POV-Ray : Newsgroups : povray.general : There must be a better way to do threads Server Time
21 Oct 2026 16:49:21 EDT (-0400)
  There must be a better way to do threads (Message 1 to 6 of 6)
Subject: There must be a better way to do threads
Date: 25 Mar 2004 09:18:05
Message: <86brml810l.fsf@duchess.twilley.org>
Hash: SHA1
I've googled for examples on threads (on bolts and the like) and I've
written a macro that looks like this:
#macro do_threads (turns, start, length, outer, inner, perturn)
union {
  #local index = 0;
  #local total = 360*turns;
  #while (index < total)
    #local zee = start+index*length/total;
    cone {
      <outer, 0, zee> length/turns <inner, 0, zee> 0
      rotate index*z
    #local index = index + 360/perturn;
This macro creates a jillion (well, perturn*turns) cones to simulate a
triangular spiral prism.  It works, but it's ugly and slow as a dog.
Please tell me that there's a better way.  I stared at the docs for
lathe and prism, and I couldn't see anything useful there.
Help?
Jack.
Jack Twilley
jmt at twilley dot org
http colon slash slash www dot twilley dot org slash tilde jmt slash
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (FreeBSD)
iD8DBQFAYuneGPFSfAB/ezgRAoMGAJ0aaJINe5OpXNP7UMxa9j1/coNovACgnBUu
MlX93neI9Bx0USOF+Tt13pE=
=Jafi
-----END PGP SIGNATURE-----
Subject: Re: There must be a better way to do threads
Date: 25 Mar 2004 10:34:24
Message: <4062fc00@news.povray.org>
Hi Jack
Have you tried pov's helix function (the thread shape does not have to
be round)?
Try playing with this:
//Start extract
#include "functions.inc"
// Bolt - thread is made 4 times larger.
#declare Thread =
isosurface {
  function{ f_helix1(x,y,z, 1, 40, 0.12, 0.28, 0.7, 2, 0) }
  contained_by{ box{ <-0.5,-3,-0.5>,<0.5,-0.6,0.5> } }
  accuracy 0.0001
  max_gradient 1.7
#declare Bolt =
difference{
   union{
      cylinder{ 0, y*0.3, 0.3 } // Head
      object{ Thread scale 0.25 }
      cylinder{ -y*0.75, -y*0.1, 0.07 }
      cylinder{ <0,-0.15,0>, <0,0.05,0>, 0.1 }
   torus{ 0.1, 0.04 translate -y*0.15 }
   box{ <-0.05,0.2,-0.4>, <0.05,0.35,0.4> }
// End extract
You can see an example of these here:
http://www.peake42.freeserve.co.uk/pix1/tape.jpg
There is also a "Nut and Bolt" macro out there somewhere (also try
p.b.s-f and p.t.s-f).
Alf
http://www.qsl.net/gw3srg/
Date: 25 Mar 2004 11:41:10
Message: <861xng98yk.fsf@duchess.twilley.org>
Hash: SHA1
I hadn't tried f_helix[12] or f_spiral because I couldn't find any
example code using them, and I've never used isosurfaces before.
If f_helix1 will allow me to create a triangular spiral prism, then
I'm all set.  I'll tinker with the code you've posted (it all makes
sense except the isosurface stuff) and see if I can make it work.
Thanks!
Jack.
Jack Twilley
iD8DBQFAYwtoGPFSfAB/ezgRAnbNAKCYiG2uygYwb13LAwMfVamzPqIScACgjNj2
jKq9N+VQxr59jYH4dBo5b6E=
=2Alh
Date: 25 Mar 2004 11:51:50
Message: <40630DF0.7080202@hotmail.com>
Jack Twilley wrote:
 > Help?
Hello Jack.
Here's a simple way using an isosurface and a declared pattern to make
triangular threads:
#declare threads=
  function{
   pattern{ spiral1 1 rotate x*90 triangle_wave}
isosurface {
  function{
   // cylinder, with a radius of 5 units
   sqrt(x*x+z*z)-5
   // threads
   +threads(x,y,z)/4
  accuracy .01
  evaluate 5, 1.2, 0.95
  contained_by{ box{<-5,-10,-5>,<5,10,5>} }
  pigment{rgb .1}
  finish{reflection .9 specular 1 roughness .05}
If I think of anything else, like a faster method, I'll post more code.
-Samuel Benge
Date: 25 Mar 2004 13:49:36
Message: <cjameshuff-7E0E3C.13495525032004@news.povray.org>
In article <86b### [at] duchesstwilleyorg>,
There are several better ways. You could build a mesh or use an
isosurface, for example. The mesh would probably be faster, the
isosurface would use less memory and wouldn't have faceting problems.
http://tag.povray.org/
Date: 25 Mar 2004 13:52:29
Message: <cjameshuff-D5E66C.13524825032004@news.povray.org>
In article <cjameshuff-7E0E3C.13495525032004@news.povray.org>,
BTW, an easy method of generating a mesh would be to use the
cylinderical height field macro in shapes.inc. Just use a spiral pattern
function to bring out the threads.
