POV-Ray : Newsgroups : povray.general : Re: Softglow example Server Time
27 Jul 2025 10:20:23 EDT (-0400)
  Re: Softglow example (Message 1 to 10 of 14)
Subject: Re: Softglow example
Date: 17 Aug 2003 15:25:52
Message: <Xns93DADA01BDF00raf256com@204.213.191.226>
hua### [at] post3teledk news:3f3fcfc6@news.povray.org
> http://users.skynet.be/bs936509/povfr1/concept1/povfr-gs-pp.htm
(FUT warning)
Interesting, I will try to implement this to SpecFlare[1]. Can POV output
is 16 bit per channel mode? And maybe - to a text file ?
I was suggesting this path some time ago, along with additional chanels,
but it was not welcomed AFAIR...
[1] name may change
Date: 17 Aug 2003 17:12:48
Message: <3f3fefd0$1@news.povray.org>
> Can POV output in 16 bit per channel mode?
Yes, the PNG and PPM file formats allow you to specify an output bit depth
from 5 to 16 bits per channel. This is done via the commandline. The docs
will tell you how to do.
Not to my knowledge, but there's a slow work-around: It's possible to use a
function to evaluate a pixel, and output the info with a loop running over
all the pixels. Beware it's done in SDL and therefore it's slow. It may also
require a two-pass rendering, where you first render the image, and then
start another render that loads the first image and evaluates it... Not so
elegant solution.
By the way, what is a FUT warning?
Hugo
Date: 17 Aug 2003 17:17:47
Message: <Xns93DAECFB0E2BFraf256com@204.213.191.226>
hua### [at] post3teledk news:3f3fefd0$1@news.povray.org
> use a
I realy must find some time one day to implement it :)
Can anybody here help me to start with Pov re-compiling, using
GCC+MinGW+DevCPP platform ?
Date: 18 Aug 2003 02:29:15
Message: <qur0kvogqji2b51vrdjlb63ako6urrr9eb@4ax.com>
On 17 Aug 2003 15:25:52 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> Can POV output is 16 bit per channel mode?
http://www.povray.org/search/?s=Bits_Per_Color
+FP
this become your constant error. patch!
You mean you proposed additional channels before old MegaPOV introduced
postprocessing ?
Please reference that thread. I'm pretty sure the reaction was not related to
subject of patch.
ABX
Date: 18 Aug 2003 02:32:31
Message: <5gs0kvgcm5uftpi61v1kkp3nv5nrp8gpoq@4ax.com>
On 17 Aug 2003 17:17:47 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
You mean POV-Ray for Windows ? At this moment sources of WinPOV are not ready
for compiling with MinGW. MegaPOV 1.1 should be compilable with MinGW.
ABX
Date: 18 Aug 2003 04:54:38
Message: <3F40950D.7020509@informatik.uni-freiburg.de>
There are two versions of ppm. One is pure text, for the other one just the
header is pure text. povray uses the second one. You can convert that to the
first one with pnmtoplainpnm.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 18 Aug 2003 06:01:42
Message: <Xns93DB7A54F34Eraf256com@204.213.191.226>
abx### [at] abxartpl news:qur0kvogqji2b51vrdjlb63ako6urrr9eb@4ax.com
OK, no need to get angry.
> introduced postprocessing ?
Idea is to allow storing of additional informations per pixel in new file
format.
Format would be:
V,W,H
Names
Pixel00;Pixel01;Pixel02;...Pixel0W;
PixelH0;PixelH1;PixelH2,...PixelHW;
V is format version like 100 W=Width H=Height
Names is list of variables names stored for each pixel i.e.
R,G,B
mean that each pixel has standard RGB information ets.
Suggested informations:
R (G,B) - red channel of output pixel 0 - 255
r (g,b) - -||- as float  0.0 - 1.0
R2 (G2,B2) - -||- as 16 bit 0 - 65536
x,y,z      - position of pixel(*) in scene relative to camera
xa,ya,za   - -||- absolute
nf,nt      - normal of surface in that point defined by 2 angles
(*) pixel - in case of AA, or focal blur - this would be the i.e. first
sub-pixel used for computing this pixel
user1,user2,user3 - user date, user can use them in code as additional
pigment or texture data
  pigment { bozo ...
    info { user1 1.0, user2 2.0 }
flags - user falgs - list of flags that are ON for this pixel
  pigment { ...
    flags { backgr, skin }
It would be very usefull for game developers. I will try to create a small
example why would I suggest thist patch in few days.
And to summ it up example of output image:
100,3,3
R,G,B,user1,flags
0,0,255,0,[backgr] 128,0,0,0,[] 0,0,255,0,[backgr]
200,0,0,1,[skin] 200,50,0,2,[skin eye] 200,0,0,1,[skin]
0,0,255,0,[backgr] 128,0,0,0,[skin] 0,0,255,0,[backgr]
and this image describes a hmm monster with in asciiart could look like
  (*)   (an alien "cyclope" with eye in middle)
   A
and image is ready-to-use in game because it stores data about
- hit points for each area (user1)
- background (flags: backgr)
- monster skin where can it be hit (flags: skin)
- monster eye - from where can it attac by his thunders ;) (flags: eye)
Date: 18 Aug 2003 06:10:13
Message: <Xns93DB7BC6948A4raf256com@204.213.191.226>
spa### [at] raf256com news:Xns### [at] 204213191226
>    A
This image would be create by i.e.
global_Settings {
  output_info "R,G,B,user1,flags"
background { rgb z info{user1{0} flags{backgr}}  }
sphere { 0 1 scale 1+x pigment { bozo info{user1{1} flags{skin}} } }
sphere { 0 1 scale 1+y pigment { bozo info{user1{1} flags{skin}} } }
sphere { 0 1 scale  .7 pigment { bozo info{user1{2} flags{skin eye}} } }
Another important usage - user1 etc would be perfect for SpecFlare - then
can pass to it informations i.e. is this point a lightsource (add flare) or
is it only white material.
Date: 18 Aug 2003 06:25:14
Message: <pe91kvsssl0rid9nikg23qupc92hp6arr8@4ax.com>
On 18 Aug 2003 06:01:42 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
I have no idea what suggested you I was angry. I myself made a lot of typos
and grammar mistakes. Probably many in this post :-)
> format.
Rafal, I asked for reference. Can you force yourself to refer to the thread
you mentioned ? I would appreciate if you could continue previous discussion
rather than waste time and space for repeating the same things ? I don't want
again and again repeate arguments like:
  Why ? If you can output it with 16 bit per color resolution in format
  readable for other image manipulation apps why to introduce another file
  format which only duplicates functionality of other formats ?
And please note, you did not proposed patch. You usually imagine/propose
_feature_ and only promise patches :-)
ABX
Date: 18 Aug 2003 06:51:37
Message: <Xns93DB82CB7EB48raf256com@204.213.191.226>
abx### [at] abxartpl news:pe91kvsssl0rid9nikg23qupc92hp6arr8@4ax.com
And my SpecFlar is what, an FPP game ;) ?
Yes it is as separate program. I wrote in only in 3 hourse (one day
including test image screation and render).
I use MinGW and if pov 3.5 can't be yet compiled by it - it's a problem for
me if I want to change pov code.
>   format readable for other image manipulation apps why to introduce
In with format can I store informations about RGB each pixel, is it a light
source and how bright, is this an hit-point of monster for my game, what is
normal of this pixel, how far is it from camera.
It would need about 5 channels.
And yes, this is usefully, if arguemnt about monster in game etc is'nt so
good for graph artistis, I hope a little demo I'm making would be
interesting.
This demo requires RGB + normal FT data, but I will fake it using pov 3.5
in two renders (one for actual RGB, second to gather FT data).
