POV-Ray : Newsgroups : povray.general : Bug when using radiosity + photons + dispersion Server Time
22 Jan 2025 11:54:46 EST (-0500)
  Bug when using radiosity + photons + dispersion (Message 1 to 2 of 2)
Subject: Bug when using radiosity + photons + dispersion
Date: 25 Feb 2004 22:13:35
Message: <Xns949B2AEF062F9raf256com@203.29.75.35>
Just a quick info, I'll post full bug-report with test and minimalistic
scene to reproduce bug tomorrow.
In 3.6 there stil is a bug that I reporded about half year ago in 3.5
Sometimes when using photons (refracted) and radiosity, colors of photons
[spots] are wrong. In 3.5 "wrong" ment that their was in gray-scale, in 3.6
I noticed either that, or - red component was missing (only green-blue
photons).
Scene: Put an glass ball with ior say 1.5 and some dispersion on a ground
(white plane). use photons on sphere  (target on),  use radiosity.
Reproduction of bug:
* wen You STOP render in it's pre-rendre radiosity phase and re-run it
without restarting (frequency - about 1 in 4 times in Pov 3.5 and 3.6).
Restarting Pov helps, with might suggest some kind of memory leak, or
uninitialized variable.
* even when You normaly start render (without STOPing it first) same thing
happends I think (frequency - I noticed in only once in about 30 renders,
only in 3.6)
Subject: Re: Bug when using radiosity + photons + dispersion
Date: 26 Feb 2004 02:54:51
Message: <kg9r305v7ibcrcji7sft2qub6eafra23au@4ax.com>
On 25 Feb 2004 22:13:35 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
Please do not forget rest of bug-reporting guidelines then. TIA,
ABX
