POV-Ray : Newsgroups : povray.general : It's alive! Server Time
12 Sep 2025 22:44:52 EDT (-0400)
  It's alive! (Message 1 to 4 of 4)
Subject: It's alive!
Date: 23 Oct 2002 19:06:55
Message: <chrishuff-53169C.19005623102002@netplex.aussie.org>
I just got G to successfully compile and run a function!
function scalar main(scalar n, scalar p) {return n*n + p;};
It supports arithmetic, function declarations, and...um, the return
statement. Ok, it needs a little work. ;-)
It does support scalar and vector math, and I'm especially proud of the
expression parser...I'm going to use some of the compiler techniques I
developed while working on it in Sapphire.
The language itself is pretty much as the above line shows. It is
designed to do as much work as possible at compile time, it should run
fairly quickly...faster than Sapphire, anyway, because Sapphire is an
extremely dynamic language while this is almost entirely static. I have
no idea how it'd compare against POV functions, probably quite a bit
slower at the moment. (almost no optimizations are done)
Next: Function calls, flow control, and numeric constants (it doesn't
even understand things like "2+2" yet).
Posted in *.general because this is going to be part of a POV patch, but
is not restricted to POV...
http://tag.povray.org/
Subject: Re: It's alive!
Date: 23 Oct 2002 21:14:10
Message: <chrishuff-7D4E2B.21081223102002@netplex.aussie.org>
In article <chr### [at] netplexaussieorg>,
It now supports scalar and vector variables, numeric constants, if(),
if()-else, and while() statements. ;-)
Date: 23 Oct 2002 21:20:28
Message: <3db74adc$1@news.povray.org>
So what is this patch exactly? An extension to functions?
 - Slime
[ http://www.slimeland.com/ ]
Date: 23 Oct 2002 22:06:06
Message: <chrishuff-3C9253.22000923102002@netplex.aussie.org>
In article <3db74adc$1@news.povray.org>, "Slime" <slm### [at] slimelandcom>
It isn't a patch, though it will be part of one eventually. It's just a
very simple procedural language designed to be interpreted quickly, for
things like shading or math computations. I'm going to try to get it to
work alongside or through POV functions.
