POV-Ray : Newsgroups : povray.general : question about same code(?) and different render Server Time
30 May 2026 15:25:22 EDT (-0400)
  question about same code(?) and different render (Message 1 to 10 of 11)
Subject: question about same code(?) and different render
Date: 19 Mar 2026 23:35:00
Message: <web.69bcbfe9df46a7a2ebc5b66f59126100@news.povray.org>
I am working at my parser, but I got two different results.
example :
triangle{<3.2475,.9143,6.0001><3.4358,.9376,5.9847><3.2475,.9376,6.0047>
pigment{color rgb<255/255,63/255,0/255>}}
pigment{color rgb<1,63/255,0>}}
but is mathematics an opinion? (ver. 3.7)
many thaks if someone help me to understand!
Download 'clipboard01.png' (19 KB)
Preview of image 'clipboard01.png'
Subject: Re: question about same code(?) and different render
Date: 20 Mar 2026 08:15:00
Message: <web.69bd393c2834f0ea844aba0825979125@news.povray.org>
This is VERY interesting Gio.
Apparently the color keyword applies gamma handling,
but using just rgb is linear color.
Remove the color keyword and see if the colors are the same.
I'd also be interested to see what happens if you do your multiplication first.
#declare Color = <255/255,63/255,0/255>;
pigment{color rgb Color}}
I guess "color" triggers legacy gamma correction rules, which exists for
backwards compatibility.
- BE
gamma‑encoded color values, applying the scene gamma correction rules.
And:
Date: 20 Mar 2026 12:50:00
Message: <web.69bd7a022834f0ea8a6844a759126100@news.povray.org>
> - BE
> And:
Thanks for the suggestion.
I'm upgrading my POV-STL-CAD translator from 32 to 64 bit, and I realized that
before translating the pov files I need to normalize all the various syntax
expressions I used in my POV and INC files.
If I don't standardize the syntax, compiling the database for exports the
entities will become a very complicated mess.
I'll try what you suggest...
Date: 20 Mar 2026 13:40:00
Message: <web.69bd85d82834f0ea8a6844a759126100@news.povray.org>
mmmm... it seems not working again
it's possible that in the same vector <nnn,nnn,nnn> the elements cannot to be a
mix of integer and float (nnn/nnn)
Date: 20 Mar 2026 14:00:00
Message: <web.69bd8a302834f0ea48bf72fa6cde94f1@news.povray.org>
hi,
to POV-Ray an "integer" is the same as a float, without decimal point & digits,
"Where POV-Ray needs an integer value it allows you to specify a float value and
it truncates it to an integer".
<wiki.povray.org/content/Reference:Numeric_Expressions>
regards, jr.
Date: 21 Mar 2026 11:39:03
Message: <69bebb97$1@news.povray.org>
I'm confused.  Both colors specifications should be orange, but I see no
orange in the images.  The only difference I see is areas that are black
on the left and white on the right, and that does not look like a gamma
issue.
It would help if we had more context for this code.  When I incorporated
the triangles in a scene, they both were the expected orange.
> - BE
> “The color keyword causes POV‑Ray to treat the given RGB values as
> The plain rgb keyword specifies linear RGB values.”
> And:
> “The color keyword is deprecated and should be avoided in new scenes.”
Whoa, this is news to me!  Where is this in the documentation?
This has implications for macros that force promotion on its arguments
or that return vectors to be used as colors.  Sometimes the only way to
avoid a parse warning or parse error is to use the color keyword.
Date: 21 Mar 2026 11:55:00
Message: <web.69bebf0c2834f0eaa6fa745959126100@news.povray.org>
Thank to all!
I'm sorry for wasting your time
I accidentally found the source of the problem. It must have happened while
using my compression routine to remove unnecessary white space. I couldn't
replicate the error; when I used it on a very large file, it gave the same
error. Suspended... for now.
Sorry again !
Date: 21 Mar 2026 12:30:00
Message: <web.69bec7582834f0ea1f9dae3025979125@news.povray.org>
Yeah, this is what happens when I get too little sleep and try to wrangle things
with a search engine while I'm doing 8 other things at the same time have and no
direct access to povray so I can run test code.
It didn't seem right - especially due to the vector promotion thing, but I just
plowed right through that and didn't listen to "the little voice".
What a gaffe.  Someone delete this.  :O
- BE
Date: 26 Mar 2026 10:30:00
Message: <web.69c542c02834f0eae83955656e066e29@news.povray.org>
> - BE
No no! :-)
Even though GioSeregni solved his own problem, I'm likewise curious as to where
your search engine pulled up that gamma info about the 'color' keyword. It was
news to me too. (To satisfy my curiosity, I just tested 'color rgb' vs. rgb-- no
difference.)
Maybe that was the case in an **old** POV-ray version?
Or did that piece of info get generated by...uh...A.I.? :-O
Date: 26 Mar 2026 11:00:00
Message: <web.69c549df2834f0ea7ca0eb7925979125@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> No no! :-)
I'm sure this is how the War Between The States got started . . .
> difference.)
Man, that was last Friday at 8:15 in the morning.
I likely had 300+ pages of stuff to sort, a truck driver at my window, the phone
ringing, someone behind me talking, the walkie screeching, and I was just trying
to eke out a quick answer before diving into all that.
Maybe it was one of those stupid "AI summary" things that they insist on making
look like an actual search result.
I mean, with as much of this color-correction crap as we've been through, I
should have just looked at it and said _That can't be right_, but the coffee
really just doesn't fully grab hold until maybe 9am or so.
I never use "color", so my snoozing brain must have somehow been bedazzled by
that wild claim.
Caveat Lector.
- BE
