POV-Ray : Newsgroups : povray.general : Parse Warning: Suspicious expression after rgb Server Time
4 Mar 2026 16:00:35 EST (-0500)
  Parse Warning: Suspicious expression after rgb (Message 1 to 6 of 6)
Subject: Parse Warning: Suspicious expression after rgb
Date: 15 May 2013 15:35:00
Message: <op.ww44olehufxv4h@xena>
How can I find out what this suspicious expression is?
The variable was obtained through eval_pigment()
-Nekar Xenos-
Subject: Re: Parse Warning: Suspicious expression after rgb
Date: 15 May 2013 17:36:28
Message: <5193ffdc$1@news.povray.org>
This is generated when what follow the rgb keyword may not be a valid
rgb triplet. It can appen in a number of ways, mostly when you apply
some arithmetics to your colour.
Normaly, it's safe to just ignore that warning. It can be used as a hint
when the colour you see is not what you intended or what it should be.
Date: 15 May 2013 23:38:54
Message: <op.ww5q24saufxv4h@xena>
nt
> Alain
Thanks Alain.
-Nekar Xenos-
Date: 16 May 2013 09:46:40
Message: <5194e340@news.povray.org>
Am 15.05.2013 21:34, schrieb Nekar Xenos:
I suspect eval_pigment() gives you a 5-component colour (RGBFT), while
rgb expects a 3-component vector. Try using "rgbft" instead of "rgb", or
omitting the "rgb" keyword entirely.
Date: 16 May 2013 12:00:01
Message: <web.519501b052d8056c2d977c20@news.povray.org>
Actually, the eval_pigment function returns just three. (I've always been
curious why it wasn't designed to return all five.)
Another possible reason for Nekar's problem might be the unexpected behavior of
color 'dot operators' (if he's using them.) The "Common color pitfalls" section
in the documentation gives a good rundown of what to watch out for. (Although
I'm not sure if the eval_pigment result constitutes a true COLOR, in the sense
of an implicit "rgb" color; it's a *function* of a color. But I use the
documentation workarounds with it anyway, just to be safe.)
Date: 16 May 2013 12:49:18
Message: <op.ww6roduqufxv4h@xena>
> behavior of
> section
> (Although
> sense
Thanks for the hint. It seems that you may be correct about the dot
operators. Just add brackets... ;)
-Nekar Xenos-
