POV-Ray : Newsgroups : povray.general : Scattering media and photons Server Time
7 May 2026 04:54:49 EDT (-0400)
  Scattering media and photons (Message 1 to 10 of 21)
Subject: Scattering media and photons
Date: 11 Mar 2004 18:43:52
Message: <ocu150drt8hccnsd7lv4g5m160hohfsh9u@4ax.com>
Well, I've got a sort of laser beam being generated in a scattering
medium so you can see the beam.
I want to be able to reflect the beam off of something, so I added the
necessary photon clauses.
However, one sees the beam as it comes out of the little laser gun
that is used to contain the light source, sees it in the medium as it
makes it way, sees it hit the object its designed to hit and that's
it. There are no visible light beams being reflected. Yet, if I tilt
the object, it correctly casts its caustics onto a background plane.
If I'm reading the documentation correctly this should work. Is there
anything obviously wrong I'm doing from my description of it, or
should I post the script to the appropriate group?
My First Subgenius Picture Book:
http://www.imbjr.com
Subject: Re: Scattering media and photons
Date: 12 Mar 2004 01:04:05
Message: <405152d5@news.povray.org>
Are you using media photons?
 - Slime
[ http://www.slimeland.com/ ]
Date: 12 Mar 2004 14:50:06
Message: <o954509i1fievc4qpbsmk1ln4pr6mfs8q6@4ax.com>
On Fri, 12 Mar 2004 01:01:45 -0500, "Slime" <slm### [at] slimelandcom> wrote:
If you mean am I using the media statement in the global photon
declaration then yes - see the attached scene file.
Hopefully, someone will be able to slap me on the forehead and tweak
me on the nose for doing something stupid in this code.
> - Slime
Download 'reflectos.pov.txt' (4 KB)
Date: 12 Mar 2004 14:54:30
Message: <cd5450p159oeei9vd9e1iglj84721scvjk@4ax.com>
> - Slime
PS. If anyone can tell me a better way of producing a beam of light I
am open to suggestions.
Currently, I've a cylinder of light in a box with a transparent sphere
cut out of it. The problem is that the documentation implies that the
rays are not parallel so I've not got what I would have thought was a
truer model of a laser beam. Notice in the code that the box is quite
big - that's because I can't seem to get the diameter of the beam any
smaller - and that's why I'm using this box get-up, to be able to
narrow the beam. I tried a parallel light, but the light comes from
the entire plane specified, and so that will not give me a single beam
of light out of box. I tried looks_like (with a small sphere) on the
cylinder and parallel light options and neither wored.
Date: 12 Mar 2004 23:20:40
Message: <40528c18@news.povray.org>
Hmm, I vaguely remember other people having troubles with cylinder lights
and photons... but I don't remember what the solutions were.
 - Slime
Date: 13 Mar 2004 10:53:58
Message: <btb650tm5bqmehlv463uie51em8g1ke70n@4ax.com>
On Fri, 12 Mar 2004 23:18:50 -0500, "Slime" <slm### [at] slimelandcom> wrote:
LOL
Cheers, that fills me with hope!
> - Slime
Date: 15 Mar 2004 04:29:49
Message: <opr4wcqgeqp4ukzs@news.povray.org>
>> lights
> LOL
>> - Slime
Hopefully you won't object to comments from a newbie, but as I've been
messing with this sort of thing I may know what's happening.
The parallel light source beam diameter seems to be controlled by the
tightness keyword, as for reflecting the light beam off a reflected
surface; it doesn't.
As they say a picture is worth a thousand words;
//code
global_settings {
photons {
count 20000
media 200
autostop 0
jitter .4
#declare LightReflector=
prism{0,6,4
<3,0>,<3,-3>,<0,-3><3,0>}
media{
scattering{1,rgb 0.01}
light_source{<1.5,3,50>, rgb <100,0,0> cylinder point_at<1.5,3,-10>
tightness 0.3
media_attenuation on
media_interaction on
camera{
location<1.5,20,-1.5>
look_at<1.5,0,-1.5>
/*location <-5,3,-1.5>
look_at <10,3,-1.5>*/
object{LightReflector hollow
photons{
target
reflection on
pigment{rgb 0.85}
finish{reflection {1.0} ambient 1 diffuse 0}
sphere{0,0.2 pigment{rgb 0.8} finish{ambient 0} translate <1.5,3,0.5>}
sphere{0,0.2 pigment{rgb 0.8} finish{ambient 1} translate <2,5,0.5>}
//end code
As you can see from the top view the light beam isn't reflected, but if
you switch to the other camera view the white sphere is reflected in the
prism. The only way round this I think is to point a cylinder light where
the beam should reflect.
Hope this helps
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 15 Mar 2004 16:14:34
Message: <8d7c50t9lui77r465c5efdlhv8am482jmk@4ax.com>
On Mon, 15 Mar 2004 09:31:18 -0000, Phil Cook
>>> lights
>> LOL
>>> - Slime
>//code
>global_settings {
>photons {
>count 20000
>media 200
>autostop 0
>jitter .4
>prism{0,6,4
>media{
>tightness 0.3
>camera{
>look_at<1.5,0,-1.5>
>photons{
>target
>reflection on
>pigment{rgb 0.85}
>//end code
>Hope this helps
Interesting. I've had a play with your scene and still can't see why
this does not work. After all I'm sure the documentation does talk
about photons being trapped/held/sampled in media.
>Phil
Date: 16 Mar 2004 05:01:23
Message: <opr4x8vnzup4ukzs@news.povray.org>
>>>> lights
>>> LOL
>>>> - Slime
<snip code>
>> where
>> Hope this helps
Yeah I've fiddled with it at lot too, add a new camera at:
location <10,7,3>
look_at <-10,3,3>
add a box at:
box{0,<-10,10,-100> rotate y*22.5 translate <-10,0,10> pigment {rgb 0.8}
finish{reflection {1.0} ambient 0.5 diffuse 1}}
then switch the LightReflector to ambient 0.5 diffuse 1
you can see that the light beam is being calculated as there is a patch on
the box however note the lack of a shadow from the first sphere which
should appear in the middle of it, also note the lack of the reflected
shadow in the box part which is showing the reflection of the
LightReflector.
So unless there's something I'm missing it appears POV-Ray can't do this
sort of thing with media.
Phil
Date: 16 Mar 2004 15:37:41
Message: <7jpe50ttstqe6gvdasidg304fdv24u2h2r@4ax.com>
On Tue, 16 Mar 2004 10:03:13 -0000, Phil Cook
>>>>> lights
>>>> LOL
>>>>> - Slime
><snip code>
>>> where
>>> Hope this helps
>location <10,7,3>
>look_at <-10,3,3>
>add a box at:
>LightReflector.
How odd. Unless I'm misreading the documentation, we should be able to
do this. I'm sure I've see a classic Dark Side Of The Moon prism with
refracted beam done in POV. I can't see why reflections should be any
different.
>Phil
