POV-Ray : Newsgroups : povray.general : PovRay Output Statistics Server Time
6 May 2026 22:30:48 EDT (-0400)
  PovRay Output Statistics (Message 1 to 7 of 7)
Subject: PovRay Output Statistics
Date: 6 Jun 2004 13:57:04
Message: <ujm6c0ht6ucfkir1d9jnhfe263sup2hgih@4ax.com>
Can some one explain what the Max Level results mean from the example
below. I thought it might be the Max_Trace_Level but I have set this
to 50.
Statistics for bcb03a.pov, Resolution 1024 x 768
Pixels:          786432   Samples:          786432   Smpls/Pxl: 1.00
Rays:           1434111   Saved:              2566   Max Level: 20/20
Regards
Subject: Re: PovRay Output Statistics
Date: 6 Jun 2004 14:27:14
Message: <40c36202$1@news.povray.org>
In article <ujm6c0ht6ucfkir1d9jnhfe263sup2hgih@4ax.com> , Stephen McAvoy
> to 50.
It is max_trace_level.  Probably you looked at the wrong stats or rendered a
different scene or something like that.
    Thorsten
e-mail: tho### [at] trfde
Date: 6 Jun 2004 14:44:34
Message: <dgp6c0p4dkdsb8gg0ft34ggergnr626v0q@4ax.com>
On Sun, 06 Jun 2004 20:27:13 +0200, "Thorsten Froehlich"
Thanks Thorsten,
What could change the value from 50? I copied the statistics while the
scene was rendering. Here are the scene's global settings, there is no
other instance of max_trace_level in the scene.
global_settings {
  adc_bailout 0.003922
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 1.0
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 50
  number_of_waves 10
  noise_generator 2
  charset ascii
Regards
Date: 6 Jun 2004 15:15:06
Message: <40c36d3a$1@news.povray.org>
Stephen McAvoy nous apporta ses lumieres ainsi en ce 06/06/2004 14:44... :
>Thanks Thorsten,
>global_settings {
>  assumed_gamma 1.0
>  hf_gray_16 off
>  max_trace_level 50
>  number_of_waves 10
>  noise_generator 2
>  charset ascii
>Regards
>        Stephen
Then, it must be the statistics of the previously rendered sene. The
info you mention is only displayed after a render finishes.
Date: 6 Jun 2004 15:25:17
Message: <40c36f9d$1@news.povray.org>
In article <40c36d3a$1@news.povray.org> , Alain <aze### [at] qwertygov>  wrote:
<snip>
Exactly!
Date: 6 Jun 2004 16:07:59
Message: <ibu6c09oitd6cbscnmb78t2i6k81l0kkm3@4ax.com>
True, but since it is from an animation and each frame has the same
objects and the same Global Settings. It must be because I'm using
Chris Colefax's LENS.INC and it has this line;
global_settings {max_trace_level 20}
Thanks for the input.
And hanks Thorsten.
Regards
Date: 6 Jun 2004 16:09:27
Message: <teu6c01mh0tiu08ccmnrhufcsg72adav39@4ax.com>
On Sun, 06 Jun 2004 21:08:00 +0100, Stephen McAvoy <mca### [at] aolcom>
wrote:
>And hanks Thorsten.
That's thanks Thorsten.
Regards
