POV-Ray : Newsgroups : povray.general : [wish] Limits and hints - parameters Server Time
2 Nov 2024 07:26:00 EDT (-0400)
  [wish] Limits and hints - parameters (Message 1 to 4 of 4)
Subject: [wish] Limits and hints - parameters
Date: 1 Apr 2004 12:54:56
Message: <Xns94BECA44B61B4raf256com@203.29.75.35>
how about adding an limits and hints system?
Let me explain on example,
photons count *must* be >= 0, so its limits are 0 .. about 2^32
Any other value will cause should stop render with error mesage.
For IOR, usualy values are >= 1, but for artistics reasons any value could
be used, so there is no limit, but there is a hint - 1.0 .. 10.0 (other
values will cause Warining, or rather Hints - new stream type in addition
to debug, warning,...)
Limits could be placed both in code so that renderer will inform about them
at parsing-time, and in documentation.
Maybe it would be a good idea to start from documentation, since especialy
newusers could be a bit confused - I think every value should be described
in documentation by default value, suggested values, and valid values
limits.
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: [wish] Limits and hints - parameters
Date: 1 Apr 2004 12:57:13
Message: <Xns94BECAA789234raf256com@203.29.75.35>
spa### [at] raf256com news:Xns94BECA44B61B4raf256com@203.29.75.35
> especialy newusers could be a bit confused - I think every value
> should be described in documentation by default value, suggested
> values, and valid values limits.
Btw, I wish to help adding this to manual, can I help - what tools should I
download to edit source code of help (AFAIK all versions of manual are
generated from one source?). Is there maybe some tool to edit them for
Windows (or are they in some text/html-like format?)
Computer Graphics
Date: 1 Apr 2004 21:56:12
Message: <406cd64c$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns94BECA44B61B4raf256com@203.29.75.35...
> Hi,
I often use IOR's > 10 for metal textures (using fresnel reflection)
cu!
Date: 2 Apr 2004 01:12:29
Message: <sp0q6055370qa0eq75bpsicfktmvos7ad6@4ax.com>
On 1 Apr 2004 12:54:56 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
POV-Ray is not 32-bit only.
ABX
