POV-Ray : Newsgroups : povray.general : supershapes in povray Server Time
17 Aug 2025 13:02:02 EDT (-0400)
  supershapes in povray (Message 1 to 10 of 10)
Subject: supershapes in povray
Date: 13 Jul 2003 03:52:37
Message: <pdb_NOSPAM-B5640B.17532813072003@netplex.aussie.org>
Has anyone been following the developments of supershapes that
appeared in a brief article in Nature as little while ago? Well
3D versions can be made and there are some examples here
    http://astronomy.swin.edu.au/~pbourke/surfaces/supershape3d/
along with a PovRay macro.
Oh yeah, some people call it a "super formula".
ps: I've never written a macro before so if there are any
conventions I should have used then please let me know.
Paul Bourke
pdb_NOSPAMswin.edu.au
Subject: Re: supershapes in povray
Date: 13 Jul 2003 04:47:43
Message: <Xns93B76E72EB96Bseed7@povray.org>
in news:pdb### [at] netplexaussieorg Paul Bourke
Paul,
on that page you write "One is to use the builtin parametric primitive,
doing it this way would result in ...". Do you have a scene using the
parametric primitive available? I'd like try it with my param.inc macro (
http://members.home.nl/seedseven/ ) as it uses a syntax very close to the
parametric primitive, but to be honest I'm too lazy to figure it out for
myself.
Ingo
Date: 13 Jul 2003 07:28:45
Message: <3F11426C.E67ABF87@gmx.de>
Interesting, do you know if these shapes can be converted in an implicit
form, at least in some special cases?
This would make it easier to render them in POV-Ray without generating a
mesh.
I don't think so.  When having many parameters it might be useful to group
them into vectors, this would be easier to memorize for the user.  If you
have vector parameters it is a good idea to alternatively allow floats by
using:
#macro Test (Parameter, ...)
  #local Param_Intern=Parameter+<0,0,0>;
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 13 Jul 2003 12:24:40
Message: <Xns93B7BBA00DE90torolavkhotmailcom@204.213.191.226>
ingo <ing### [at] tagpovrayorg> wrote in
news:Xns### [at] povrayorg:
> Paul,
> primitive, doing it this way would result in ...". Do you have a scene
> using the parametric primitive available? I'd like try it with my
> param.inc macro ( http://members.home.nl/seedseven/ ) as it uses a
> syntax very close to the parametric primitive, but to be honest I'm
> too lazy to figure it out for myself.
Hi Ingo
Below is a "super shape" scene that uses your Parametric() macro.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.5;
#include "param.inc"
#macro SuperFunction(M, A, B, N1, N2, N3)
  #local Nil = 1E-12;
  #local MM = M/4;
  #local NN = -1/N1;
  function(T) {
    pow(
      Nil +
      pow(abs(cos(T*MM)/A), N2) +
      pow(abs(sin(T*MM)/B), N3),
      NN
#end // macro SuperFunction
#macro SuperShapeMesh(
         M1, A1, B1, N11, N12, N13,
         M2, A2, B2, N21, N22, N23,
         ResTh, ResPh)
  #local SuperFn1 = SuperFunction(M1, A1, B1, N11, N12, N13)
  #local SuperFn2 = SuperFunction(M2, A2, B2, N21, N22, N23)
  Parametric(
    function(Th, Ph) { cos(Th)*SuperFn1(Th)*cos(Ph)*SuperFn2(Ph) },
    function(Th, Ph) { sin(Ph)*SuperFn2(Ph) },
    function(Th, Ph) { sin(Th)*SuperFn1(Th)*cos(Ph)*SuperFn2(Ph) },
    <-pi, -pi/2>, <pi, pi/2>,
    ResTh, ResPh, ""
#end // macro SuperShapeMesh
object {
  SuperShapeMesh(
    1, 1, 1  77, 0.81, 71.7,
    8, 1, 1, 0.63, 2.92, 0.24,
    100, 50
  pigment { color rgb <1, 1, 1> }
  double_illuminate // Because of bug
  no_shadow
  location <3, 2, 4>*0.6
  look_at <0, 0, 0>
light_source { 100*x color rgb <1.0, 0.5, 0.5> }
light_source { 100*y color rgb <0.5, 1.0, 0.5> }
light_source { 100*z color rgb <0.5, 0.5, 1.0> }
Date: 13 Jul 2003 12:30:03
Message: <3f118909$2@news.povray.org>
> mesh.
What about adding the supershape as a built-in POVRay function for
isosurface? (like f_sphere, etc.)
That would at least eliminate function evaluation time.
Wolfgang
Date: 13 Jul 2003 12:50:12
Message: <Xns93B7C03FD91D0seed7@povray.org>
in news:Xns### [at] 204213191226 Tor Olav
Thank you Tor Olav
Ingo
Date: 13 Jul 2003 22:44:45
Message: <3f12191d@news.povray.org>
Hi Paul. I was trying to recreate some of the Super Shapes at your site and
punched in the numbers shown for the SS1 and SS2 parameters. Alas, I did not
get anything like the images at your site. Can you tell me if I can use the
supershape.pov macro to generate the same images you show? Perhaps that is
not the right appraoch. Great work, in any event!
Best wishes,
Dennis
"Paul Bourke" <pdb### [at] swineduau> wrote in message
news:pdb### [at] netplexaussieorg...
> Paul Bourke
Date: 13 Jul 2003 23:04:57
Message: <Xns93B8340FC7547torolavkhotmailcom@204.213.191.226>
"Dennis Miller" <dhm### [at] comcastnet> wrote in
news:3f12191d@news.povray.org:
> site and punched in the numbers shown for the SS1 and SS2 parameters.
> Alas, I did not get anything like the images at your site. Can you
> tell me if I can use the supershape.pov macro to generate the same
> images you show? Perhaps that is not the right appraoch.
Try with all the A's and B's set to 1
(SS1a = SS1b = SS2a = SS2b = 1)
E.g.:
For the first example on his web page, call the macro like this:
SuperShape(
  2, 1, 1, 0.7, 0.3, 0.2,
  3, 1, 1, 100, 100, 100,
  200
Tor Olav
Date: 14 Jul 2003 01:49:51
Message: <GFud$BAW6jE$EwVs@econym.demon.co.uk>
>Paul,
>myself.
I think it goes something like this:
// Choose one of the three examples from supershape.pov
#declare Example=1;
// Suitable camera positions for each example shape
#switch (Example)
#case (1)
  camera { location  <2,1,-2> look_at <0, 0, 0>}
  #break
#case (2)
  camera { location  <2,1,-10> look_at <0, 0, 0>}
  #break
#case (3)
  camera { location  <-0.5,0.5,-2> look_at <0, 0, 0>}
  #break
light_source {<100,200,-100> colour rgb 1}
light_source {<-100,-200,-100> colour rgb 0.5}
#macro SuperShape(SS1m,SS1a,SS1b,SS1n1,SS1n2,SS1n3,SS2m,SS2a,SS2b,SS2n1,
SS2n2,SS2n3,resol)
  #declare SS1 = function(T) { 1/
      pow( pow(abs(cos(SS1m*T/4))/SS1a,SS1n2)
    + pow(abs(sin(SS1m*T/4))/SS1b,SS1n3), 1/SS1n1)
  #declare SS2 = function(T) { 1/
      pow( pow(abs(cos(SS2m*T/4))/SS2a,SS2n2)
     + pow(abs(sin(SS2m*T/4))/SS2b,SS2n3), 1/SS2n1)
  #declare Fx=function(u,v) { SS1(u) *cos(u) *SS2(v) *cos(v) }
  #declare Fy=function(u,v) { SS1(u) *sin(u) *SS2(v) *cos(v) }
  #declare Fz=function(u,v) { SS2(v) *sin(v) }
  Parametric(Fx,Fy,Fz,<-pi/2,-pi>,<pi/2,pi>,resol,resol,"")
// Run It
object {
  #switch (Example)
  #case (1)
    SuperShape(1,1,1   77,0.81,71.7,   8,1,1,0.63,2.92,0.24, 100)
    #break
  #case (2)
    SuperShape(9,1,1,92,0.3,-45,  4,1,1,-0.8,88,-0.35,  39)
    #break
  #case(3)
    SuperShape(4,1,1,1,1,1,  0,1,1,1,1,1,  50)
    #break
  pigment {rgb 0.9}
  finish {phong 0.5 phong_size 10}
Mike Williams
Gentleman of Leisure
Date: 14 Jul 2003 20:37:37
Message: <3f134cd1$1@news.povray.org>
Thanks very much Tor.
D.
"Tor Olav Kristensen" <tor_olav_kCURLYAhotmail.com> wrote in message
> E.g.:
> SuperShape(
>   200
> Tor Olav
