POV-Ray : Newsgroups : povray.general : radiosity bug possibility Server Time
3 Nov 2026 07:01:59 EST (-0500)
  radiosity bug possibility (Message 1 to 19 of 19)
Subject: radiosity bug possibility
Date: 8 Apr 2002 08:23:02
Message: <6tt2bukar7lt4pmdr4fa9g2ain3t29hcg6@4ax.com>
I can't prove anything but somehow I feel below can cause some kind of error
(crash, bad image, etc). I wonder about radiosity in animation. I have SCENE.POV
script with scene of animation with radiosity. Then I start two instances of
POV-Ray:
first: +KFF100 +EF50 +ISCENE.POV
second: +KFF100 +SF51 +ISCENE.POV
but during trace proces there is only one file SCENE.RCA. Is it good behavior ?
Both images are different - objects move. I don't use save/load feature of
radiosity but I can imagine somebody can. Shouldn't RCA file be named like
currently rendered image ? Of course I'm talking about 3.5.
ABX
Subject: Re: radiosity bug possibility
Date: 8 Apr 2002 13:13:28
Message: <3cb1cfb7@news.povray.org>
  That's exactly how it works. It uses one file for the radiosity data tree.
When the rendering finishes, it deletes this temporary file.
Date: 8 Apr 2002 13:25:14
Message: <bhk3bu4abq3qf4kfdobef640odvkrdhbco@4ax.com>
but... is it safe when two applications write data to one RCA file ?
ABX
Date: 8 Apr 2002 13:39:53
Message: <3cb1d5e9@news.povray.org>
so running multiple versions of the same filename (in the same path,
on the same machine, of course) with different data parallel will
work wrong ... Is this what you said?
Date: 8 Apr 2002 15:56:59
Message: <3cb1f60a@news.povray.org>
  POV-Ray does not support parallel rendering. Thus collisions can happen.
Date: 8 Apr 2002 15:59:31
Message: <3cb1f6a3@news.povray.org>
  POV-Ray is not designed to perform parallel raytracing.
Date: 9 Apr 2002 03:00:45
Message: <3cb2919d@news.povray.org>
but it would be a "minor" change (in the next MegaPov, of course) to build
a hash 'bout the parsed Code, and its "variables" to have a unique identifier
for this File, one could append ....
... but thats probably just a silly idea (Hey, its early morning here, isn't it ? ;)
Date: 9 Apr 2002 04:19:12
Message: <ou75bucf1fps61ukbmkgi3c3ulr21sdh1q@4ax.com>
unique identifier is a name of current image becouse it contains number of
frame.
ABX
Date: 9 Apr 2002 06:24:56
Message: <g7g5bu8d8q5tvaern01ct9030gn5n9vd77@4ax.com>
so another thing to do for me in patching time
ABX
Date: 9 Apr 2002 09:24:22
Message: <3cb2eb86@news.povray.org>
what if someone makes use of some "external-parameters" such as current
time/date, to make a nice watch ? ...
... and maybe, he doesn't want an animation ... ? ... and he starts it
at different times while the first one is still running ...
So what is left, if the filename (and "frame") is the same ?
hence I said, that probably a hash of a memdump  (after parsing) is
necessary, to create a unique ID
Date: 11 Apr 2002 15:38:51
Message: <72m7buo3llmhqhd1h67hrdrc1sf91cg89f@4ax.com>
On Tue, 9 Apr 2002 15:24:56 +0200, "Jan Walzer" <jan### [at] lzernet>
An MD5 checksum of all the memory reserved by POV right after parsing
Peter Popov ICQ : 15002700
Date: 12 Apr 2002 04:53:37
Message: <3cb6a091$1@news.povray.org>
thats what I meant ...
... but wouldn't the creation of this MD5 mean, that the memory reserved
by POV will change? ... doesn't that make the MD5 invalid ?
... no ? .. ok ... then do so ...
Date: 28 Jun 2002 08:05:35
Message: <73kohu4ts25k37pf7376vbm74t7m5r5bf5@4ax.com>
On Mon, 08 Apr 2002 14:22:23 +0200, Wďż˝odzimierz ABX Skiba <abx### [at] babilonorg>
> POV-Ray:
Have anybody tested something similiar for OS on cluster of computers? with
3.5 or 3.1 ? I'm interested in results. Thanks.
ABX
Date: 20 Jan 2004 17:29:54
Message: <400DAB68.63729752@cpsc.ucalgary.ca>
Hello,
I have been rendering radiosity images on clusters for a few weeks now.
I am doing *absolutely nothing* to prevent/deal with the supposed
"artifacts" that distributed radiosity rendering creates.  I cannot see
any rendering artifacts.  Could someone please explain what these
artifacts would look like & possibly point them out in the following
images?
http://homepages.ucalgary.ca/~psmacmur/images/poppy640.png
This was rendered with SMPOV in 16 horizonal strips (Tiled 1x16)
http://homepages.ucalgary.ca/~psmacmur/images/beanstalk_potted_500x700.png
This was rendered on several computers but i forget which or how many:
http://homepages.ucalgary.ca/~psmacmur/images/beanstalk_potted_filter_1500x2100.jpg
This hi-res version of the previous model was rendered in 4 horizontal
strips on SGIs using distribution/reassembly code based on Paul
Bourke's:
http://astronomy.swin.edu.au/~pbourke/povray/parallel/
All use radiosity in conjunction with a very large dense area light.
"Włodzimierz ABX Skiba" wrote:
> On Mon, 08 Apr 2002 14:22:23 +0200, Włodzimierz ABX Skiba <abx### [at] babilonorg>
> > POV-Ray:
> ABX
Date: 20 Jan 2004 22:00:01
Message: <pan.2004.01.20.23.17.57.445065@nomail.com>
On Tue, 20 Jan 2004 15:27:52 -0700, Peter MacMurchy wrote:
What a beautiful plants, and, indeed, I cannot see artifacts too.
But I have to ask: how do you generate these plants...do you happen
to be linked to the L-systems group ?
Willem
Date: 21 Jan 2004 04:02:16
Message: <400e4018@news.povray.org>
> images?
I don't know, but it is easy to test: render the same image using a
single computer and a cluster and calculate the difference of the two
images. If you get only zeros, then there is no difference.
Severi S.
Date: 21 Jan 2004 04:32:03
Message: <tvs1e1-h3a.ln1@triton.imagico.de>
> Hello,
> images?
These images already look quite near to the correct lighting solution -
in such cases the problems of tiled renders without sharing radiosity
data will of course diminish because all tiles converge to the same
correct solution.
Still it will be quite inefficient not to share the data because this
way many calculations are redundant.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 21 Jan 2004 17:18:28
Message: <400efab4$1@news.povray.org>
Thank you!  Yes, indeed, the plants' skeletons are generated using
L-systems, which are coded in the locally-developed L-Studio.  The
output of the L-systems are then passed to my research software, which
generates subdivision surfaces.
> Willem
Date: 24 Jan 2004 15:15:29
Message: <4012d261$1@news.povray.org>
I can't speak to clustering, but the screens you link to (very nice,
BTW) are not ones prone to radiosity artifacts.  You have strong
textures and mostly curved surfaces both of which tend to hide lighting
imperfections.  If you want to find where artifacts may have occurred
use a plane white texture in one of your renders.  That tends to make
any artifacts stand out.
> Hello,
> images?
> Bourke's:
