POV-Ray : Newsgroups : povray.general : Rendering part of an image in black and white Server Time
17 Aug 2025 03:40:41 EDT (-0400)
  Rendering part of an image in black and white (Message 1 to 4 of 4)
Subject: Rendering part of an image in black and white
Date: 26 Aug 2003 05:30:53
Message: <kaveh1000-7C8313.10305126082003@netplex.aussie.org>
I have a particular project for which I need to render a scene in black
and white. Ideally, I need a filter (like a photographic filter) which
shows a scene in black and white when we look through it.
So imagine a rendered scene which is in full color, except a part of it
which is scene through a special glass filter which is held up.
I looked at the archives and the nearest solution I can find is to use
hf_gray_16 in the global settings, and re-import that to somehow
generate a black and white scene:
http://news.povray.org/povray.general/1150/
Is there any other method I can use to do this in a single render?
Kaveh
Subject: Re: Rendering part of an image in black and white
Date: 26 Aug 2003 06:40:34
Message: <7hdmkvsdtnoqc06ut5rld340q39njfonh5@4ax.com>
On Tue, 26 Aug 2003 10:30:53 +0100, Kaveh Bazargan <kav### [at] maccom> wrote:
1. Render your scene in color into image.png.
2. Render your mask.png with area of glass filter as white and rest in black.
3. Create scene like:
  #version 3.5;
  global_settings{assumed_gamma 1.0}
  #include "screen.inc" /* http://www.povray.org/documentation/view/288/ */
  #declare Image=pigment{image_map{"image.png"}};
  #declare f_Image=function{pigment{Image}};
  #declare Processed=texture{
    pigment{
      image_pattern{"mask.png}
      pigment_map{
        [0 Image]
        [1 function{f_Image(x,y,z).gray}]
    finish{ambient 1 diffuse 0}
  Screen_Plane(Processed, 1, 0, 1)
not tested but should work the way I understand your problem.
ABX
Date: 26 Aug 2003 06:51:06
Message: <kaveh-6F75AE.11510526082003@netplex.aussie.org>
In article <7hdmkvsdtnoqc06ut5rld340q39njfonh5@4ax.com>,
>   #version 3.5;
>     pigment{
>       pigment_map{
>         [0 Image]
Thanks very much for taking the time to write this. Plenty of new stuff
for me to learn here.
Can I just confirm, this needs two renderings, one to create the first
png, another to map it onto the 'screen'. Any possibility of a single
render?
Kaveh
Date: 26 Aug 2003 07:01:47
Message: <r5fmkvobr2og1duds82hrqa8dh9calnpt5@4ax.com>
On Tue, 26 Aug 2003 11:51:05 +0100, Kaveh
Have a good time with it :-)
> render?
In fact the way I did it it needs three renderings: image, mask, combination
of image and mask. You don't have to create mask into separate image so you
can do it in two renderings too. mask can be any function which returns floats
gray values within area <0,0,0>-<1,1,0>. To have single process you can use
POST_SCENE_COMMAND and/or POST_FRAME_COMMAND ini options - see manual. In
MegaPOV 1.1 it will be possible to make everything in single render but
MegaPOV 1.1 has to wait with release :-(
ABX
