The scene below results in "Expected 'function identifier', } found
instead".
Are the three bitwise_.. functions not usable in functions? Bug? Me?
Ingo
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
plane{
<0,1,0>, 0
texture{
pigment{
function{bitwise_xor(x, y, z)}
light_source{< 3000,3000,-3000> rgb 1}
angle 75
location <0.0 , 3.0 ,-3.0>
look_at <0.0 , 1.0 , 0.0>
https://ingoogni.nl
Yikes.
I've tried all manner of things to correct the syntax or find a workaround, but
I can't even get the parser to recognize the expressions
#declare F1 = function {bitwise_and (x, y, z)}
#declare F2 = function {bitwise_or (x, y, z)}
#declare F3 = function {bitwise_xor (x, y, z)}
SO, I'm thinking that the problem is that somehow those built-in function
identifiers never got put in a list to get passed to the (separate) function
parser. Oof.
Which means that until that gets fixed, you're going to have to roll your own
user-defined functions in SDL. :( I recall doing this somewhere, when I didn't
know that our bitwise operators were spelled-out function identifiers and not
the usual symbols.
I can go hunt that down if you need me to...
https://stackoverflow.com/questions/7199625/mathematical-equation-for-and-bitwise-operation
(a & b)
can be done with:
(((a/1 % 2) * (b/1 % 2)) * 1) +
(((a/2 % 2) * (b/2 % 2)) * 2) +
(((a/4 % 2) * (b/4 % 2)) * 4) +
(((a/n % 2) * (b/n % 2)) * n)
Where n is 2 to the number of bits that A and B are composed minus one. This
assumes integer division (remainder is discarded).
in news:web.62c97261fd43e9001f9dae3025979125@news.povray.org Bald Eagle
wrote:
> Yikes.
Yes.
I'll make a bugreport of it.
Doing my own in SDL is not important now, was just fiddling around.
Thanks.
https://ingoogni.nl
I don't think this a bug so much as unsupported. Just FYI, it should probably be
a feature request rather than a bug report.
Also, the documentation says that these functions treat the inputs as integers.
Is that what you are expecting?
Bald Eagle is exactly right as to why this isn't working, BTW.
For function{} there is a separate function parser that is pretty restrictive,
and it will not support calling things like bitwise_xor(), trace(), etc. It only
supports numerical values, operators, variables/parameters, and references to
other defined function names. So for this to work, someone would need to define
a "built-in" f_bitwise_xor function (for example), that you could then call in
function blocks.
You would indeed need to "roll your own" using only operators and simple
variables.
Yes, you may be right. They are mentioned in the numeric expression
section but not in the functions section. :(
https://ingoogni.nl
