POV-Ray : Newsgroups : povray.general : #read only supports 3D vectors Server Time
11 Sep 2025 08:43:46 EDT (-0400)
  #read only supports 3D vectors (Message 1 to 8 of 8)
Subject: #read only supports 3D vectors
Date: 4 Oct 2003 10:41:43
Message: <Xns940A6CCFCD48DNone@204.213.191.226>
I noticed someone mentionned this in the newsgroups a few years ago, I
guess it's still the same?  #read only supports 3D vectors, not 2,4 or 5?
Unless I'm doing something wrong?  (Yeah, I know, just use four seperate
floats and reassign the 4D vector with them... just not as elegant)
Example:
#declare CurColor = <1,1,1,0.8>;
#if (clock > 0)
  #fopen ColorFile "curcolor.dat" read
  #read (ColorFile,CurColor)  // <- Error
  #fclose ColorFile
#macro V4strC(V)
    concat("<",vstr(4,V,",",10,7),">, ")
#fopen ColorFile "curcolor.dat" write
#write (ColorFile,V4strC(CurColor),"\n")
#fclose ColorFile
Subject: Re: #read only supports 3D vectors
Date: 4 Oct 2003 11:50:14
Message: <3f7eec36$1@news.povray.org>
I'm not sure, but what is the error message POV spits out when trying to
load?
Tim Nikias v2.0
Email: tim.nikias (@) gmx.de
> Example:
> #if (clock > 0)
>   #fclose ColorFile
> #end
> #macro V4strC(V)
> #end
> #fclose ColorFile
Version: 6.0.521 / Virus Database: 319 - Release Date: 23.09.2003
Date: 4 Oct 2003 11:53:55
Message: <3f7eed13$1@news.povray.org>
Aside of that, your text looks strange to me: Just using
#write (SomeOutputFile, FourD_Vector)
suffices, no need to concat it to string first.
Tim Nikias v2.0
> load?
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
5?
> > Example:
> > #if (clock > 0)
> >   #fclose ColorFile
> > #end
> > #macro V4strC(V)
> > #end
> > #fclose ColorFile
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
Date: 4 Oct 2003 14:08:48
Message: <Xns940A8FEB2C3C1None@204.213.191.226>
"Tim Nikias v2.0" <tim.nikias (@) gmx.de> wrote in news:3f7eed13$1
@news.povray.org:
Error is: 4D vector unexpected.
That was just an example.  Control of precision and the comma is useful
with many data elements, might not be with a single colour, but with
something like quaternions higher precison than the default might be
desired. "\n" is useful for human readability.  Isn't so strange to me.
Date: 6 Oct 2003 02:42:33
Message: <3f810ed9@news.povray.org>
I never use the #read primitive, it's usually much easier to save in a
POV-script format (objects declarations, array definitions and
initialisations, etc.) and to load using the very basic #include
primitive that has all the parsing functionalities already implemented
(including 4D and 5D vectors).
JC
> Example:
> #if (clock > 0)
>   #fclose ColorFile
> #end
> #macro V4strC(V)
> #end
> #fclose ColorFile
Date: 6 Oct 2003 06:18:39
Message: <3f81417f@news.povray.org>
I've never noticed that the default isn't proper. E.g. for floats, it will
just put 0.2 for 0.2, but it will use .21342 if that's the number. AFAIK,
that's the same for vectors, so what you're doing is forcing it to round to
a certain precision.
Have you looked at the output-file to see if the vector is written
correctly? And I'm not too sure, but isn't the variable you're loading a
value to (CurColor in this case) supposed to be undefined before loading?
I've never had problems using my I/O-Macs, and they support all kinds of
vectors and floats, so I'm not sure where you're problem originates...
Tim Nikias v2.0
> @news.povray.org:
Date: 6 Oct 2003 12:43:15
Message: <Xns940C81678D7CDNone@204.213.191.226>
news:3f81417f@news.povray.org:
> will just put 0.2 for 0.2, but it will use .21342 if that's the
> number. AFAIK, that's the same for vectors, so what you're doing is
> forcing it to round to a certain precision.
No, Povray uses default precision, try it.  If one of the numbers is
really small, Povray's default will write out something like: "1.22461e-
032", which might be rounding errors I don't want to carry forward.  On
the other hand, if one of the numbers is 1.0000005, Povray will write out
"1", which is precision I don't want to lose.  (I'm using the Windows
version).
> a value to (CurColor in this case) supposed to be undefined before
> loading?
Yes, it's written correctly in the file, and... EUREKA! That's the
problem, because I had already initialized the vector.  Hehehe, from the
Help on #read: "A DATA_IDENTIFIER is any undeclared identifier or any
previously declared string identifier, float identifier, or vector
identifier.".  I guess that doesn't apply to non 3D vectors.  I've
initialized all of my other variables and 3D vectors before reading them
without any issues, so I didn't think about that for a 4D.
Thanks.
Date: 6 Oct 2003 12:44:10
Message: <Xns940C818EDA833None@204.213.191.226>
"JC (Exether)" <no### [at] spamfr> wrote in news:3f810ed9@news.povray.org:
Good idea!  Thanks.
