POV-Ray : Newsgroups : povray.general : Strange syntax Server Time
13 Aug 2026 09:18:55 EDT (-0400)
  Strange syntax (Message 1 to 10 of 19)
Subject: Strange syntax
Date: 24 Feb 2026 11:36:24
Message: <699dd388$1@news.povray.org>
Hello,
I found this in some very old code (2016) :
light_source {
   <0, 100, 0>
   color White=1
and with thise, the light in the scene is red.
of course, back to "normal" color White give white light.
How this <color White=1> is interpreted and why does it turn red?
kurtz le pirate
compagnie de la banquise
Subject: Re: Strange syntax
Date: 24 Feb 2026 12:25:00
Message: <web.699dddebf71f0dcaa433a43625979125@news.povray.org>
kurtz le pirate <kur### [at] freefr> wrote:
> Hello,
> light_source {
>    <0, 100, 0>
>    color White=1
Yeah, that's weird.
The parser is a strange and wondrous thing.
Presumably you are including colors.inc.
Can you output the color value of White as a 5D vector to the debug stream
before instantiating the light source, and then show what happens to it after?
- BE
Date: 24 Feb 2026 22:21:40
Message: <699e6ac4$1@news.povray.org>
Where does the identifier `White` come from?  Like BE, I would like to
know its value.
My understanding of that syntax is that it compares each component of
`White` with 1.  But if `White` comes from colors.inc, the
component-wise comparison would still end up as white.  The only way I
can see this evaluating as red is if `White.red` is exactly 1, and
`White.green`, `White.blue`, `White.filter`, and `White.transmit` are
all something other than 1.
Date: 25 Feb 2026 03:56:54
Message: <699eb956@news.povray.org>
> know its value.
White come from "colors.inc"
I also thought that "=" was interpreted as a comparison operator.
But since “White” is defined by rgb 1, that doesn't explain anything.
kurtz le pirate
Date: 25 Feb 2026 06:50:00
Message: <web.699ee0d4f71f0dca1f9dae3025979125@news.povray.org>
[before light_source]
White = <1.000, 1.000, 1.000, 0.000, 0.000>
[after light_source]
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\_CodeScratchPad.pov" line 13:
Parse Warning: Expected pure RGB color expression,
unexpected filter and transmit components will have no effect.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\_CodeScratchPad.pov" line 16:
Parse Error: Parse halted by #error directive: No
objects in scene
I'm thinking that the red must be coming from something else.
Post the whole scene, a link, or at least more to work from?
- BE
Date: 25 Feb 2026 13:45:13
Message: <699f4339$1@news.povray.org>
> objects in scene
> - BE
Just tested, using this : #declare W = (White=1);
And got this :
W = <1.000, 0.000, 0.000, 1.000, 1.000>
NOT what I would expect.
Date: 25 Feb 2026 14:25:00
Message: <web.699f4b6cf71f0dcaa433a43625979125@news.povray.org>
> And got this :
Yes indeed, VERY strange.
I was going to do something like that, but I needed to head out.
what if plug (White=1) directly into a debug vstr statement?
- BE
Date: 25 Feb 2026 15:01:50
Message: <699f552e$1@news.povray.org>
I just tried it with different versions of POV-Ray.  It is red only with
POV-Ray 3.8 and the discontinued POV-Ray 3.7.1.  It is white for all
versions 3.5 to 3.7.0.10.
This appears to be a bug that was introduced in POV-Ray 3.7.1.
Date: 25 Feb 2026 15:15:00
Message: <web.699f575ff71f0dcaa433a43625979125@news.povray.org>
Nice work, Richard.
So what are you doing that I didn't?
Because as you can see above/below, I'm using 3.8
Are you outputting the color value with vstr(), or performing a render using
that light source?
I'm just trying to understand where this all goes off the rails, and where to
look under the hood.
- BE
Date: 25 Feb 2026 15:50:28
Message: <699f6094$1@news.povray.org>
> Nice work, Richard.
I just opened a bug report on GitHub, issue #486.
https://github.com/POV-Ray/povray/issues/486
The warning about unexpected filter and transmit components indicates
that the bug did manifest, but without altering `White`.  Did you create
an image output?  Did you vstr() the expression `(White=1)`?
> that light source?
Both.  My source code is in the GitHub report.
