POV-Ray : Newsgroups : povray.general : please confirm ... Server Time
17 Aug 2025 03:32:35 EDT (-0400)
  please confirm ... (Message 1 to 4 of 4)
Subject: please confirm ...
Date: 23 Feb 2002 16:59:57
Message: <8JPUA55t4xB@lzer.net>
If I render a (Widescreen[1]-)Image ...
... with a resolution of 3840x1024 ...
... and this image renders at a rate of 1PPS (dooh ... it increased in the
    last line, it startet the hard part[3] with 26PPM)
... and I still have 500 lines to do ...
... this will take a loooong[2] time ?
I think about halting the pic and continuing with more conservative[4] AA-
settings ...
[1] I'm rendering a wallpaper, that fits in my multimon-environment[5]
[2] just a short calculation: 3840 Px/line means ~1 line/h ...
    ... meaning >~500h ... meaning .... oh my god ...
[3] a ground-plane with (fresnel)reflection blur, a crackle(metric 1)-
pigment wich is reflecting a quite complex TTF with fade-color.
[4] +AM2 +AA0.3 +R4
[5] (3x 1280x1024)
[6] /me likes to write footnotes ...
[-1] Error: footnote overflow
Subject: Re: please confirm ...
Date: 23 Feb 2002 17:07:09
Message: <3C781295.CE27174E@gmx.de>
I would confirm that you must have done either:
...something weird in your scene which takes forever to render[1]
...something wrong in your scene which could be made better[2]
But that's hard to say with no source-code...
[1] too many merge's where union is sufficient, stacked-planes, area_lights?
[2] too large container objects for isos or medias?
Tim Nikias
Date: 23 Feb 2002 17:50:14
Message: <8JPUG1tO4xB@lzer.net>
Yes
Probably
will follow when image is ready ...
no merge, only csg is one union of 80000 rounded-cubes(which of course are
again unions). I presume that the automatic bonding worked quite well, as
this object is already done computing
no isos, no media, for bounding look at answer_of([1]).
the time-consuming part is the ground-plane, which uses fresnel-
reflection-blur[23] ...
above this plane there is a TTF-Object, scaled z*200 (away from Cam) and
"filled" with fade-color ... so all intersections of the font have to be
computed ...
furtermore there are also 2 ground-fogs defined ...
but what the heck ... raytracing is no fun, unless pps < 5 (hey...
currently I have 100ppm)
[23] I only set 16 layers ...
Date: 24 Feb 2002 03:24:43
Message: <3C78A355.50AD849@gmx.de>
Perhaps your computer's specification would solve the riddle, because
what you seem to have in your scene could be "worse"...
Well, I'm seeing forward to see the result!
Tim Nikias
