55:15
Message: <3e1f4f52@news.povray.org>
>> povray.bugreports ?
Hmm... I'm using prod() to calculate the factorial, as indicated in the
docs. Should I be worried or does it work fine with that simple example?
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
