POV-Ray : Newsgroups : povray.general : realistic rendering in pov Server Time
26 Oct 2026 20:25:39 EDT (-0400)
  realistic rendering in pov (Message 1 to 24 of 24)
Subject: realistic rendering in pov
Date: 24 Jun 2000 20:34:59
Message: <8F5DD1EBDdashixpressnet@204.213.191.228>
anyone have any tips/pointers/urls/include files or anything to help with
photorealistic rendering in pov-ray? I can't seem to get my images to that
level of quality, the best I have done so far is (
http://daishi.50megs.com/glass_thingie.html )
which took 85+ hours to render on my PIII733 (most likely cause of all the
tiny groves and high AA I had to use to get rid of the 'jaggies' )
thanx in advance
Subject: Re: realistic rendering in pov
Date: 25 Jun 2000 01:06:40
Message: <39559360@news.povray.org>
Perhaps one of the most smooth renderings I've seen.
I can't believe a 85 hour render time with a 733MHz cpu, incredible just for
this one object.  Not a good commercial for the notebook (slower than
desktops/towers anyway) computer I have in mind.
I really don't understand you thinking this lacks photorealism so I can't
point anything out myself.
The web page tutorials I've seen are usually about getting the basics learned,
not photorealism.  There's even the 3 light rule type stuff but I don't think
of that as having to do with such a thing.
"daishi" <das### [at] x-pressnet> wrote in message
news:8F5DD1EBDdashixpressnet@204.213.191.228...
| thanx in advance
Date: 25 Jun 2000 01:45:35
Message: <39558E98.A582DAC3@peak.edu.ee>
What makes an image appear realistic? Obviously, the objects have to be modelled
as accurately as possible; but this is not enough. Other very important
considerations are texturing and lighting - not necessarily in that order. The
actual methods vary greatly, depending on the type of scene.
Some scenes are more dependent on advanced lighting (radiosity for indoor
scenes, reflections and caustics for glass objects and polished surfaces, etc),
some require complex texturing (e.g. natural surfaces like organics and
minerals).
One thing to consider: there is often a difference between what _is_ realistic
and what is _perceived_ as realistic. For example: a common complaint about
computer-generated images is "too sterile". This preconception is so strong that
subtly exaggerating the "dirtyness" of the scene can in fact increase the
apparent realism of an image.
As for pointers: one excellent learning recource is the website of the Internet
Raytracing Competition (http://www.irtc.org).
You can find some amazing works there. Many of them have the source files
available for download (although not all are created in POV-Ray). Some also give
a detailed description of the creation process.
Margus Ramst
Date: 25 Jun 2000 13:48:49
Message: <8F5E81EECdashixpressnet@204.213.191.228>
well I think the shadows looked to washed out personlly, and cause of the
insane render time its not really worth it to me to go back in and re-tweak
the area light
per### [at] aolcom?subject=PoV-News: (Bob Hughes) wrote in
<39559360@news.povray.org>:
>for this one object.  Not a good commercial for the notebook (slower
>than desktops/towers anyway) computer I have in mind.
>can't point anything out myself.
>learned, not photorealism.  There's even the 3 light rule type stuff but
>I don't think of that as having to do with such a thing.
>Bob
>| with photorealistic rendering in pov-ray? I can't seem to get my
>| images to that level of quality, the best I have done so far is
>| the tiny groves and high AA I had to use to get rid of the 'jaggies' )
>| thanx in advance
Date: 25 Jun 2000 13:51:50
Message: <8F5E87751dashixpressnet@204.213.191.228>
hmm, maybe some post-processing of the final image to give it that 'grainy
photographic quality'? (I don't think you can do this in pov can you?)
I know about the IRTC stuff, but a lot of the images aren't what I would
consider photoquality. I guess I'll just have to go sorting through the
image and see what people have done (and mess with radiosity)
thanks for the advice
mar### [at] peakeduee (Margus Ramst) wrote in
<39558E98.A582DAC3@peak.edu.ee>:
>modelled as accurately as possible; but this is not enough. Other very
>important considerations are texturing and lighting - not necessarily in
>that order. The actual methods vary greatly, depending on the type of
>scene. Some scenes are more dependent on advanced lighting (radiosity
>for indoor scenes, reflections and caustics for glass objects and
>polished surfaces, etc), some require complex texturing (e.g. natural
>surfaces like organics and minerals).
>realistic and what is _perceived_ as realistic. For example: a common
>complaint about computer-generated images is "too sterile". This
>preconception is so strong that subtly exaggerating the "dirtyness" of
>the scene can in fact increase the apparent realism of an image.
>Internet Raytracing Competition (http://www.irtc.org).
>files available for download (although not all are created in POV-Ray).
>Some also give a detailed description of the creation process.
Date: 26 Jun 2000 07:50:35
Message: <395735A6.FC48933C@peak.edu.ee>
Well, MegaPOV has post-process ability, although I don't think a suitable filter
has been implemented currently. But what I mainly meant was exaggerating
imperfections in textures and object arrangement.
Margus Ramst
Date: 26 Jun 2000 14:27:31
Message: <chrishuff-306775.13320126062000@news.povray.org>
In article <395735A6.FC48933C@peak.edu.ee>, Margus Ramst
<mar### [at] peakeduee> wrote:
> > 'grainy
> suitable filter has been implemented currently. But what I mainly
> meant was exaggerating imperfections in textures and object
> arrangement.
Using the add, subtract, multiply, and divide post_process filters with
noise_pigment should work fine...however, you either need a Mac or the
ability to compile the MegaPOV+ code yourself.
Date: 26 Jun 2000 16:40:10
Message: <3957C07D.ACCDCC57@yahoo.com>
there are two books i want to get about photorealism in 3d that got
really good reviews.  both are platform and application independant.  i
can't recall the exact titles off the top of my head, but i believe the
first was simply, "3d photorealism" and the second was "advanced 3d
photorealism" both by the same guy.
  i think the main thing one needs for photrealism is composition.  for
example, my house is by no means messy, but at the same time, i haven't
placed my coffee table exactly perpedicular to the walls.  it's off a
little due to human error and the fact it gets bumped around sometimes.
pictures aren't hung on the walls exactly straight, table arrangements
aren't exactly centered, magazines aren't stacked perfectly, there is
fabric on various items that doesn't lay uniformly (hard to do in pov),
and there is simply a lot of stuff and modelling them all would be hard
to do.  even hardback books don't stand completely upright unless they
are squeezed in tight.  starting to see what i mean?  in fact, i think
this is the area that povers need to work on the most.
  the next main thing is textures.  this is very difficult to do in
pov.  i'm not sure why.  i mean, other packages come with all kinds of
nifty textures that are perfect to use 'off the shelf', but povers have
a heck of a time (myself included) finding textures that are even close
to the right thing.  and i'm not sure if that is a fault of the user, or
of the application.  but it seems to me that it shouldn't take hours or
days to find one texture good enough to be photorealistic (like battle
damage on a spaceship).  the best solution i have seen in pictures is
the use of image maps.  gilles' and h.e.day's best pics use them a lot.
this gives the user control over exactly how something looks, but it
requires the person to be proficient in a paint program.  it also (in my
opinion) precludes the option of making a group of the same object, each
with a unique look (like the battle damage i'm still looking for).  it
may be that pov simply needs to find out how other apps do their 3d
textures and see if any can be incorporated into pov.
  i think someone mentioned modelling as another point, but that seems
pretty obvious and it is the easiest thing to work on and finish to
satisfaction.
  your pic looks good.  maybe what you could have used is something
behind the picture, but in front of the light to cast soft shadows, or
use a table instead of a plane, or choose a background color more the
color of a neutral wall color.  or you could have put it on a pedestal
or in a wall niche like in a museum; something to give it a location and
not mak it look like it is just a piece of glass on some eternal plane.
hope some of this helps and good luck.
> thanx in advance
Date: 26 Jun 2000 23:52:41
Message: <39581D9A.2970@pacbell.net>
The books you are thinking about are by Bill Fleming. At this time he
has three out:
3D Photorealism Toolkit
Advanced Photorealism   ( This one I can't find at the momentl, so I am
not sure of the title. )
3D Modeling & Surfacing
I have all three and recomend them without reservation. They are a
little expensive but well worth the price.
Ken Matassa
Date: 27 Jun 2000 00:04:42
Message: <8F5FF9AABdashixpressnet@204.213.191.228>
the main problem with 3d in general is that the scene/textures/anything are
to 'perfect' (most of my scenes I do do in 'hyper realism' though. its only
a few times I like to get the less then perfect 'real world')
for textures, noise is your friend. one thing I think pov could use is
fractal noise, this seems to be better then the other types of noise imo
also a fully extensible shading language ala renderman wouldn't hurt either
I was only trying to get the vase thing to look photorealistic. I think one
of the problems might be is that the vase was just a massive triangle mesh
(exported from rhino). I can't see anyway to construct it nativly in pov
(and I wouldn't either, I do all my modelling in rhino these days)
I still say the shadows are to washed out. maybe some day I'll retweak them
, after I purchase that dual ghz comp :)
rco### [at] yahoocom (ryan constantine) wrote in
<3957C07D.ACCDCC57@yahoo.com>:
>satisfaction.
>> images to that level of quality, the best I have done so far is (
>> thanx in advance
Date: 27 Jun 2000 00:48:45
Message: <39583140.7C651A21@pacbell.net>
Sors, Lathes, Prisms, While Loops, and CSG are our friends. They
can help you make some very realistic vases without having to
resort to a triangle mess.
Date: 27 Jun 2000 02:44:32
Message: <39584DF5.DC57877D@aetec.ee>
ryan constantine wrote:
[Good advice]
I'd add illumination as one of keywords for realistic rendering: it can
make otherwise average picture outstanding (and vice versa, of course).
Date: 27 Jun 2000 04:04:53
Message: <39586025@news.povray.org>
daishi <das### [at] x-pressnet> wrote:
: I can't seem to get my images to that
: level of quality
  I know the feeling...
Date: 27 Jun 2000 11:42:57
Message: <chrishuff-854CFC.10425827062000@news.povray.org>
In article <8F5FF9AABdashixpressnet@204.213.191.228>, das### [at] x-pressnet
> scene/textures/anything are to 'perfect' (most of my scenes I do do
> in 'hyper realism' though. its only a few times I like to get the
It might be interesting to make two versions of an image: one which goes
into a lot of very tiny details but is "perfect", for example, having
books on a shelf perfectly aligned, papers on a table in a stack
centered in the middle, etc, as well as a real-world version with the
same level of detail but with randomness and noise introduced into the
scene: knots in wood panels, leaning books, scattered pens/pencils,
smudges of dirt and dust, etc.
The granite and wrinkles patterns are examples of fractal noise, as well
as the turbulence warp, etc. In MegaPOV, you also have Ridged and Hetero
Multifractals, and can make fractal noise patterns with the function {}
pattern.
> either
There is someone working on a shader patch...it isn't a simple addition,
however.
Date: 27 Jun 2000 11:54:44
Message: <3958CEE1.25F2E13@aetec.ee>
> however.
I've heard this too ;-)
But creating this patch is only half of problem, other part would be
creating of useful shaders. If I look into BMRT shaders, then I can't
imagine, how they are created. (Only idea is that someone throw
expressions into shader source code, massaged it long enough to compile
and then looked to output ;-)
If I manage to get enough time for reading "Texturing and Modeling",
(which is waiting in bookself), then perhaps I get better idea of
procedural shaders...
Date: 27 Jun 2000 11:55:30
Message: <3958ce72@news.povray.org>
news:8F5FF9AABdashixpressnet@204.213.191.228...
are
only
I seem to remember coming across a tutorial/general discussion about making
scenes realistically dirty and disorganised. The main example was a render
of a workbench, but I can't track the link down in pov links (Ken?). Anyone
know the link I'm after? (Ken?).
Maybe Ken will know. (Ken?).
BTW Could Ken distribute signal watches, like Superman gave to Jimmy and
Louis?
Date: 27 Jun 2000 12:04:26
Message: <slrn8lhkqn.tul.ron.parker@linux.parkerr.fwi.com>
>are
>only
It's gone.  It was at serious3d.com, but they had some financial troubles
or something and are no more.  The tutorial you're thinking of was written
by Bill Fleming, whose home is at http://www.komodostudio.com/ .  He has
info there on his various books on photorealism, one of which is an
expanded version of the article you remember.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 27 Jun 2000 12:05:34
Message: <3958CFDE.8294C906@pacbell.net>
It was from a book written by Bill Flemming.
> Anyone know the link I'm after? (Ken?).
I know the link but the site is no longer available so it would do
you no good.
I know.
> Louis?
Pagers are cheaper and more redily available.
Date: 27 Jun 2000 12:08:32
Message: <slrn8lhl2e.tul.ron.parker@linux.parkerr.fwi.com>
Whoops, guess it's not gone.  It's just moved.  Try
http://mastering3dgraphics.com/public/freestuff/tutorials/general/
Date: 27 Jun 2000 12:29:01
Message: <3958d64d@news.povray.org>
take a look at http://www.3dluvr.com/marcosss/morearni/ - view the one in
the middle - the little guy with the gun - this was the most realistic
rendering I have seen
> thanx in advance
Date: 27 Jun 2000 12:29:52
Message: <3958d680$1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] linuxparkerrfwicom...
Many thanks. Bill's stuff is amazing.
Date: 27 Jun 2000 13:04:44
Message: <8F608DDFEdashixpressnet@204.213.191.228>
the vase itself isn't the problem
its all the little grooves
I could approximate it possibly by making lots of tiny cylinders and having
those copyied along a spline path. it would be more work then its worth
though..
also it wouldn't be as accurate as the rhino model
lin### [at] povrayorg (Ken) wrote in <39583140.7C651A21@pacbell.net>:
>> think one of the problems might be is that the vase was just a massive
>> triangle mesh (exported from rhino). I can't see anyway to construct
>> it nativly in pov (and I wouldn't either, I do all my modelling in
>> rhino these days)
Date: 27 Jun 2000 18:39:15
Message: <39592d13@news.povray.org>
That is a very long render time. Did you use photons?
Seems to me that the single most important aspect of a quality
photorealistic rendering is how the lighting is set up. I saw an excellent
example on lighting and postprocessing at this location:
http://3drender.com/jbirn/ea/Ant.html
It is very brief but pictures say alot and you can glean ideas from such
articles.
If you master this sort of thing then you can render excellent
photorealistic pictures of fake-looking objects with fake-looking textures!
Date: 27 Jun 2000 19:46:52
Message: <8F60C829Adashixpressnet@204.213.191.228>
no photons, just 1 area light and a point light (acting as a fill light)
hha### [at] capitalnet (Halbert) wrote in <39592d13@news.povray.org>:
>excellent example on lighting and postprocessing at this location:
>articles.
>textures!
