POV-Ray : Newsgroups : povray.general : a little ray tracer Server Time
13 Aug 2026 09:16:55 EDT (-0400)
  a little ray tracer (Message 1 to 10 of 15)
Subject: a little ray tracer
Date: 4 May 2026 02:51:06
Message: <69f841da@news.povray.org>
Why is POV-Ray (development) in decline? Lack of developers? Realy? Look
at the wealth of include files.
What if we can compile an include file, use it as a dll? What if after
some time it gets integrated in the core?
simple scene
   -> include file      (sphere.nim imported, used directly)
     -> plugin          (sphere.nim compiled as shared lib, loaded at
runtime)
       -> core feature  (merged into core)
Then the author of the Nim programming languge published:
https://nim-lang.org/araq/relays.html
It clicked.
That woud make it possible to write torus.nim as an "extension". Add
`import torus` in a nim scene file. The parser would detect it, but does
not know it. Looks for the file in the right place, compiles it to a dll
and uses it
`torus.nim` would contain just the torus intersection algorithm, a
constructor and a few tidbits. In the future it will contain a proc that
will result in a mesh of a torus and a pies of code that extends a scene
parser with `torus`
so, shapes are relays. Lights are relays, cameras and materials are.
I've been discussing ratracing for quite some time with Claude, this
brought it all together.
A glimpse of the goal:
Scene SDL
├--> Raytracer backend       (analytical intersection, BVH/R-tree) ←
reference
|--> Path tracer backend     (physically based)
|--> OpenGL / Vulkan backend (realtime preview, all geometry meshed)
|--> STL / mesh backend      (3D printing, watertight meshes)
|--> Audio backend           (acoustic simulation)
Back-ends are also relays. When back-end is switched to vulcan all
shapes will be meshified.
So far very little is implemented. The little ray tracer does not
support plug ins yet and it just has one fixed back-end. Shapes etc are
relays.
The first code I got running with the help of Claude:
https://gist.github.com/ingoogni/c4ca054e37a79706ff9c05c75b435467
You'll find SQlite references in the code. Not implemented yet, but the
goal is to store a lot of data during tracing in a database. These data
can be used for example for post processing the image(s). Re-colour a
light source?
ingo
Subject: Re: a little ray tracer
Date: 4 May 2026 04:05:00
Message: <web.69f8531f1235ce7816086ed06830a892@news.povray.org>
> simple scene
> runtime)
> It clicked.
> and uses it
> parser with `torus`
> Scene SDL
> reference
> relays.
> light source?
> ingo
Initiatives, brainstorming are always good ! And POV development is indeed not
at all in decline but I wouldn't look at macros to advocate that (because core
developers know best the real gap between lowest levels and the SDL, I would
rather look at master codebase pull requests:
And indeed flags are turning green there: Much awaited steps are being worked on
such as incrementing Visual studio version, adding more modern scalable
processors with future-proof architectures (AVX512) without throwing away
ubiquity (3.8 bsd port is available, as is a Termux package).
Even when considering only the couple of pull requests that are being closely
reviewed by the Chris Cason, main developer, and followed through by their
openers to conform to his suggested technical tweaks or legal conformity
demands. Slow train is steadily moving forwards, with a solid strategy!
POV versions have always been slow to happen, sometimes allowing branches to
appear as they did in the MegaPOV era. But since the git-hub era started, The
improvements of these branches could almost directly benefit the plain master
version of POV after thorough testing and pruning: a lot of the Uberpov features
got merged, and a lot of the POVR/YUQK fixes also did.
The currently underestimated number one bottleneck :
More time and focus should be given to documentation. because what prevented
latest 3.8 version to go out exactly as it used to, with binary installers etc.
is docs (not only draft bits and pieces, but finalizing them and all of it):
After the departure of the person who had for decades single-handedly maintained
POV documentation. And only someone who has been there long enough to be highly
trusted by the core team and the community could fill in to not lower the
currently triple A quality, with native language (US vs UK, good expressive
style...) and lots of free time to proofread, convert it to other formats, etc.
Date: 4 May 2026 05:21:09
Message: <69f86505@news.povray.org>
> rather look at master codebase pull requests:[...]
There is a, almost natural, discrepancy between developers and users of
a program. They have different interests, goals. Nothing wrong with
that. They speak different languages (in life and in code (in POV-Ray's
case)). English bridges the gap between my Dutch and your French. What
if there is no gap at all, in coding language? Front end, back end
middle ware all in the same language. Coders and users speak the same
language, they all "code". That removes "friction". That can enhance the
product.
I'm in no way suggesting that in such a case users can suddenly be core
POV-Ray developers. Knowing the moves of chess pieces don't make me a
chess player.
Decline; It always saddens me when I mention POV-Ray within a relevant
context that the response is, "yeah, I used that 20 years ago, is it
still around?".
Anyway, thoughts like this made my give it a try and see wether it would
work. As said, it is the first working version. In theory the concept is
very extensible up to the question: is POV-Ray the plug-in to the
modeller or is the modeller a plug-in for POV-Ray. Don't want to quote
Goehte here, yes, boundaries should be set, but first have to be
explored. So far, it's just a little fun project.
ingo
Date: 4 May 2026 09:05:00
Message: <web.69f899771235ce78da82d88b25979125@news.povray.org>
jr and I have had extensive discussions and brainstorming / planning sessions
where we have striven to address how we should go about
fixing/rewriting/developing POV-Ray and how to best manage an open-source
project.
I like to use the analogy of actually building something.
It may start with an idea, then a sketch, then an analysis of the details:
requirements, parameters, goals, features, allowing modification/extension, etc.
Detailed drawings, Geometric Dimensioning and Tolerancing, and perspective
drawings to get a preview of what it will look like when finished.
As folks have seen, I have tried to make lists of "things" in POV-Ray that I'd
like to implemented, improved, or fixed.
I've also made some doodles in SDL to sketch out what I'd like to see formally
implemented in source code.
With things like sor {}, I've gone through the source and done the research and
detective work necessary to understand what the goals, are, how they are
currently implemented, and meticulously checked all of the steps that make it
work, and compared that to expected or desired outputs.
Then I offered suggested source code edits, and critiqued the current state of
not only the sor {} object, but the related lathe, the spline code, the root
solver(s), and the bounding.
> that.
Yes, but there does need to be communication and meaningful feedback for
anything productive and substantive to happen.
Developers create the things that the users implement.
Users dream up applications of what the developers create.
There's a behind-the-scenes anecdote regarding the film's set design. When
reviewing script scenes depicting Hell, Director Adrian Lyne asked writer Bruce
Joel Rubin, "How many carpenters do I need to build the abyss?"
That really struck home to the writer the immense practical construction
but might take a herculean effort to create on a set.
"Easier said than done."
Also consider the "bullet time" scene from The Matrix.  I think it took a year
and a half and a huge pile of equipment and money just to implement an effect
for only a few seconds of a scene in an otherwise long film.
> product.
> chess player.
Yes, this is why I have strongly suggested that users pick a feature and try to
implement it in SDL. (or any other language)
It serves to increase understanding of what actually goes into making a shape,
or solving some equation, and properly visualizing it on the screen.
It also helps (self)document things, incidentally discover limitations, bugs,
and other unknowns, and usually the user winds up providing the results of their
research and discoveries in the forum.
That helps everyone in the long run.
Documentation is a giant pain in the ass.
However, formal documentation need not be a stumbling block for releasing a new
version.
No one needs a 4-paragraph explanation about how to use a volume control.  Be it
a rocker-style button with +/- marking, a knob to rotate that has a wedge shaped
glyph, or a slider that has a bar-graph indicator.
Even if the label is somewhat cryptic and mysterious, you just move the control
and observe the change.  Understanding is almost instantaneous.
If we have working code that a user can implement in seconds, then they can just
fiddle with the controls to intuitively understand what might takes pages of
written documentation to convey.  Not to mention all of the renders and diagrams
that might be necessary to supplement the text.
So I'll say it again:   1 fully working code example for every keyword.
Once the code gets written, it's a lot easier to understand what may need to be
written about it, and the written part can always lag behind the development
(presuming that comments are provided in the cde, as they should be).
- BE
Date: 4 May 2026 13:36:13
Message: <69f8d90d$1@news.povray.org>
One of the reasons I wrote the stuff in the portfolio when I worked on
the documentation. Currently only for patterns, textures, shapes and
objects but it can be extended to all kinds of keywords.  All kind
radiosity setting in a Cornell box...
ingo
Date: 4 May 2026 15:10:00
Message: <web.69f8eeda1235ce7848bf72fa6cde94f1@news.povray.org>
hi,
I like Mr's take (for which thanks) -- "...train is steadily moving forwards..."
> Look at the wealth of include files.
> Scene SDL
> reference
ideally, yes.  however
> ... English bridges the gap between my Dutch and your French. What
> product.
what happened to "variety is the spice of life" ?!  different languages (both
computer and human) all have their strengths and weaknesses, and I see nothing
"wrong" with "multi-language" projects.
@Bald Eagle.
> ...the sor {} object...
yes, "unfinished business", write.
regards, jr.
Date: 5 May 2026 08:20:26
Message: <69f9e08a$1@news.povray.org>
languages (both
see nothing
but but, but the raytracer's job is to populate the database. The trace
data is the render. Everything else is SQL. Image is a query, depthmap
is a query, normalmap is a query ...
-- depth map as a query, not a render pass
SELECT
   pixel_x,
   pixel_y,
   MIN(t) AS depth  -- closest hit along each ray
FROM bounces
WHERE frame = 42
GROUP BY pixel_x, pixel_y
to take it to the extreme, the render relay should probably be the only
thing that actually traces rays. Everything else — depth, normals,
object IDs, albedo — is a material relay or a post-process query.
ingo
Date: 5 May 2026 09:05:00
Message: <web.69f9ea7a1235ce789839f6ab25979125@news.povray.org>
> .... Everything else is SQL. Image is a query, depthmap
Perhaps you could take a bit of time to explain how the parser gets handled.
clipka's major concern was fixing/refactoring the parser.
I know that we have a special, hand-written parser that's not like most
languages.
If I understand all of it correctly, we have
A raw tokenizer
A tokenizer
A scanner
A parser
and then handling of objects, symbol tables, functions, textures, etc.
I don't really understand all the grammar, lexemes, syntax vs semantics, symbol
tables, etc. that go into building a language, and I think it would help if we
dedicated a few threads to discussing these aspects of the source, so that we
can better understand what we HAVE, and plan out a path to where we want/need to
be.
Writing out some code that just goes through the motions but doesn't implement
anything would give people an idea about the roadmap that constitutes how the
raytracer works overall, and I think a high-level pseudocode version would be a
great way to help organize all of the various parts.
We have redundant code, things that are intertwined in the parser that ought not
be there, and various algorithms that get applied to different shapes as part of
the bounding (bsp, cylinder bounding, AABB, sphere bounding).
If we rearranged the code at a high level, and made extensive comments about WHY
the parts of the code ought be in the places we're putting them, then that would
be a big step forward in filling in the place-holder stuff with actual code.
We already have the code base, so we can just copy-paste a lot of what already
exists, and then it would be a matter of making all of the various parts work
together.  We can make it modular, add much-needed comments and references,
standardize some of the math and constants used (epsilons), etc.
This would also be a good class on writing patches and compiling source code, so
that more people can understand how to make POV-Ray vX.Y.Z
- BW
Date: 5 May 2026 10:47:31
Message: <69fa0303$1@news.povray.org>
When using Nim, as I do there are two and two halve options.
- Just use Nim as I have done now (could be cleaner), no need to write a
parser as we use Nim's parser & compiler.
- A halve option adds a Domain Specific Language on top. That is created
using Nim's macro system (AST rewriting at compile time). It is still
pure Nim and the DSL could be done for scene description while using
usual Nim code for the rest functions etc. Look at it as a syntax sugar
layer:
scene:
   camera perspective:
     pos    = vec3(0, 1, 2)
     lookAt = vec3(0, 0, -3)
     fov    = 60
   sphere:
     center   = vec3(0, 0, -3)
     radius   = 1.0
     material = red
   pointLight:
     pos       = vec3(5, 8, 2)
     intensity = 100
Squiggels can probably be added to make it look more POV-Ray.
- A halve option would be to use Nim's scripting language. That would
require no compilation but it does not (yet?) fully / seamlessly
integrate with the compiled version. But it still looks and feels the
same as Nim
- An option would be to write a full scene parser. I have not arrived at
that stage, but feel it as "limiting".
Nim3 is in the making, a part of it is a Lisp like language that could
bridge a parser and the Nim compiler. If I understand it all correctly.
https://github.com/nim-lang/nifspec/blob/master/README.md
https://github.com/nim-lang/nifspec/blob/master/doc/nif-spec.md
A front end parses and converts "POV-Ray SDL" and outputs:
(.nif27)
(.lang "raytracer")
(stmts
   (camera@2,1 (vec3 0.0 1.0 2.0) (vec3 0.0 0.0 -3.0) 60.0)
   (sphere@3,1 (vec3 0.0 0.0 -3.0) 1.0 (material :red.0.materials))
Nim parses it, compiles and renders.
But, what becomes clear in the discussion so far, we are trying to solve
different problems.
ingo
Date: 5 May 2026 17:20:00
Message: <web.69fa5ea21235ce7848bf72fa6cde94f1@news.povray.org>
hi,
>  > what happened to "variety is the spice of life" ?! ...
> SELECT
>    pixel_x,
>    pixel_y,
> FROM bounces
> WHERE frame = 42
you sure know how "to take the wind out of my sails" </grin>.  that really is an
interesting perspective.  heavy..
> to take it to the extreme, ...
I don't have the required background(s) but am still left with a "nagging
feeling".  a fully spec'd "application binary interface", as you've alluded to
with the dynamic-link libraries, ought to be enough.  (unless I misunderstood ?)
regards, jr.
