POV-Ray : Newsgroups : povray.general : Material for a lamp? Server Time
8 Mar 2026 01:40:11 EST (-0500)
  Material for a lamp? (Message 1 to 2 of 2)
Subject: Material for a lamp?
Date: 29 Dec 2004 12:56:52
Message: <Xns95CEC0E137F6raf256com@203.29.75.35>
What material would be best for a lamp, or "cloth", or  curtain/drapery on
a window?
The problem is, that such material can be lighted by light comming from
behind, but using transparent or filter gives bad results because it makes
it look like glass/plastic/folium, not like "cloth".
Some random ideas are to use - strong normal like granite 2 scale .1 but no
refletion/specular, low brilliance, no_shadow, diffuse media (but this is
very slow), or tricks with adding shadowless lights to color_group of
objects that are made of such material...
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Material for a lamp?
Date: 29 Dec 2004 21:31:27
Message: <41d3687f@news.povray.org>
> a window?
The most "realistic" way to handle this may be to use an open cone with
double_illuminate and radiosity so that it brightens things around it. But
that obviously has severe shortcomings: double_illuminate doesn't model the
scattering of light through cloth very well, and radiosity isn't fast.
So, a more practical approach might be to use an object with no_shadow, and
light it manually:
finish {diffuse 0 ambient 1}
Then light will pass through it and it will appear bright. If you want it to
cast a shadow on the room, you can then add another object the same shape
with no_image, and color it with whatever transparency gives the best
shadow.
 - Slime
 [ http://www.slimeland.com/ ]
