POV-Ray : Newsgroups : povray.general : Neon Signs Server Time
12 Aug 2025 11:01:09 EDT (-0400)
  Neon Signs (Message 1 to 8 of 8)
Subject: Neon Signs
Date: 28 Jul 2002 22:44:01
Message: <web.3d44abd7e694ad8fd02c7b870@news.povray.org>
Does anybody know of a good way to make a neon sign, especially one that
emits light?
Rohan _e_ii
Subject: Re: Neon Signs
Date: 28 Jul 2002 23:07:45
Message: <Xns925A3395AD3B6raf256com@204.213.191.226>
"Rohan Bernett" <rox### [at] yahoocom> wrote in
news:web.3d44abd7e694ad8fd02c7b870@news.povray.org
> emits light?
I suggest - glass, maybe media inside glass, and :
a) area_light x*10,y,10,1 to make line area lights
b) maybe use emitting media with radiosity to make madia realy emit light ?
c) use many light_sources placed inside each neone part i.e. in loop
Date: 29 Jul 2002 03:59:57
Message: <ldt9kucftabnsnkp0b42rakvg6ihq508ro@4ax.com>
On 28 Jul 2002 23:07:45 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com>
c) is better, as area lights only behave as expected when it comes to
shadows.
This could prove to be slow...
Probably the best solution, yes. Especially when you add emitting
media to fake the glow.
Peter Popov ICQ : 15002700
Date: 29 Jul 2002 10:26:38
Message: <chrishuff-6C7341.09193529072002@netplex.aussie.org>
In article <ldt9kucftabnsnkp0b42rakvg6ihq508ro@4ax.com>,
A texture with a high ambient and maybe some transparency would be
faster.
Date: 29 Jul 2002 15:42:14
Message: <slrnakb6kp.dc5.ron.parker@fwi.com>
> emits light?
I can't help with the "emits light" part but try my signature for the rest.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 31 Jul 2002 10:17:53
Message: <pan.2002.07.31.14.17.51.992920.17877@iastate.edu>
>> >light ?
> faster.
I tried to do this recently, and didn't have very good luck.  The neon
tube itself looks okay (not great) with a high ambient, but it doesn't do
as much as you'd expect for illumination.  Maybe my radiosity settings
weren't too good, but even with a count of 500 and an ambient as high as
10000, it was far from convincing.
Similar results with emitting media in a clear object.
I also never came up with a good way to control the density of the media
so that it would be highest along the central axis of the tube and fall
off toward the outside like a real neon tube.  (The tube was a complex
curve made with a sphere sweep).
	-Ed
Date: 31 Jul 2002 19:21:41
Message: <5srgkuc3ksflncmsvsip472aifpub2di05@4ax.com>
On Wed, 31 Jul 2002 09:17:52 -0500, Ed Jackson <eja### [at] iastateedu>
Did you adjust max_sample accordingly?
Date: 1 Aug 2002 17:49:24
Message: <pan.2002.08.01.21.49.24.78858.18949@iastate.edu>
>>do as much as you'd expect for illumination.  Maybe my radiosity
>>settings weren't too good, but even with a count of 500 and an ambient
>>as high as 10000, it was far from convincing.
Actually, I gave up and moved on to other things.  I might go back to it
eventually.  However, I just had it up against a wall, and it didn't even
illuminate the wall convincingly.  *shrug*  I guess I just need to play
with it some more.
	-Ed
