POV-Ray : Newsgroups : povray.general : texture dependent on surface normal angle? Server Time
6 May 2026 12:38:05 EDT (-0400)
  texture dependent on surface normal angle? (Message 1 to 4 of 4)
Subject: texture dependent on surface normal angle?
Date: 27 Oct 2004 23:28:33
Message: <Xns9590382047634raf256com@203.29.75.35>
Is there a way to blend textures, as in texture_map, but using angle of
normal as a pattern?
So that "walls" - surfaces like :
 | plane { x,0 }  or plane { z,0 }
will have texture A, and flat surfaces like
-----  plane { y,0 }
would have texture B, and
plane { y,0 rotate x*45 /* or z*45 */ }  will be 50% A and 50% B
I want to use it for rusty ship - so that deck floor would have quite
normal surface, and all walls will have "water steams" / rust (like this
marks under windows, etc)
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: texture dependent on surface normal angle?
Date: 27 Oct 2004 23:31:51
Message: <Xns959038AF91C18raf256com@203.29.75.35>
spa### [at] raf256com news:Xns9590382047634raf256com@203.29.75.35
So its something between MlPov's, and 3.6 faced normal pattern.
It would be excelent to have possibility of using:
  function { normal.z }
where normal is normal vector of given surface in currently evaluated
point. Or is something like this already available?
Computer Graphics
Date: 28 Oct 2004 02:17:08
Message: <nm31o0tr572ves5e3u1jm6ivavo9qd70l4@4ax.com>
On 27 Oct 2004 23:28:33 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
Slope pattern can help you
http://www.povray.org/documentation/view/3.6.1/393/
ABX
Date: 11 Nov 2004 23:29:58
Message: <Xns959F384FBE9DFraf256com@203.29.75.35>
abx### [at] abxartpl news:nm31o0tr572ves5e3u1jm6ivavo9qd70l4@4ax.com
Yeap, it did, thanx.
Btw - isn't there any way to use it in a function?
Like:
  function {
    f_slope.x + x*2 + f_bozo(x,y,z)
Computer Graphics
