[Crossposted to povray.general and Followup-To set]
On Sun, 05 Nov 2000 19:44:14 -0800, Thomas Lake wrote:
>Some may remember the fish tank. Sorry for the file size but anything
>bellow 2% compression and artifacts started to eat away at it.
Since this problem comes up so often in this group, I think this calls
for inclusion in Warp's VFAQ. Here is a draft entry:
How can I avoid artifacts and still get good JPEG compression?
First, you have to know a little bit about how a picture is stored
in JPEG format.
Unlike most image formats it doesn't store RGB values, but YUV
values (1 grayscale value and two "color difference" values) just
like they are used in a color TV signal. Since the human eye uses
mostly the gray values to detect edges, one can usually get away
with storing the color information at a lower resolution - an
800x600 JPEG typically has only grayscale information at 800x600,
but color information at 400x300. This is called supersampling.
For each color channel separately, the picture is then divided into
little squares and the cosine transform of each square is computed.
A neat feature of this transformation is that if you throw away only
a few of the values, the quality will degrade very little, but the
image will compress a lot better. The percentage of values stored is
called the quality.
Finally, the data is compressed.
Most programs only let you change the quality setting. This is fine
for photos and photorealistic renderings of "natural" scenes.
Generally, quality values around 75% give be best compromise between
quality and image size.
However, for images which contain very saturated colors, the lower
resolution of the color channels causes visible artifacts which are
very similar to those caused by low quality settings. They can be
minimized by setting an extremely high quality (close to 100%), but
this will dramatically increase the file size, and often the
artifacts are still visible.
A better method is to turn off supersampling. The higher resolution
will cause only a modest increase in file size, which is more than
offset by the ability to use a lower quality setting.
The cjpeg command line utility (which should be available for all
systems which have a command line, e.g., Linux, MS-DOS, Unix, ...)
has an "-sample" to set the sampling factors for all passes.
cjpeg -sample 1x1,1x1,1x1 -quality 75
should be good default values which have to be changed only rarely.
Comments? Improvements? Recommendations for Windows or Mac tools?
hp
| | | hjp### [at] wsr ac at | -- Lutz Donnerhacke in dasr.
__/ | http://www.hjp.at/ |
Subject: Re: Good JPEG compression with minimal artifacts (was: Shocked Fish. (~160k))
Date: 11 Nov 2000 21:29:27
Message: <3A0E00AD.2D0FC1EE@peak.edu.ee>
Thanks, this looks very informative.
It might be useful to mention a few links such as:
http://www.jpeg.org
http://www.ijg.org
http://www.faqs.org/faqs/jpeg-faq/
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
Date: 11 Nov 2000 22:30:29
Message: <3A0E0EE2.6B45A070@home.com>
Thanks for this. I know a little about Jpeg compression but I learned a lot
from reading this.
> in JPEG format.
> called the quality.
> hp
On Sat, 11 Nov 2000 23:33:09 +0100, Peter J. Holzer wrote...
[much snippage]
Not specifically a windows util, but Sea 1.3 for DOS can perform 1x1x1
sampling for jpeg compression. And it tuns quite happily under Win98 on
my box.
Unfortunately, I can't remember the current URL for it... (I downloaded
it a good two or three years ago)
Bye for now,
Jamie.
In article <slr### [at] teal h hjp at>,
A nice looking Mac drag-and-drop program:
"To JPEG uses a free JPEG library written by the Independent JPEG Group;
it's essentially a Macintosh port of the cjpeg program included in that
library."
http://iagu.on.net/jsam/to-jpeg/to-jpeg.html
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
In article <MPG.1478a04a70609ae498983e@news.povray.org>,
> my box.
http://www.photodex.com/downloads/platforms/dos.html
Date: 13 Nov 2000 07:09:19
Message: <3a0fd9ef@news.povray.org>
I added this to the VFAQ. Thanks for the extensive (and great) answer.
(Btw, I took the liberty of adding the option "-optimize" to your cjpeg
command.)
