POV-Ray : Newsgroups : povray.general : HF_Square Macro usage? Server Time
2 Nov 2024 05:20:00 EDT (-0400)
  HF_Square Macro usage? (Message 1 to 4 of 4)
Subject: HF_Square Macro usage?
Date: 18 Apr 2004 12:41:06
Message: <Xns94CF75BE6AFC1cybermans.pov.posts.@203.29.75.35>
I'm attempting to use this and I seem to have failed to understand how this
Macro works.
What I've defined is this:
#declare HF_R=seed(0);
#macro HF_F(X, Y, Z)
   rand(HF_R);
#declare Ground=HF_Square(HF_F, false, false, <40, 40 >, 1, "", <-20, -1, -
20>, <20, 4, 20>)
object
   Ground
This of course bombs completely.. so how does one use the HF_Square macro?
It's not obvious and there are no examples I could find.
Clue me in please?
Subject: Re: HF_Square Macro usage?
Date: 18 Apr 2004 12:53:34
Message: <cjameshuff-96F2D1.12543718042004@news.povray.org>
In article <Xns94CF75BE6AFC1cybermans.pov.posts.@203.29.75.35>,
You have to pass a function to the macro, you can not use a macro. For
example:
#include "functions.h"
#declare HF_F = function {f_noise3d(x, y, z)}
#declare Ground = HF_Square(HF_F, false, false, < 40, 40>, 1, "",
<-20,-1,-20>, <20, 4, 20>)
rand() can not currently be used in functions, but it would be fairly
useless for this anyway.
Look at the shapes.pov demo scene, in the incdemo folder.
http://tag.povray.org/
Date: 19 Apr 2004 00:44:50
Message: <Xns94CFF0733E542cybermans.pov.posts.@203.29.75.35>
Christopher James Huff <cja### [at] earthlinknet> wrote in
news:cjameshuff-96F2D1.12543718042004@news.povray.org:
> example:
I noticed so I used the bump pattern :) Thanks.
This is just what I was looking for! Thanks.. looks like it works with any
object so I could use an external height field as well.
I suppose there just was no cross reference :/
Date: 19 Apr 2004 10:31:52
Message: <cjameshuff-E3FA35.10325719042004@news.povray.org>
In article <Xns94CFF0733E542cybermans.pov.posts.@203.29.75.35>,
I'm not sure what you were trying to say here. The height field macros
don't "work with any object"...there are separate macros specifically
written for square, spherical, and cylindrical height fields. As for the
"external height field", you can use an image to generate a height field
using these macros like you would with the built-in height field
primitive, and you can use the mesh file generated by a previous call of
the macros, but that's it.
The documentation should probably at least mention this scene...
