POV-Ray : Newsgroups : povray.general : Brillouin zones - Voronoi type construct (math/programming) Server Time
18 Aug 2025 12:40:02 EDT (-0400)
  Brillouin zones - Voronoi type construct (math/programming) (Message 1 to 3 of 3)
Subject: Brillouin zones - Voronoi type construct (math/programming)
Date: 21 Oct 2001 17:27:06
Message: <Xns9141BC31BD307sdevetistarca@204.213.191.226>
I'm taking a solid state course, and have been learning about Brillouin
zones. Brillouin zones are simple to construct, but a bit tricky to
visualize.
Imagine you have a repeating lattice of points.
1) Choose one of the points, and measure the distance to all other points.
2) Take the closest points, and draw lines connecting them to the central
point.
3) Bisect each line with a plane (ie: a plane located at the halfway point
and with a normal parallel to the line)
4) The shape enclosed by the planes is the first brillouin zone.
The second brillouin zone is constructed by repeating the process using the
second closest points, and subtracting the first zone. The third is
constructed by using the third closest points and subtracting the first and
second zones, and so forth.
These structures have interesting properties. Every zone has exactly the
same volume as all the others. The bits of every zone can be moved by
integer multiples of the lattice spacing to construct the next lowest zone.
Generally, one can imagine the first zone witohut trouble, but beyond the
second the shapes get too complex to visualize without a computer.
This is what I want POV to do. I think I can construct the Nth zone without
much difficulty if I know the locations of the Nth nearest points, but I
don't know how hard this will be to do. Any ideas?
-- Simon
PS: I think I could do this using some simple C code that generates a data
file, but I'd prefer to do it natively in POV.
Subject: Re: Brillouin zones - Voronoi type construct (math/programming)
Date: 22 Oct 2001 02:11:17
Message: <3BD3B880.E1C823E3@free.fr>
Just keep in mind that the C code will be probably much faster.
I have no idea of how much data you want to generate, though,
so you are the judge.
Adrien Beau   adr### [at] freefr   http://adrien.beau.free.fr/
Date: 23 Oct 2001 07:05:39
Message: <3bd54f03$1@news.povray.org>
without
I wrote the code for Nth Brillouin zones in Fortran (and later in C)
long time (15 years?) ago.  The original purpose of the development
of the isosurface patch was to visualize the Brillouin zones and
Fermi surfaces (=isosurfaces in BZ).
However, it might be difficult to use those data with "isosurface"
in POV-Ray 3.5 because of the lack of "data_*D_*" functions.
Anyway, you can visualize the zones with only POV code.
The below code is an example of Brillouin zones of
fcc crystals. (it's messy, though)
R. Suzuki
// The code
#version 3.5;
#include "functions.inc"
#include "woods.inc"
#declare N_BZ=1;       // n-th BZ     1st - 4th
#declare N_POINTS=200;  // higher value : sharper edge but slower
#declare BT=array[130][3]
#declare AL=array[130]
#declare  BZ=array[12]
#declare L=0;
#declare i=0;
#while(i<3)
  #declare j=0;
  #while(j<3)
    #declare k=0;
    #while(k<3)
         #declare ZZ=0;
         #if (int(i)=1)
          #if (int(j)=1)
           #if (int(k)=1)
             #declare ZZ=1;
             #debug "zero"
         #if (ZZ=0)
              #declare BT[L][0]=-(i-1);
              #declare BT[L][1]=-(j-1);
              #declare BT[L][2]=-(k-1);
              #declare
AL[L]=sqrt(BT[L][0]*BT[L][0]+BT[L][1]*BT[L][1]+BT[L][2]*BT[L][2])*0.5;
              #debug concat(str(AL[L],6,2),str(BT[L][2],6,2),"\n")
              #declare BT[L][0]=BT[L][0]/AL[L]*0.5;
              #declare BT[L][1]=BT[L][1]/AL[L]*0.5;
              #declare BT[L][2]=BT[L][2]/AL[L]*0.5;
              #declare L=L+1;
         #declare k=k+1;
      #declare j=j+1;
    #declare i=i+1;
  #debug "\n"
#declare i=0;
#while(i<2)
  #declare j=0;
  #while(j<2)
    #declare k=0;
    #while(k<2)
              #declare BT[L][0]=-(i-0.5);
              #declare BT[L][1]=-(j-0.5);
              #declare BT[L][2]=-(k-0.5);
              #declare
              #declare L=L+1;
         #declare k=k+1;
      #declare j=j+1;
    #declare i=i+1;
  #debug "\n"
#declare BB=object {blob{
 threshold 1
#declare i=-0.01;
#while (i<(pi*0.5+0.001))
  #declare j=pi*0.25;
  #while (j<(pi*0.5+0.001))
      #declare XX=sin(i)*cos(j);
      #declare YY=sin(i)*sin(j);
      #declare k=0;
      #declare BZ[0]=1e10;
      #declare BZ[1]=1e10;
      #declare BZ[2]=1e10;
      #declare BZ[3]=1e10;
      #while (k<L)
         #declare COSAL= BT[k][0]*XX+BT[k][1]*YY+BT[k][2]*cos(i);
         #declare LENGTH=AL[k]/(COSAL+0.00000001);
         #if (LENGTH>0)
           #if (BZ[0]>LENGTH)
            #declare BZ[3]=BZ[2];
            #declare BZ[2]=BZ[1];
            #declare BZ[1]=BZ[0];
            #declare BZ[0]=LENGTH;
           #else
             #if (BZ[1]>LENGTH)
               #declare BZ[1]=LENGTH;
             #else
               #if (BZ[2]>LENGTH)
                 #declare BZ[2]=LENGTH;
               #else
                 #if (BZ[3]>LENGTH)
                   #declare BZ[3]=LENGTH;
         #declare k=k+1;
      #declare COSAL=BZ[N_BZ-1];
      sphere{<XX*COSAL*2, YY*COSAL*2, cos(i)*COSAL*2> 12/N_POINTS, 1}
      #if (j>pi*0.25)
        sphere{<YY*COSAL*2, XX*COSAL*2, cos(i)*COSAL*2> 12/N_POINTS, 1}
      #declare j=j+pi/N_POINTS;
    #declare i=i+pi/N_POINTS;
     #debug concat(str(i,6,3),"\n")
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1.5, -4.0>
  direction 2.5*z
  look_at   <0.0, 0.5,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.4,0.5,0.35>]
      [0.7 rgb <0.02,0.05,0.1>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare CC=object{
union{
  object {BB}
  object {BB rotate z*90}
  object {BB rotate z*180}
  object {BB rotate z*270}
object{
  union{
    object {CC}
    object {CC scale <1,1,-1> }
  texture{T_Wood4 scale 0.5}
  scale 0.4
  translate y*0.5
  rotate y*-20
// end of the code
