POV-Ray : Newsgroups : povray.general : Announce: 3DWin 4.1, a 3D file format converter Server Time
6 Nov 2026 00:32:19 EST (-0500)
  Announce: 3DWin 4.1, a 3D file format converter (Message 1 to 21 of 21)
Subject: Announce: 3DWin 4.1, a 3D file format converter
Date: 15 Jul 2000 03:05:11
Message: <9130nsgao5vba7ft76lltf2q13330gbl3a@4ax.com>
this program is a small utility to view and convert 3D
files to a number of other 3D formats. Beside well known
features from V3.5 now full material conversion is supported.
3DWin is available at
	http://www.stmuc.com/thbaier/tools.html
What's new:
  * 3dto3d engine supports now solids like sphere, cylinder etc
  * Protein Data Bank (*.pdb) import
  * bug in OpenGL export fixed
  * Batch import (registered version only)
The Basics:
  * running unter Win95/98/NT4/W2K
  * easy installation
  * plugin architecture
  * updates via support web page.
  * clear and comfortable userinterface
  * full help support
  * robust and fast conversion routines
  * reliable handling of larges scenes
  * detailed statistics about conversion process
  * supports polygon meshes including normals and uv vectors
  * supports light and camera conversion
  * supports material and image map conversion (registered version
only)
   Import:
   	Generic ASCII format (*.raw)
   	3dStudio (*.3ds, *.prj)
   	Lightwave (*.lwo, *.lws)
	Autodesk (*.dxf)
	WaveFront (*.obj)
   Export:
   	3dStudio (*.3ds, *.asc)
   	Lightwave (*.lws, *.lwo)
   	Autodesk (*.dxf)
   	VRML 1.0/2.0 (*.wrl)
   	POV-Ray and Moray (*.inc, *.udo)
	WaveFront (*.obj)
	OpenGL (*.C)
	Renderman/BMRT	(*.rib)
	Lightflow	(*.py)
© by Thomas Baier 2000
Subject: Re: Announce: 3DWin 4.1, a 3D file format converter
Date: 16 Jul 2000 15:36:42
Message: <39720eca@news.povray.org>
Hmm .. recently noticed that I can't load a lightwave-R6-Object
Is there a incompatibility between earlier versions ???
PS: I'm still using v3.5 of 3DWin ... is this the reason ???
(Should I update ???)
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Date: 17 Jul 2000 00:32:06
Message: <2q25ns8hmnrrinhk209ivvv1qeh72cbh56@4ax.com>
On Sun, 16 Jul 2000 21:40:08 +0200, "Jan Walzer"
<wal### [at] informatikuni-hallede> wrote:
3.5 and V4 do not have support for LW6 but it is on my todolist :-))
-tb
Date: 17 Jul 2000 15:26:45
Message: <39735df5@news.povray.org>
Is there another way to do this ??? How can I get my LW6-Mesh
into Moray (or POV)?
Date: 17 Jul 2000 15:40:15
Message: <39735FC2.624E0059@pacbell.net>
There probably is no way to do so unless you have LW6 and it
can export to a different 3D file format that 3DWin supports
such as .dxf, .3ds, .obj....
Date: 17 Jul 2000 16:31:46
Message: <39736d32@news.povray.org>
hmm... I thought so ... :-(
Date: 20 Jul 2000 15:37:40
Message: <39775504@news.povray.org>
I'm having some difficulty exporting a Moray .udo/.inc.  The only export
format I can find is .pov.   Am I doing something wrong?
"Thomas Baier" <NOS### [at] stmcucom> wrote in message
news:9130nsgao5vba7ft76lltf2q13330gbl3a@4ax.com...
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 20 Jul 2000 15:58:10
Message: <397759d2@news.povray.org>
Never mind, I just found the checkbox.  Thanks anyway.
"Dennis McDaniel" <hyp### [at] yahoocom> wrote in message
news:39775504@news.povray.org...
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 20 Jul 2000 18:17:54
Message: <39777a92@news.povray.org>
Okay, I checked all of the options and still can't find an answer to my
problem.  I can create the .udo/.inc and import the .udo into Moray, and
assign it a material--but it just won't render.  HELP!
TIA
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 21 Jul 2000 00:38:07
Message: <ukkfnskh7m502rf0tck1giasgrbd1od4i2@4ax.com>
On Thu, 20 Jul 2000 15:16:40 -0700, "Dennis McDaniel"
<hyp### [at] yahoocom> wrote:
be sure to select the right POV-Ray version. It wold be good, if you
download Mega POV with UV support.
-tb
>TIA
>Hi,
>What's new:
>The Basics:
>  * easy installation
>  * full help support
>only)
>   Import:
>Autodesk (*.dxf)
>WaveFront (*.obj)
>   Export:
>   Autodesk (*.dxf)
>WaveFront (*.obj)
>OpenGL (*.C)
>Lightflow (*.py)
Date: 21 Jul 2000 11:03:32
Message: <39786644$1@news.povray.org>
OK, this is a dumb question... but what is UV? I'm pretty sure it isnt Ultra
Violet...
Alan
news:ukkfnskh7m502rf0tck1giasgrbd1od4i2@4ax.com...
> Hi,
> -tb
> >TIA
> >Hi,
> >What's new:
> >The Basics:
> >  * easy installation
> >  * full help support
> >only)
> >   Import:
> >Autodesk (*.dxf)
> >WaveFront (*.obj)
> >   Export:
> >   Autodesk (*.dxf)
> >WaveFront (*.obj)
> >OpenGL (*.C)
> >Lightflow (*.py)
Date: 21 Jul 2000 12:45:33
Message: <39787D57.5B1BA277@inapg.inra.fr>
> Violet...
u and v are the names of the coordinates used to map a 2D texture on the surface
of a 3D object.
G.
Date: 21 Jul 2000 16:05:02
Message: <MPG.13e191c7e1bae367989761@news.povray.org>
On Thu, 20 Jul 2000 15:16:40 -0700, Dennis McDaniel wrote...
> TIA
I suppose you've made sure that you moved both the .udo and the
corresponding .inc into you moray for windows/udo directory?
Have you created a light source?
Is the light source outside the object?
If yes to all the above, then I pass.
Bye for now,
     Jamie.
Date: 21 Jul 2000 16:59:59
Message: <3978b9cf@news.povray.org>
Thanks for the suggestions, but yes, I've tried them all already.  In fact,
I checked the message window in POV-Ray, and it says it can't find one of
the .inc files.  But I've checked and everything is where it's supposed to
be (\udo).  Go figure?!?
Dennis
"Jamie Davison" <jam### [at] dh70qdu-netcom> wrote in message
news:MPG.13e191c7e1bae367989761@news.povray.org...
> TIA
Bye for now,
     Jamie.
Date: 21 Jul 2000 17:04:55
Message: <3978baf7@news.povray.org>
I downloaded Mega' (is that different than Mega' with UV support?) and it
made no difference.  The POV message windows says it can't find one of the
.inc files, but it's in the \udo directory with the .udo.  Any other
suggestions?  It's killing me because I can see my model in the scene (which
renders btw when I delete the UDO object) but can't get it to render.  I
used SolidWorks to build the model then exported a .wrl, took that into
Crossroads, exported a .3ds (also tried .dxf and .raw) and then used 3DWin
to create the .udo/.inc's.  Whew!  No wonder I'm tired.  Thanks for all of
your help.
Dennis
-tb
>TIA
>Hi,
>What's new:
>The Basics:
>  * easy installation
>  * full help support
>only)
>   Import:
>Autodesk (*.dxf)
>WaveFront (*.obj)
>   Export:
>   Autodesk (*.dxf)
>WaveFront (*.obj)
>OpenGL (*.C)
>Lightflow (*.py)
Date: 22 Jul 2000 02:16:13
Message: <t3einskhgnjr0pn87t8rn716351npv0k1t@4ax.com>
On Fri, 21 Jul 2000 14:03:38 -0700, "Dennis McDaniel"
i asume that your converted files renders well if go with provray
directly. V4.2 will include a version statement to enable mesh2
features in the current MegaPov version.
If you want to use your 3DWin output with Moray you have to do some
things:
enable udo/mdl output during POV-Ray export.
copy *_p.inc, *_m.inc and *_o.inc to Moray\PovScen
copy all images to Moray\PovScen
copy *.mdl to Moray\mdl
copy *.udo to Moray\udo
start Moray and load your mdl file.
Press F9 to render.
Thatīs it.
-tb
>your help.
>Dennis
>Hi,
>-tb
>>TIA
>>Hi,
>>What's new:
>>The Basics:
>>  * easy installation
>>  * full help support
>>only)
>>   Import:
>>Autodesk (*.dxf)
>>WaveFront (*.obj)
>>   Export:
>>   Autodesk (*.dxf)
>>WaveFront (*.obj)
>>OpenGL (*.C)
>>Lightflow (*.py)
Date: 22 Jul 2000 17:51:26
Message: <397A173F.A65AF062@softcom.net>
Thanks for the suggestions.  Now I can get it to render, but it will only use the
default material.  Is this the function of the *_m.inc file?  I tried exporting
again and unchecking materials in the options dialog.  This still renders, but
doesn't display the imported object--as if it has an invisible texture (i.e. no
"missing material" message).  So near and yet so far.  BTW, how close on the
Moray plug-in (he asked wearily)?  Also, being that 3D-Win will be shareware, how
much will it cost (US$).
Thanks again.
> Hi,
> things:
> Press F9 to render.
> Thatīs it.
> -tb
> >your help.
> >Dennis
> >Hi,
> >-tb
> >>TIA
> >>Hi,
> >>What's new:
> >>The Basics:
> >>  * easy installation
> >>  * full help support
> >>only)
> >>   Import:
> >>Autodesk (*.dxf)
> >>WaveFront (*.obj)
> >>   Export:
> >>   Autodesk (*.dxf)
> >>WaveFront (*.obj)
> >>OpenGL (*.C)
> >>Lightflow (*.py)
Date: 23 Jul 2000 01:15:03
Message: <8nvkns4bga1093urqo06d4krgq698nvlv5@4ax.com>
On Sat, 22 Jul 2000 14:50:55 -0700, Dennis McDaniel
<dmc### [at] softcomnet> wrote:
If you need texture conversion then you should register 3DWin. The
demo supports only a default material, as mentioned on my page.
-tb
>Thanks again.
>> Hi,
>> things:
>> Press F9 to render.
>> Thatīs it.
>> -tb
>> >your help.
>> >Dennis
>> >Hi,
>> >-tb
>> >>TIA
>> >>Hi,
>> >>What's new:
>> >>The Basics:
>> >>  * easy installation
>> >>  * full help support
>> >>only)
>> >>   Import:
>> >>Autodesk (*.dxf)
>> >>WaveFront (*.obj)
>> >>   Export:
>> >>   Autodesk (*.dxf)
>> >>WaveFront (*.obj)
>> >>OpenGL (*.C)
>> >>Lightflow (*.py)
Date: 23 Jul 2000 01:19:38
Message: <i00lns42ca68t4f8pd8f03qiu99s3aonpv@4ax.com>
35 EURO.
-tb
Date: 26 Jul 2000 14:52:21
Message: <397f3365$1@news.povray.org>
Thomas Baier <NOS### [at] stmcucom> wrote in message
news:i00lns42ca68t4f8pd8f03qiu99s3aonpv@4ax.com...
> Hi,
> 35 EURO.
> 1 Euro dollar=1US dollar AFAIK
Steven
Date: 27 Jul 2000 04:13:27
Message: <397fef26@news.povray.org>
In moray.win Steven Durham <ste### [at] earthlinknet> wrote:
:> 1 Euro dollar=1US dollar AFAIK
  1 Euro = 0.9423 US Dollar
Date: 22 Jul 2000 14:31:08
Message: <1cqjns0ar0l6s9untj2gocnpsnbknts6sf@4ax.com>
Hi Dennis McDaniel, you recently wrote in moray.win:
Have you done a View|Dependancies? If that command pops up message
boxes about missing files, then that's the problem. Just follow the
screen instructions to let Moray know where the files are.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 22 Jul 2000 18:03:08
Message: <397A19FD.FA816896@softcom.net>
Lutz,
Yes, I checked the references, and their all in place.  However, as I mentioned
to Thomas only slightly earlier in this thread, the problems I'm having now are
with a *_m.inc file which I believe is a material file created in 3D-Win.  Per
his suggestion, I moved the *_m.inc, the *_o.inc, and the *_p.inc files to the
\povscn directory and I was able to render the part.  However, it only renders
with the default white texture despite what I assign it in Moray.  If I export
the part from 3D-Win with the materials option unchecked (this doesn't create a
*_m.inc file), then it renders the scene, but without the .udo object displayed.
I don't get any missing materials errors, it just renders without the object.
Any suggestions?
By the way, Lutz.  I just want to tell you how much I enjoy using Moray.  I am a
mechanical designer and use a $4000 CAD program (SolidWorks 2000) every day.  But
I still sit down in the evenings and use Moray and POV-Ray for recreation.  Keep
up the good work.  Is there any way you could post on your website what we might
expect from the next version?
Thanks again, Lutz.
> - Lutz
Date: 22 Jul 2000 18:18:20
Message: <397A1E2D.6397106B@yahoo.com>
Dennis,
I have found exactly the same thing... rendering a "white android".. see a post of
mine in the POVray.general group.  I suspect that we are both using the demo register
key version and that the material/UV mapping feature is turned off even though the
options are apparently there in the interface. The release notes does state that
material import is only available in the registered version. I looked inside the
various include files generated and the UV data seems to be missing too.
My problem is that I really need to see the material import working to decide if I
want to register this program. The free earlier versions already import UDOs as one
mesh with no texture. I'm poor and I don't have the $40 or so to register just to see
if it works.
Dennis McDaniel wrote:
> Lutz,
> Any suggestions?
> Thanks again, Lutz.
> > - Lutz
