POV-Ray : Newsgroups : povray.general : Problem with small-angle camera and radiosity Server Time
6 May 2026 14:07:21 EDT (-0400)
  Problem with small-angle camera and radiosity (Message 1 to 7 of 7)
Subject: Problem with small-angle camera and radiosity
Date: 7 Oct 2004 14:01:11
Message: <Xns957BCB950ADBAraf256com@203.29.75.35>
Radiosity seems to work wrong when used with very-small-angle perspective
camera.
Such camera can be used to simulated ortographics one, like
camera { angle 45/X  location 10*X }  with X = 10000;
  instread of
camera { ortographics angle 45 location 10 }
When using such camera radiosity gets very strongly distored.
Only using extremly low minimum_reuse can partialy prevent that from
happening.
IMHO that could indicate that either there is a lost-precission problem,
or, despite what documentation states, minimum_reuse is based on angle
(like - each sample per 1 degree) not on pixels.
Rendered images and minimal code is on
http://www.raf256.com/povray/bug/radiosity-orthographic/
And below + on p.b.i
Change SHOW_BUG to see good version, bug, and partial fix.
// bug (problem) while immitating orthographic camera by
// standard-perspectiver camera with very narrow angle
// suggested:  +w640 +h480 +a0.03 +am2 +r2 +fn
#declare SHOW_BUG = 1; // 0=normal 1=show bug  2=show bug + partialy fix
union {
  box { -100, +100 pigment { rgb 1 }  }
  box { <-80,-80,+150> <+80,+80,0> pigment { rgb <1,0,0> } }
  finish { ambient 0 }
  #local FlatPerspective = 1.0;
  #if (SHOW_BUG)
    #local FlatPerspective = 5000.0;
  #else
    orthographic
  up y  right x*(image_width/image_height)
  angle 60/FlatPerspective
  location 250*FlatPerspective
  look_at 0
light_source { <500,2000,1000> rgb 1 }
global_settings { radiosity {
    count 1600 error_bound 0.3 nearest_count 15  // very-high quality
    //count  800 error_bound 0.6 nearest_count 12 // high quality
    #if (SHOW_BUG=2)
      minimum_reuse 0.000001
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Problem with small-angle camera and radiosity
Date: 7 Oct 2004 15:32:03
Message: <416599b3$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns957BCB950ADBAraf256com@203.29.75.35...
> camera.
>   instread of
> happening.
> union {
> camera {
>   #if (SHOW_BUG)
>   #else
>     orthographic
>   #end
>   look_at 0
>     #if (SHOW_BUG=2)
>     #end
just to nitpick before everyone else, is this pov 3.6 or 3.6.1? official
release or custom compile? what operating system?
not that I would know if it is or isn't a bug... just getting the obligatory
system setup questions out of the way.
Date: 7 Oct 2004 16:08:20
Message: <Xns957BE1294CBBAraf256com@203.29.75.35>
rli### [at] everestkcnet news:416599b3$1@news.povray.org
> official release or custom compile? what operating system?
> obligatory system setup questions out of the way.
Uuups, sorry, I knew I forgot something.
3.6.1 ofcourse,
3.6.1.icl8.win32 running on WinXP 2 Ghz Athlon to be precise.
Computer Graphics
Date: 7 Oct 2004 16:12:56
Message: <Xns957BE1F0A928Fraf256com@203.29.75.35>
spa### [at] raf256com news:Xns957BE1294CBBAraf256com@203.29.75.35
> 3.6.1 ofcourse,
MegaPov 1.1 / based on 3.6.1.mingw-3.1(gcc-3.2.3).unofficial.win32
MegaPov 1.1 / based on 3.6.1.MetroWerks.unofficial-win32
Give same result. Shape of shadow was *identical* to a pixel, only one-two
small parts of a shadow was a bit (like 5%) brighter then the 3.6.1
official version, and MegaPov is exacly identical to MegaPov-MW output by
the way.
Computer Graphics
Date: 8 Oct 2004 05:14:02
Message: <41665a5a@news.povray.org>
> camera.
  If you use very small camera angles, all kinds of floating point errors
are prone to happen. These errors are usually not bugs, but simply
limitations in the accuracy of the floating point numbers and the
rendering engine.
  There's a good example of this at:
http://tag.povray.org/povQandT/languageQandT.html#largescaleproblems
Date: 8 Oct 2004 05:31:32
Message: <Xns957C752F8C122raf256com@203.29.75.35>
war### [at] tagpovrayorg news:41665a5a@news.povray.org
> errors are prone to happen. These errors are usually not bugs, but simply
Yes, almost same problem :)
How about issuing a warning in such situation (angle < 0.1)?
Computer Graphics
Date: 8 Oct 2004 06:02:34
Message: <416665ba@news.povray.org>
In article <Xns957BCB950ADBAraf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
>     #if (SHOW_BUG=2)
>     #end
There is no bug here at all. You are simply exceeding the maximum resolution
radiosity can offer.  That is also why setting higher quality improves
quality while reducing radiosity quality settings makes the resolution
limits more visible.  You will see pretty much the same effect if you just
render your image at 5000 times the resolution with a normal camera angle
(well, if you could render such a huge image anyway).
    Thorsten
e-mail: tho### [at] trfde
