In the scene below, try all four locations. In the first all is
ok, the second gives a black image. The third is ok again and
the fourth is missing the sphere.
Why does this happen?
light_source{<500,500,-500> rgb 1}
camera{
location < 0.0, 0.0, -0.47>
//location < 0.0, 0.0, -0.46>
//location < 0.0, 0.1, -0.46>
//location < 0.0, 0.1, -0.45>
look_at 0
angle 90
orthographic
sphere{0.2*y,0.2 pigment{rgb 1}}
cylinder{0,-0.5*y,0.2 pigment{rgb<1,0,0>}}
Ingo
Pov-Ray : http://members.home.nl/seed7/
I think you have the camera too close for one thing, the orthographic type
really always should have the 'up' and 'right' keywords in there to specify
the scene dimensions. Of course the default should make for a 4/3 wide by 1
high view, so the objects not appearing whole or not at all must be related
to the close proximity is going to be my guess anyway, without actually
rendering and testing.
Well, I just can't resist trying it out. Tried it. Nothing wrong with any
of the four viewpoints. What version POV-you have there? I used 3.1g for
Win.
ingo <ing### [at] home nl> wrote in message
news:8E8### [at] 212 120 113 81...
> camera{
> file://location < 0.0, 0.0, -0.46>
> file://location < 0.0, 0.1, -0.46>
> file://location < 0.0, 0.1, -0.45>
> look_at 0
> angle 90
> orthographic
> Ingo
> Photography: http://members.home.nl/ingoogni/
>orthographic type really always should have the 'up' and
>'right' keywords in there to specify the scene dimensions.
Adding "up" and "right" changes noting in the result.
I want a close-up of the sphere and cylinder toutching. But for
every "angle" there seems to be a "location" beyond witch things
get messed up :(
>wrong with any of the four viewpoints. What version POV-you
>have there? I used 3.1g for Win.
POV-Ray 3.1g.msvc.win32, Superpatch, UV-Patch, Minipatch.
I have no watcom compiles anymore to test it on.
Running NT4 & SP6.
Ingo
Back again.
The viewpoints do all show a white sphere on top of a red cylinder here. No
problems. Besides this, I wondered about the placement of keywords within
your camera statement. 'angle' being removed makes a difference, as does
also the order of 'orthographic' and I always put it before the 'location'
and 'look_at' (very first thing in camera), and seems to be correct there.
With yours it is much different and apparently not based any longer on up
and right keywords either, maybe even not functional at all placed at the
end like that, not sure.
omniVERSE <inv### [at] aol com> wrote in message
news:3832b40b@news.povray.org...
specify
1
related
any
> Win.
> Bob
> > camera{
> > look_at 0
> > angle 90
> > orthographic
> > Ingo
I have found that orthographic can come at the last of the
camera statement and still work fine. I only have to make sure
that the camera is not too close or it takes a picture of the
insides of some of the objects.
> Bob
> specify
> 1
> related
> any
> > Win.
> > Bob
> > > camera{
> > > look_at 0
> > > angle 90
> > > orthographic
> > > Ingo
>Running NT4 & SP6.
Installed 3.1g.watcom.win32, gives the same results.
Ingo
I think the direction vertor length is longer that your camera
location-to-look_at distance, causing some problems. With an ortho
camera you can move it as far back as you like, and then use the up
and right vectors to indicate viewing area. Try moving it as far back
as 100 and use something lije up Size*y right Size*4/3*x, and vary
Size until you get a perfect fit.
Peter Popov
ICQ: 15002700
Peter Popov wrote:
>Try moving it as far back as 100 and use something lije
>up Size*y right Size*4/3*x, and vary Size until you get a
>perfect fit.
That's it. Thanks Peter,
Ingo
