POV-Ray : Newsgroups : povray.general : Pov D&D Maps Server Time
7 May 2026 10:18:15 EDT (-0400)
  Pov D&D Maps (Message 1 to 10 of 12)
Subject: Pov D&D Maps
Date: 12 Nov 2003 09:20:49
Message: <slrnbr4gd6.h6h.povfan@corky.voltar-confed.org>
OK, yeah, I'm a nerd,
I wish to make resonably good overhead maps using pov.  Does
anyone have any macros for this?  It shouldn't be a difficult
puzzle.
I'm actually hoping someone's already done all the work for me,
but that my google searches have failed because I'm incompetant
at them.
And if I'm writing it from scratch, I have identified three basic
problems in this very easy assignment.
Problem 1 is figuring out terragen or worldmap or whatever so I
can make some terrain.  I'm not really sure how to import things
I make in either of those ... So this step is the most
challenging.
Problem 2 is how to place objects on the surface of the
heightfields (or whatever).  That shouldn't be too hard.
And Problem 3 is how to place the grid over the map.  Just
thin cylinders?  Is that a good way?
If riding in an airplane is flying, then riding in a boat is swimming.
50 jumps, 15.0 minutes of freefall, 31.3 ff vertical miles.
Subject: Re: Pov D&D Maps
Date: 12 Nov 2003 11:22:08
Message: <3fb25e30@news.povray.org>
"Jettero Heller" <pov### [at] voltar-confedorg> wrote in message
news:slr### [at] corkyvoltar-confedorg...
> challenging.
You basically need to export an image output from these and use them as a height
field. See section 6.5.1.5. of the docs..
Use trace (some hf progs allow the export of co-ordinates, but IMHO trace is
easier). Check section 6.1.4.6 (Vector functions).
Dunno what the best solution is, but I'd try using an object pattern - see
6.7.11.23 of the docs.
I'm not sure how much you want to play around with these suggestions, or how
much additional help you want, but by all means ask for further
clarification/examples.
Oh, BTW, you're going to hell iirc -
http://www.chick.com/reading/tracts/0046/0046_01.asp
Date: 12 Nov 2003 12:48:47
Message: <slrnbr4sj3.pst.povfan@corky.voltar-confed.org>
No, your answers were precisely what I'd hoped for.  I just
wanted to ask if I was missing out on The Easy Way(tm).
Hilarious.
Date: 12 Nov 2003 18:24:53
Message: <3fb2c145$1@news.povray.org>
I must be a closet nerd then.
> puzzle.
I haven't played for years, but last year I started thingking about POV's
potential for creating maps. I created a couple unfinished macros to test
the idea. The macros provided nice results but are RAM and CPU intensive. To
make a long story short, you define a map one hex shapped cell at a time.
Parameters can be set for different soild types, vegetation, water, rocks,
etc....
I will dig them out tomorrow and render a test image for you. If you are
interested in the results, I'll be more thatn happy to give the macros to
you.
Tim
Date: 12 Nov 2003 18:28:45
Message: <3fb2c22d@news.povray.org>
Hay, I'm with you there. That is the main reason that I started using
POV.
Date: 13 Nov 2003 04:23:30
Message: <3fb34d92$1@news.povray.org>
But with the hard way you get James Woods (yay!).
BTW one thing I don't think I mentioned is that you probably want an
orthographic camera....
Date: 13 Nov 2003 18:50:55
Message: <3fb418df$1@news.povray.org>
I posted an image in p.b.i of map generated with the macros.
Merrin
Date: 14 Nov 2003 11:44:51
Message: <slrnbra1j4.j33.povfan@corky.voltar-confed.org>
> you.
They actually look pretty slick imho.  So I'd love a copy.
Though, 3rd edition D&D is squares instead of hexes -- eight
people can surround someone.
I'm curious to see why.  It doesn't seem like it should be...
Date: 14 Nov 2003 11:45:31
Message: <slrnbra1kb.j33.povfan@corky.voltar-confed.org>
> POV.
And did you succeed in making some?
Date: 14 Nov 2003 18:17:59
Message: <3fb562a7@news.povray.org>
Would you like me to modify the code to support squares instead of Hexes?
> puzzle.
> at them.
> challenging.
