POV-Ray : Newsgroups : povray.general : Mesh rotation and inside_vector Server Time
28 Oct 2026 08:31:54 EDT (-0400)
  Mesh rotation and inside_vector (Message 1 to 11 of 11)
Subject: Mesh rotation and inside_vector
Date: 21 Aug 2024 12:05:43
Message: <66c61057$1@news.povray.org>
Greeting wise ones,
When fiddling with meshes I came to conclusion that, if I rotate a mesh,
inside_vector assigned to it does not rotate together with mesh. As a
result, if I build a CSG like intersection with mesh and start rotating
that CSG, some imaginary parts appear and disappear from/to nowhere.
Is there any way to glue inside_vector to mesh so it gets transformed
together with it?
Ilyich the Toad
https://dnyarri.github.io/
Subject: Re: Mesh rotation and inside_vector
Date: 21 Aug 2024 12:50:00
Message: <web.66c619aacb3ec43fa5a6be6925979125@news.povray.org>
You may be (probably) misunderstanding what the inside_vector does / is for.
Likely your problem arises from an incompletely closed mesh.
You should use a mesh editing took to analyze / fix your mesh and try again.
https://news.povray.org/povray.general/message/%3C5997f81e%241%40news.povray.org%3E/#%3C5997f81e%241%40news.povray.org%
3E
- BE
Date: 21 Aug 2024 14:41:20
Message: <66c634d0$1@news.povray.org>
On 8/21/24 12:05, Ilya Razmanov wrote:
> Greeting wise ones,
> together with it?
Hi.
This is likely a longstanding bug in the official releases of POV-Ray.
You are correct the inside vector should be rotated (transformed) along
with the mesh - otherwise the inside test is unstable(*).
I proposed a fix to this many years ago on the developer mailing list
and posted a pull request to github to fix it. At the time clipka
suggested an alternate coding and I, either updated my pull request to
that, or closed and submitted another exactly pull request which was
exactly his suggested code(**).
I kept the pull request current via re-basing for many years, but it was
in a collection of pull request from me never merged into the the
POV-Ray source code. I closed all my pull requests on deciding to pursue
my own branch (povr -> now yuqk) maybe 5-6 years ago. That closed pull
req on the official code is very likely still searchable on github. I
don't recall the fix off the top of my head. I confess I have not been
doing much with POV-Ray of late - and I find myself too lazy in the
moment to search for it (sorry).
Bill P.
(*) - There also is / was a longstanding unfortunate suggestion to make
the inside vector axis aligned (and so problematic with many meshes) in
the official documentation which I suggested be fixed too... Last I
looked, the documentation had not been updated either. Some random
vector would be better suggestion - and the truth is the vector should
be set so as not to be parallel (or near parallel) with any face normal
in the overall mesh.
(**) - clipka's fix was adopted in the yuqk fork. So it exists there,
but off the top of my head I don't remember what it is well enough to
suggest how to find it in the source via a search - and the yuqk code
base is many thousands of changes different than POV-Ray proper these
days, anyhow. What's found there probably won't exactly map to the
official code base, though the core of the change will be exactly what
you suggest for an update.
Date: 21 Aug 2024 15:45:00
Message: <web.66c64300cb3ec43fa5a6be6925979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
(a lot of stuff)
Well - that's a bummer.
Maybe the thing to do (if you can tolerate the parse time and additional memory
overhead) is a workaround by writing a macro to reinstantiate your mesh with a
different inside_vector.
I guess maybe you'd have to edit your mesh file to use a variable name as the
inside_vector.  Then pass your desired rotation to the macro, have it declare
the inside_vector as that variable, and #include the mesh file, then rotate the
mesh.
yuk(q).
Date: 22 Aug 2024 05:40:19
Message: <66c70783$1@news.povray.org>
Let's assume I understand how it works, and I just don't want to double
filesize with useless "bottom mesh" (which still leaves roundoff defects
but it's another another story). I did so with STL export for my
img2mesh, it works, but let's say representing flat plane with thousands
of triangles makes toad sad toad.
I want to cheat and avoid useless triangles, and with POVRay it works
well, until I try to rotate the mesh. And, since inside_vector is a
property of the object, I wished it will transform together with parent;
at least this sound logical. Unfortunately, my beautiful logic goes to
hell in the face of reality (btw, yesterday TV ad told me "diarrhea have
many faces", either they know something hidden about this reality, or
mess faces with faeces). That makes toad... you got the idea.
Ilyich the Toad
Date: 22 Aug 2024 05:49:21
Message: <66c709a1$1@news.povray.org>
> (a lot of stuff)
I was thinking a bit in similar direction previously - if I define
rotate vector in the beginning of the scene, and then use it as argument
to rotate the thing, then I may probably refresh my school math
knowledge and use the same vector to create inside one. Haven't tried it
though, since, obviously, even I can't stop people from rotating objects
the way they used to, i.e. first having an object, then rotating it, and
not vs (hm, Alice, just think of rotating object before having one).
Ilyich the Toad
Date: 22 Aug 2024 06:20:00
Message: <web.66c710a0cb3ec43f1f9dae3025979125@news.povray.org>
Ilya Razmanov <ily### [at] gmailcom> wrote:
> ... (btw, yesterday TV ad told me "diarrhea have
:D  I'm almost crying, I'm laughing so hard.
Might laugh so hard that I Schidt myself.  ;)
Thanks for that - lightened my morning mood, like "Spirit of Radio".
- BW
Date: 22 Aug 2024 06:35:00
Message: <web.66c713b2cb3ec43f1f9dae3025979125@news.povray.org>
No need to refresh any math - let POV-Ray do the heavy lifting.
If you want to end up at <x, y, z> starting from <x0, y0, z0>, then take <x, y,
z> and rotate _inverse_ the rotation of your object.
See this "recent" thread:
http://news.povray.org/povray.advanced-users/message/%3Cweb.65c535447ecd0aa1f9dae3025979125%40news.povray.org%3E/#%3Cwe
> Haven't tried it
Well, yeah - but we do all sorts of things like that here.
Because there is no camera or light or object - it's all just math.
So you're just defining a rotation matrix to use later . . .  ;)
(Maybe there's also a way to minimize that bottom mesh to use as few triangles
as possible to close it.)
- BE
Date: 22 Aug 2024 06:54:18
Message: <66c718da@news.povray.org>
Ah. I was hoping there is something simple I miss. No luck.
Ilyich the Toad
Date: 22 Aug 2024 07:38:53
Message: <66c7234d$1@news.povray.org>
Believe me, their concept of multifaced (or may be even multifaceted)
diarrhea scares even me. For 53 years I was living without thinking of
it, and now there is a risk to see it in a nightmare.
Ilyich the Toad
Date: 27 Aug 2024 18:58:16
Message: <66ce5a08@news.povray.org>
On 8/21/24 14:41, William F Pokorny wrote:
> and the truth is the vector should be set so as not to be parallel (or
> near parallel) with any face normal in the overall mesh.
Blast...
"...with any face normal in the overall mesh."
Should read:
"... with any [triangle] face in the overall mesh."
My apologies for any confusion caused.
The storm in my head is more often making out through my finger tips
days... :-(
Bill P.
