POV-Ray : Newsgroups : povray.general : CAD - > POV Server Time
22 Oct 2026 20:10:37 EDT (-0400)
  CAD - > POV (Message 1 to 9 of 9)
Subject: CAD - > POV
Date: 7 Sep 2002 10:57:46
Message: <928263250pedro.wocka@204.213.191.226>
I work in a beverage manufacturing facility. We recently added a tank farm
-- lots of blending tanks, pumps, pipes & control pods. This particular
area was fully engineered & placed in an AutoCAD drawing (3D) before any
ground was broken.
There were 'after' photos taken of the area, but the ambient [and|or] flash
lighting don't do justice to the thought and labor which was put into this
project.
Rather than calling in a professional photographer, we discussed the
possibility of converting the AutoCAD drawings to POV and creating images
from that.
Before I delve into unknown areas and make promises I cannot keep, I want
to know if there is a particular CAD > POV conversion application anyone
has used with any success? I would prefer to be able to manipulate lighting
and camera positioning (a'la Moray) before export to POV.
A couple of requirements:
Preferbly should support Autocad 2000. If not, I could convert to earlier
version I guess.
Said application should cost $500 (US) or less.
Thanks!
Subject: Re: CAD - > POV
Date: 7 Sep 2002 11:21:45
Message: <3D7A1989.803063B5@gmx.de>
Have a look at:
http://autocad2pov.povray.co.uk/index.html
Date: 7 Sep 2002 16:09:05
Message: <3d7a5ce1$1@news.povray.org>
How about 0 $   ;o)
Hugo
Date: 8 Sep 2002 01:25:02
Message: <web.3d7addf916cfb9d488d4e3910@news.povray.org>
>ground was broken.
>project.
>from that.
>version I guess.
>Thanks!
The autocad2pov looks like the keep it simplist approach.
I don't have experience with it as I use Pro Engineer (is there a proE2pov )
and then the 3rd party software of Ultimate Unwrap at
http://www.unwrap3d.com/
Recently Brad Bolthouse added a plugin ( I guess he owns the joint) to
accomadate POVRAY users.  Below is an excerpt from his news letter...
"The POV-Ray plugin has been updated to support the newly released
POV-Ray v3.5 rendering engine, which now supports UV mapping.
When exporting your model as mesh2, a POV file and a INC file
are created.
His software can open dxf files among a number of other formats (I'm forced
to save as 3dpaint), he charges very little for it.  He also maintained me
(high maintance) with problems I was having.
You also have the option of using his software for UV mapping which I
believe is what most would use Ultimate Unwrap for.
Tony
ton### [at] xenomechanicscom
Date: 8 Sep 2002 08:13:28
Message: <92834CDB4pedro.wocka@204.213.191.226>
hua### [at] post3teledk (Hugo) wrote in <3d7a5ce1$1@news.povray.org>:
>How about 0 $   ;o)
>Regards,
>Hugo
Thank you all. I'm going to give both AutoCAD2POV and Unwrap3D (mentioned in
another followup) a try.
Date: 9 Sep 2002 09:21:44
Message: <3d7ca068@news.povray.org>
> Have a look at:
download page seems to be broken, or at least it doesn't work for me, here's
what i get:
Microsoft VBScript runtime error '800a0046'
Permission denied
/acad2pov.asp, line 7
Date: 10 Sep 2002 02:30:42
Message: <3d7d9192@news.povray.org>
there's somewhere a tool called "slp2pov". As the name says it could only
work with slp files.
Or export your models as obj files and use "objupov" or another Wavefront
converter.
HTH,
Patrik
"Tony LaVigne" <ton### [at] xenomechanicscom> schrieb im Newsbeitrag
news:web.3d7addf916cfb9d488d4e3910@news.povray.org...
farm
> >ground was broken.
flash
this
> >project.
> >from that.
lighting
> >version I guess.
> >Thanks!
proE2pov )
> are created.
forced
> Tony
Date: 10 Sep 2002 03:21:02
Message: <3D7D9E4E.D95C8845@pacbell.net>
"Patrik Müller" wrote:
> Hi,
http://www.geocities.com/SiliconValley/Pines/3014/proe.html
Ken Tyler
Date: 17 Sep 2002 15:39:42
Message: <3d8784fe@news.povray.org>
Fixed now!  Thanks.
"francesco" <fra### [at] molilliorg> wrote in message
news:3d7ca068@news.povray.org...
> > Have a look at:
here's
> what i get:
> Permission denied
