POV-Ray : Newsgroups : povray.general : STL file problem Server Time
24 Aug 2025 10:08:12 EDT (-0400)
  STL file problem (Message 1 to 3 of 3)
Subject: STL file problem
Date: 17 Feb 2009 11:04:14
Message: <fdnlp4tq9jt8skqtivv1a8t9bduupr2ufo@4ax.com>
I have a copy of the free command line STL2POV converter that works
well for many STL files but not for the one I really want to run !!!!!
This is "Magnatron.stl"  produced by Bathsheba Grossman.  As described
at http://www.evilmadscientist.com/article.php/slicingstl
trying to convert this file gives an error and a very small .inc file.
I assume that there is an error in the stl file itself.
A few questions.
1	Has anyone got a working version of .metatron.inc and if so
where did it come from.
2	Is there a windowns stl  - pov conversion program rather than
the DOS one.
3	On a similar theme how can you get .off files into POVray ?
John
Subject: Re: STL file problem
Date: 17 Feb 2009 11:25:00
Message: <web.499ae44db58202a76dd25f0b0@news.povray.org>
john <@>ntlworld.com wrote:
> A few questions.
> the DOS one.
Can't help you with the first one I'm afraid, but Meshlab should help for the
rest. Convert to .obj, then use the excellent PoseRay to get the .objs to
POV-Ray.
http://mysite.verizon.net/sfg0000/
http://meshlab.sourceforge.net/
A little convoluted, but should do the job!
Bill
Date: 17 Feb 2009 15:42:48
Message: <178mp4t9o03bqrv77d9ur22ggcgjc68g7f@4ax.com>
On Tue, 17 Feb 2009 11:22:37 EST, "Bill Pragnell"
>> A few questions.
>> the DOS one.
>POV-Ray.
>Bill
Thanks that helped a lot.
Meshlab opend the metatron.stl file and from there I could get it into
pov with Poseray.
Should work OK with the off files as well
thanks
