POV-Ray : Newsgroups : povray.general : Fractals with functions Server Time
13 Sep 2025 00:42:54 EDT (-0400)
  Fractals with functions (Message 1 to 10 of 14)
Subject: Fractals with functions
Date: 1 Oct 2002 03:20:03
Message: <web.3d994bde346c153a084dc010@news.povray.org>
btw. This is my first time posting here. =)
Is there a way to create a fractal(mandelprot) pattern with the function
pattern or a 4D-julia with the isosurface?
I'd like to desing my own fractals with POV-ray, but because #declare c = x;
isn't the pattern x-variable(The c ends up as a vector <1,0,0>) I don't
know how. =(
Subject: Re: Fractals with functions
Date: 1 Oct 2002 11:18:01
Message: <3d99bca9@news.povray.org>
  You can create the mandelbrot and julia sets using the patterns with
the same names.
  However, you can't create recursive fractal functions (because functions
don't allow recursion).
  I can say that recursion support was tested before the final 3.5 was
released, and I even successfully made a mandelbrot function with it, but
due to several problems which arose, it was decided to not to include
support for that.
  By the way, the mandelbrot function looked like this:
#declare MaxIter = 30;
#declare MandIter =
  function(Re, Im, Zr, Zi, n)
    select(n<MaxIter & Zr*Zr+Zi*Zi<4, 0, n,
      MandIter(Re, Im, Zr*Zr-Zi*Zi+Re, 2*Zr*Zi+Im, n+1))
#declare Mandel = function { MandIter(x, y, x, y, 0)/MaxIter }
  Usage example:
box
{ <-2,-1.5,0>, <1,1.5,.1>
  pigment
  { function { Mandel(x,y,z) }
    color_map { [0 rgb z*.5][1 rgb <.5,.75,1>][1 rgb 0] }
  finish { ambient 1 }
  Naturally it was slower than using the internal mandlebrot pattern,
but in no way unacceptably slow.
  It's a real pitty that it was dropped... :(
Date: 1 Oct 2002 11:45:35
Message: <3d99c31f$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3d99bca9@news.povray.org...
> the same names.
Just out of curiosity, would it not be possible to hard-code the recursion in
some way? It would lead to an 'orribly long function, but can it be done?
I've no idea how to do such a thing for a fractal*, but e.g.:
#declare Rec_func = function(x,y,z){
  pow(pow(pow(x,0.5),0.5),0.5) *
  pow(pow(pow(y,0.5),0.5),0.5)
*although I'm tempted to try tonight
Date: 1 Oct 2002 12:21:44
Message: <Xns929ABA8048BC1PhiLho@204.213.191.226>
"Tom Melly" <tom### [at] tomandlucouk> wrote in news:3d99c31f$1@news.povray.org:
> recursion in some way? It would lead to an 'orribly long function, but
> can it be done?
pow pow pow... Good rythm...
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 1 Oct 2002 12:44:54
Message: <3d99d105@news.povray.org>
> some way?
  The number of recursions done depends on the given coordinates and thus
is not fixed.
Date: 1 Oct 2002 12:51:57
Message: <3d99d2ad@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3d99d105@news.povray.org...
in
> > some way?
> is not fixed.
Would it matter? I mean, normally you break out of the recursion if the value
goes above a certain level, so it would be an inefficient "loop", but wouldn't
the result be the same?
I only know about mandelbrot - have I missed an issue with other fractal-types?
(or just not understood the problem ;)
Date: 1 Oct 2002 13:29:48
Message: <3d99db8c@news.povray.org>
  The return value of the loop is how many times the recursive call was
done.
  See the problem?-)
Date: 1 Oct 2002 14:44:35
Message: <3d99ed13@news.povray.org>
news:3d99db8c@news.povray.org...
> done.
>   See the problem?-)
Ah - I *think* that you're thinking of a different approach (which maybe
because my approach is unworkable - and it would certainly start to look
very messy after more than a couple of dozen recursions). No, I was thinking
of having each required recursion already coded - i.e. if you wanted 20
recursions the function-code would be approx. 2 times longer than for 10
recursions.
Anyway, I'll have a play tonight. I can't think of any concievable use for
such an approach as mine except for killing cats...
Date: 1 Oct 2002 15:24:59
Message: <chrishuff-15AD2F.15221801102002@netplex.aussie.org>
In article <3d99d105@news.povray.org>, Warp <war### [at] tagpovrayorg>
> is not fixed.
I think you could do it using the select() feature to just stop
computation past a certain point...it would still "recurse", but the
additional levels wouldn't have to do anything. It would be horribly
complex, slow, and ugly, and would be limited to a low number of
recursions, but I think it is "possible".
http://tag.povray.org/
Date: 1 Oct 2002 15:44:41
Message: <3d99fb29@news.povray.org>
> is not fixed.
Its slow but it can be done:
camera{
 location -z
 look_at 0
#declare MaxIter = 5;
#macro _Zr(n,I)
 #if(n<I)
  (_Zr(n+1,I)*_Zr(n+1,I)-_Zi(n+1,I)*_Zi(n+1,I)+Re)
 #else
  (Zr*Zr-Zi*Zi+Re)
#macro _Zi(n,I)
 #if(n<I)
  (2*_Zr(n+1,I)*_Zi(n+1,I)+Im)
 #else
  (2*Zr*Zi+Im)
#macro MakeFun(n)
 select(n<MaxIter & _Zr(0,n)*_Zr(0,n)+_Zi(0,n)*_Zi(0,n)<4, 0, n,
  #if(n<MaxIter)
   MakeFun(n+1)
  #else
   0
#declare MandIter=
function(Re, Im, Zr, Zi, n){
 MakeFun(0)
plane{z,0
 pigment{ function { Mandel(x,y,z) }
    scale 0.3
