POV-Ray : Newsgroups : povray.general : Stupid fatfingers Server Time
28 Oct 2026 08:31:13 EDT (-0400)
  Stupid fatfingers (Message 1 to 16 of 16)
Subject: Stupid fatfingers
Date: 25 Aug 2024 12:38:00
Message: <66cb5de8$1@news.povray.org>
I just accidentally destroyed a 14 hour render, by accidentally
repeating the render command--within seconds of it completing, so no
backup.  Don't you hate when that happens?
I'm using GNU/Linux, where file undeletion requires a 3-credit semester
course to learn how to do it.
Do you with the 3 week renders ever have that problem?
Subject: Re: Stupid fatfingers
Date: 25 Aug 2024 12:49:40
Message: <66cb60a4$1@news.povray.org>
It's sorrow, but not fatal - 14 hours is not too much. Just start it
again, go to bed, sleep, wake up, have a good breakfast, go for a walk,
get back and it will be ready !
YB
Date: 25 Aug 2024 12:51:47
Message: <66cb6123$1@news.povray.org>
It's sorrowful, but not fatal - 14 hours is not too much. Just start it
YB
Date: 25 Aug 2024 13:05:00
Message: <web.66cb63188092bf0c25a9cb368484ae3a@news.povray.org>
Now it's time to learn how to make an automatic backup after each render. If you
take a moment chatgpt can create it for you.
BGimeno
Date: 25 Aug 2024 18:45:00
Message: <web.66cbb3488092bf0c1f9dae3025979125@news.povray.org>
Oh, I hear you my brother.
http://news.povray.org/povray.windows/thread/%3Cweb.5887512288c6897ec437ac910%40news.povray.org%3E/
Date: 26 Aug 2024 00:37:16
Message: <66cc067c$1@news.povray.org>
Sounds like you are complete computer novice and never pressed Ctrl+S
instead of Ctrl+Z before ;-)
With POVRay I have the opposite problem: parsing starts, takes time, and
stops and I'm going to search for the error, and all I see is
"interrupted by user".
"It's not a brake, it's slow full throttle".
Ilyich the Toad
https://dnyarri.github.io/
Date: 27 Aug 2024 08:40:00
Message: <web.66cdc7df8092bf0c587c26bf123015f7@news.povray.org>
Sorry to disappoint you, but there is no need for a dedicated course. You got
two options.
First one (under Linux Mint with Caja file manager) is found in the Edit menu,
option Undo (accessible by Ctrl+Z). After some delay, the last deleted
 file should reappear ...
Second option is a bit more involving: open Trash in your file manager and sort
it by date (from newest to oldest). You could find the requested file near the
top of the list of files, which appears after a more or less long list of
folders.
The second option can help you recover a file deleted some time ago. The first
one is an immediate action.
I hope this will help you a little. BTW, no shame having fat fingers: it happens
to me from time to time !
Kelumden a.k.a. Vincent Dumont
Date: 27 Aug 2024 10:37:41
Message: <66cde4b5$1@news.povray.org>
According to description provided, file was not deleted. File was
overwritten.
Ilyich the Toad
Date: 27 Aug 2024 10:46:26
Message: <66cde6c2$1@news.povray.org>
If I had known 3 years ago what I know today, I would have bought a
Linux Mint machine.  However, the KDE Dolphin file manager has the same
feature.  Not that it matters; see below.
> folders.
The problem is that these only work if you delete the file via the file
manager, or via an app that uses the trash folder (such as Gwenview).
This file was deleted by POV-Ray as part of the process of rendering a
new image.  It never went to the trash.
Date: 27 Aug 2024 11:05:00
Message: <web.66cdead98092bf0cf5bfc9b06cde94f1@news.povray.org>
hi,
> manager, or via an app that uses the trash folder ...
has me wonder if, perhaps, using a filesystem which supports "snapshots"[*], one
could set up a trigger, to fire when POV-Ray closes the output file.  (wild
speculation :-))
[*] like 'btrfs' and 'zfs'.
regards, jr.
Date: 27 Aug 2024 11:45:00
Message: <web.66cdf40e8092bf0cf5bfc9b06cde94f1@news.povray.org>
> ... perhaps, using a filesystem which supports "snapshots"[*], ...
on reflection, overkill.  a bit of scripting might do though, Tcl to the rescue
:-), the first example in particular:
<https://tcl-inotify.sourceforge.net/>
regards, jr.
Date: 27 Aug 2024 18:52:31
Message: <66ce58af$1@news.povray.org>
I've read through this discussion on looking in on the news forums today.
Off the top of my head, I think situation on accidentally re-starting a
long render isn't all that dire(*) these days - as long as you don't panic.
Prior to v3.7 and smp / threads, the image file was written as the image
pixels were rendered; an accidental re-start of a long render was more
of a problem because the output image file was almost immediately
written to after the render phase started. Today, the image and state
are stored internally and written to the output image file only after
the last block of the image completes.
On Linux / Unix at least, the reality is even after the fat finger
render phase starts and opens the output file, the prior image file will
exist until the file handle is closed at the end of the render phase(**).
Let the accidental re-render run (or better pause it) until you've
copied / moved the existing image file somewhere safe - then abort the
fat finger render.
Bill P.
(*) - POV-Ray versions using a gui might make me a liar, if the gui does
something with the image output file itself on the re-render.
(**) - Given most all default file buffering schemes.
Date: 27 Aug 2024 19:25:25
Message: <66ce6065$1@news.povray.org>
    Or use a real OS who do versionning, like VAX/VMS :)
|          https://tube.interhacker.space/a/tth/video-channels        |
Date: 27 Aug 2024 22:05:09
Message: <66ce85d5$1@news.povray.org>
> fat finger render.
This has not been my experience.  My observation is that the image file
disappears at the end of the parse phase of the new render.
Date: 27 Aug 2024 22:15:10
Message: <66ce882e$1@news.povray.org>
>> "snapshots"[*],
:-O
I didn't realize VMS was still around!
Yes, that is a useful feature of VMS.
Date: 27 Aug 2024 23:04:35
Message: <66ce93c3$1@news.povray.org>
>> fat finger render.
Thanks for questioning.
I didn't expect any difference on this between yuqk and official
releases with this, but apparently something I've done and forgotten; Or
an unexpected side effect of something I've done over time in yuqk,
makes it alone behave as I described.
The official releases do appear to erase the file at the start of the
rendering phase. (Ubuntu 22.04 using several official v3.7 & v3.8 releases)
Bill P.
