POV-Ray : Newsgroups : povray.general : .pov in .html Server Time
16 Aug 2025 18:55:43 EDT (-0400)
  .pov in .html (Message 1 to 10 of 12)
Subject: .pov in .html
Date: 21 Sep 2003 15:42:38
Message: <Xns93FDDCB18BF46raf256com@204.213.191.226>
where can I downoad programs to make colored .html document from .pov file
(best - basing on CSS classes that can be later declared in <head> by
autor)?
Or maybe - do someone have PHP script for generating such code?
TIA
Subject: Re: .pov in .html
Date: 21 Sep 2003 15:46:48
Message: <3f6e0028$1@news.povray.org>
Found this just today while I was googling
for POV-Related stuff and JRG's Scatter-
Macro:
http://www.hanfordonline.co.uk/povray/content/pov2html/
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> Hi,
> autor)?
> TIA
> #macro
g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local
l=mod(c,100
> );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end
light_source{
> y 2}sphere{z*20
9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Version: 6.0.518 / Virus Database: 316 - Release Date: 11.09.2003
Date: 21 Sep 2003 15:48:49
Message: <3F6E0095.E207F166@pacbell.net>
Rafal 'Raf256' Maj wrote:
> Hi,
> autor)?
http://www.palfrader.org/code2html/
Ken Tyler
Date: 21 Sep 2003 15:55:01
Message: <3f6e0215@news.povray.org>
  It uses variable-width font... ugh!
Date: 21 Sep 2003 16:46:09
Message: <3f6e0e11$1@news.povray.org>
Looks good to me, except that it uses "strong" tags for everything, which is
fairly arbitrary... when you're styling with CSS, you should use HTML tags
that closely represent what they surround. Obviously, there's no
<povkeyword> tag, but it might make sense to use an <em> tag for that
(because you want the keywords emphasised in one way or another), and maybe
<span> tags for most other things, since there's no real meaning associated
with them.
Now, what would be *really* awesome, is if it turned macro calls and
identifiers into hyperlinks which linked to the place in the source where
they were defined... =)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Sep 2003 16:51:04
Message: <3f6e0f38@news.povray.org>
Yes, I made one last year. It is still on the free webspace where
I uploaded it then. You can see its output here:
http://mitglied.lycos.de/lpvader/pov2html/pov2html.php?sourcefile=source.pov
If you want the source, you can just use a security hole in it
to get it ;-)
Lutz-Peter
Date: 21 Sep 2003 20:24:23
Message: <Xns93FDCF1FAEA40POVMIKA@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in
news:3f6e0215@news.povray.org:
Umm its fixed width for me, chances are that your brower's
default setting for fixed font has been set/changed to a
variable one :)
Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Date: 22 Sep 2003 02:56:10
Message: <557tmvglp91u245am5ajdgd4kilgh8ukei@4ax.com>
On 21 Sep 2003 15:42:38 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> Hi,
> where can I ...
http://news.povray.org/search/?s=html
ABX
Date: 22 Sep 2003 07:00:02
Message: <3f6ed632@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3f6ecdc3@news.povray.org...
> pre {  font-family: "Lucida Console, Arial, Helvetica, sans-serif"; font-size:
normal}
iirc that's pretty shi**y CSS anyway - Lucida Console is the only font that
should be quoted - i.e.:
pre {  font-family: "Lucida Console", Arial, Helvetica, sans-serif; font-size:
normal}
Date: 22 Sep 2003 11:41:49
Message: <3f6f183d@news.povray.org>
Warp wrote:
> And failing all that, it takes "sans-serif" which by definition
> is proportional.
Sans serif is NOT by definition proportional.  Sans serif is by
definition 'without serifs' (you know, those little hooks at the
ends).  Has nothing to do with proportionality.  A fixed-width
font can be sans serif.
