POV-Ray : Newsgroups : povray.general : Parametric bug? Server Time
24 Aug 2025 09:55:25 EDT (-0400)
  Parametric bug? (Message 1 to 5 of 5)
Subject: Parametric bug?
Date: 20 Aug 2002 19:00:29
Message: <web.3d62c961c0336eb58b0b6f760@news.povray.org>
This scene renders differently depending on whether the parametric is bound
by a sphere or a box. It should render the same in both instances unless
I'm overlooking something.
camera{
  perspective
  location     <1.6,1.6,-3.2>
  look_at      <0,0,0>
light_source{
  <5,10,-5>
  color             rgb<1,1,1>
parametric{
  function{u*sin(2*pi*v)}
  function{v}
  function{u*cos(2*pi*v)}
  <0,0>
  <1,1>
  contained_by{box{<-1,-1,-1><1,1,1>}}
  //contained_by{sphere{<0,0,0>,1}}
  accuracy          0.001
  max_gradient      1.1
  precompute        20,x,y,z
  pigment{color rgb<1,0,0>}
Subject: Re: Parametric bug?
Date: 20 Aug 2002 21:16:46
Message: <o8$BCCAYkuY9Ewrp@econym.demon.co.uk>
Have you noticed that the shape is the same, it's just the brightness
that's different? If you add "finish {ambient 1}" (and make the sphere
slightly bigger so that it doesn't clip the shape) then the output is
identical.
Mike Williams
Gentleman of Leisure
Date: 20 Aug 2002 22:15:05
Message: <web.3d62f6bcf8c6d3fa8b0b6f760@news.povray.org>
>identical.
Of course I can correct the brightness, but that wasn't the point.
The difference in brightness was what I referring to, not the actual shape.
I can see no reason for it to be darker in the first place, therefore it
appears to be a bug.
Date: 20 Aug 2002 22:15:06
Message: <web.3d62f776f8c6d3fa8b0b6f760@news.povray.org>
Additionally, the sphere clipping the shape is not a factor. Leave off your
finish{ambient 1} and increase the sphere's radius...no effect.
Date: 26 Aug 2002 02:49:24
Message: <pdjjmusk56m6o33p4kqm6i94vc3pvd2b7e@4ax.com>
I have not checked you rsource but I have noticed similiar thing when played
with http://abx.art.pl/pov/patches/uvparam.php. Try script listed there as is
and later with:
  contained_by{sphere{0 vlength(Corner)}}
Second version shows black object. Any confirmation ? I have added this bug to
my own "patches to do" list but if there is anybody with time to investigate
it...
ABX
