POV-Ray : Newsgroups : povray.general : texture blurring Server Time
12 Aug 2025 11:11:07 EDT (-0400)
  texture blurring (Message 1 to 10 of 12)
Subject: texture blurring
Date: 20 Jul 2002 07:42:27
Message: <Xns92518ADBA1A4Draf256com@204.213.191.226>
There was question how to blur texture. One suggestion was to make many
textures and translate <> them.
My idea is to use function, but it has limitation - it's good only for
monochrome textures (i think)
Function can be :
#declare f2 = function(_x,_y,_z) {
  #local r=6;  #local sc=0.02;
  #local maxDist = sqrt(r*r*3);
  #local ax=-r; #while (ax<=+r)
    #local ay=-r; #while (ay<=+r)
      #local az=-r; #while (az<=+r)
        fn2(_x+ax*sc,_y+ay*sc,_z+az*sc).gray +
      #local az=az+1; #end
    #local ay=ay+1; #end
  #local ax=ax+1; #end
  0) / pow((r*2+1),3)
where number of samples is (r^3)*2 + 1, and bluring radius is 'sc'.
In this version it is not so good - I want to make universal macro for
bluring, and most important - add gause (or at leaste multiply each sample
by sqrt(ax*ax + ay*ay + az*az)
My problem is - how to make real bluring for r,g,b values ?
Is it possible to use function pigment, but that function will return
color, instead of value passed to color_map ?
Maybe it would be a good idea to implement bluring in POV's code ? Because
my version is so slooow :/
btw. How is pov 3.5 handling macros ? How meany times my formula is parsed
? Once, once per sample or r^2*2+1 times per sample ?
Full source and images are posted to .b.i and .b.s-f
> A jedyne co czytam, ze to terrorysci internetowi z echelonu planuja
> kolejny atak na centrale TPSA
- Expert vel Jacek (obecnie gol### [at] pocztaonetpl)
Subject: Re: texture blurring
Date: 20 Jul 2002 08:08:20
Message: <3D3952B3.2C4C23BA@gmx.de>
You should probably have a look at previous work in that direction:
Subject: proximity/blur pattern finally adjusted
Date: Thu, 07 Mar 2002 08:52:33 +0100
Newsgroups: povray.binaries.images
news://news.povray.org/3k6e8u0g5po4glog938hommr66jr4cu858@4ax.com
http://news.povray.org/3k6e8u0g5po4glog938hommr66jr4cu858@4ax.com
Subject: Smoothly Blurred Patterns - blur2.jpeg (1/1)
Date: Mon, 05 Mar 2001 12:23:44 -0500
news://news.povray.org/chrishuff-DB4B16.12234405032001@news.povray.org
http://news.povray.org/chrishuff-DB4B16.12234405032001@news.povray.org
Subject: Megapov MCP sample (77k)
Date: Sun, 04 Mar 2001 17:42:36 +0100
news://news.povray.org/3AA2707C.CC717FC2@gmx.de
http://news.povray.org/3AA2707C.CC717FC2@gmx.de
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
Date: 20 Jul 2002 08:28:04
Message: <Xns92519296B2688raf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3D3952B3.2C4C23BA@gmx.de
hmm, why nobody mentioned it in news:3d31d9bb@news.povray.org ?
Date: 20 Jul 2002 10:17:25
Message: <3D3970F5.99461D2F@gmx.de>
Probably because everyone thought you could search yourself... :-)
Date: 20 Jul 2002 10:22:29
Message: <Xns9251A5FD16EACraf256com@204.213.191.226>
as far as I understand it, this is for creating pattarn basing on object.
It doesnt allow i.e. to take hexagonal pattern and blur it to get a 'gird'
with soft half-tones. Using function can do it (for monohrome patterns)
this looks like this wat I suggested , but it's a path
Is there sens to make better version of my blur (gauss), or should I rather
wait for author of path finishes it (and maybe include to new PovRay) ?
Date: 20 Jul 2002 10:23:08
Message: <Xns9251A6194D8B5raf256com@204.213.191.226>
news:3D3970F5.99461D2F@gmx.de
me ? I was not asking in this toppic :)
Date: 20 Jul 2002 10:31:46
Message: <3D397451.F5674C70@gmx.de>
Well, that thread was much more specific so nobody mentioned it, but if
you are interested in pattern/pigment blurring in general you could have
searched for it.
Date: 20 Jul 2002 10:34:50
Message: <3D39750A.47BCB03B@gmx.de>
I just meant you might want to have a look how it's implemented there,
esp. the difference between my and Chris Huff's approach.
Date: 20 Jul 2002 11:57:26
Message: <chrishuff-B1D0EA.10522820072002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
You could use 3 functions, one for each channel, and combine them using
an average pigment of 3 pigments. That would get you a blurred pigment
at about 1/3 the speed of a blurred pattern. Using an average pigment
would probably be faster. The only way I can see to blur a texture is to
use an average texture or write a patch.
Some work on that has been done, search through the older messages on
these groups.
I don't see a macro anywhere in that code. Your function is "parsed"
once, running through the #while() loops, and then executed whenever it
is called.
Date: 20 Jul 2002 12:03:20
Message: <chrishuff-BD4C3D.10582120072002@netplex.aussie.org>
One of my posts further into the thread was about generalizing it to
work for any pattern. It isn't blurring textures, but neither is your
approach...it is just blurring the pattern.
The main idea of that patch is to make a "smooth" blur effect that would
be suitable for isosurfaces based on the object pattern. The proximity
pattern was too slow, and other blurring techniques result in a
"stepped" pattern instead of a smooth variation. The method I used was
sort of like a voxel map created on the fly and blurred/interpolated to
give the final blurred pattern. I haven't done any work on it lately,
but I haven't abandoned it either...I'll probably do some more
experimenting with it when the 3.5 source is released.
Not sure what you are asking.
