Hi folks,
I recently came across Paul Nylander's website at http://www.bugman123.com.
Marvellous images of 3D fractals rendered with Mathematica.
Exceptional rendering times and amazing images!
He also published some code to render Mandelbulbs in Povray.
Here is SDL for one of the Mandelbulbs:
// Mandelbulb - power 4 - Believe me the power 6 is a vision of hell!
// Adapted from original function for power 8 by Paul Nylander at
http://www.bugman123.com;
// Trace time on an AMD Ryzen7 Eight Core using 16 threads: 7 h 54 min with
max_gradient 1000
// Trace time on an AMD Ryzen7 Eight Core using 16 threads: 2 h 34 min with
max_gradient 200
#version 3.7;
global_settings { assumed_gamma 2.2 }
// #include "colors.inc"
// #include "textures.inc"
// #include "math.inc"
camera{
location <1.75,4,-5.5>
look_at <0.0, 0.0, 0.0>
up y
sky y
angle 25
light_source{<-20.00, 30.00, -20.00> color rgb < 1.0, 0.498039, 0.0 >} // color
Coral
light_source{<20.00, -30.00, 0.00> color rgb < 0.847059, 0.847059, 0.74902 >} //
color Wheat
#declare n=4;
#declare f=function(i,x,y,z,xc,yc,zc) {select(i>0 & x*x+y*y+z*z<4, 0,
sqrt(x*x+y*y+z*z),
f(i-1,pow(x*x+y*y+z*z,n/2)*cos(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+xc,
pow(x*x+y*y+z*z,n/2)*sin(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+yc,
-pow(x*x+y*y+z*z,n/2)*sin(n*atan2(z,sqrt(x*x+y*y)))+zc,xc,yc,zc))};
isosurface{
function{f(24,0,0,0,x,y,z)}
threshold 2
max_gradient 200 // found by Povray: 33566
contained_by{sphere{0,1.5}}
pigment{rgb 1}
//end
But a word of warning before you start:
DO NOT ACTIVATE any INC-FILE! When I did Povray crashes as soon as I start
rendering!
Has anyone an idea why Povray crashes?
There is only a warning in the Message Window that says something like
'iterations are not allowed in this function'.
Happy tracing - and when you do: grab a big snack and a big mug of coffee before
you do!
Droj
Download 'mandelbulb_power4.png' (1117 KB)
Preview of image 'mandelbulb_power4.png'
Subject: Re: Povray Mandelbulbs - Isosurface and max_gradient
Date: 7 May 2024 18:18:49
Message: <663aa8c9@news.povray.org>
> max_gradient 1000
> max_gradient 200
Hi, Droj !
Very interesting - thanks for sharing.
I've rendered this 800x600 image with max_gradient=1000 (No other
parameters was changed) on Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
(40 cores) for 2 min 19 sec and can't figure out how to get make it more
detailed.
Any suggestions, please !
YB
Download 'fract_01.png' (288 KB)
Preview of image 'fract_01.png'
Date: 7 May 2024 18:25:21
Message: <663aaa51@news.povray.org>
> max_gradient 1000
> max_gradient 200
Hi, Droj !
(40 cores) for 2 min 19 sec and can't figure out how to make it more
detailed.
YB
Date: 7 May 2024 19:35:07
Message: <663abaab@news.povray.org>
Agree with you - sometimes it looks horrible ...
camera{location <-2.5,5,5> look_at <-0.5,0,0.3> up z sky z angle 25}
light_source{20*z,1}
sqrt(x*x+y*y+z*z),
f(i-1,(x*x-y*y)*(1-z*z/(x*x+y*y))+xc,2*x*y*(1-z*z/(x*x+y*y))+yc,-2*z*sqrt(x*x+y*y)+zc,xc,yc,zc))};
isosurface{function{f(24,x,y,z,x,y,z)} threshold 0.5 max_gradient 1000
contained_by{sphere{<-0.5,0,0>,2}} pigment{rgb 1}}
YB.
Download 'fract_02.png' (163 KB)
Download 'fract_02_1.png' (117 KB)
Preview of image 'fract_02.png'
Preview of image 'fract_02_1.png'
> detailed.
> YB
Hi yesbird
as I can see you have no problem with the rendering time as I have.
You can increase max_gradient.
When I rendered it the max_gradient Povray found was 33566.
So give it a go.
Droj
On 09/05/2024 16:23, Droj wrote:
> So give it a go.
Hi, Droj.
Thank you, I will try.
YB
Date: 9 May 2024 11:44:09
Message: <663cef49@news.povray.org>
It took 15m59,185s for rendering with max_gradient=33566, and n=6,
but I see, that your image looks more smooth and pretty.
What's the secret ? Antialiasing, maybe ... Could you please post
all rendering parameters ?
This teddy bear don't looks like real daemon, but some sort of inferno
is present, no doubt ...
YB
Download 'mand_pow_6_1600x1200.png' (1117 KB)
Preview of image 'mand_pow_6_1600x1200.png'
Hi YB
Oh man you make me weep! 16 min with max_gradient=33566 ... if I try my image
will be finished next week.
Here are the settings of the ini-file I use:
Width = 1600
Height = 1200
Antialias = On
Sampling_Method = 1
Antialias_Threshold = 0.0010
Jitter = Off
Antialias_Depth = 9
Output_To_File = On
Output_File_Type = N
Display = On
Verbose = Off
Quality = 11
Input_File_Name =
Output_File_Name =
Initial_Frame = 0
Final_Frame = 0
Subset_Start_Frame = 0
Subset_End_Frame = 0
Test_Abort = On
Test_Abort_Count = 100
Have you ever seen Edvard Munk's painting 'The Scream'? It's disturbing but
Mandelbulb power 6 is worse.
Hope the ini settings will help.
Droj
Date: 9 May 2024 19:37:06
Message: <663d5e22@news.povray.org>
On 10/05/2024 01:04, Droj wrote:> Oh man you make me weep! 16 min with
Hi, Droj.
Please, don't cry: I noticed, that your setting are too 'aggressive':
; Antialias_Depth = 9
; Antialias_Threshold = 0.0010
See: https://www.povray.org/documentation/view/3.6.1/223/
making less depth and threshold can seriously improve performance with
almost the same quality.
Thanks for setting, you've saved a lot of time for me.
> Have you ever seen Edvard Munk's painting 'The Scream'?Yes, sure, this is a famous
painting, but I see something close to
Francisco Goya. :)
Happy poving,
YB
Download 'fract_03_800x600.png' (95 KB)
Preview of image 'fract_03_800x600.png'
Hi, Droj.
Yes, sure, this is a famous painting, but I see something close to
Francisco Goya. 🙂
Happy poving,
YB
Date: 9 May 2024 20:10:53
Message: <663d660d@news.povray.org>
Hi, Droj.
Thanks, you've saved a lot of time for me.
Francisco Goya. 🙂
Happy poving,
YB
Download 'fract_03_1024x768.png' (192 KB)
Preview of image 'fract_03_1024x768.png'
Date: 9 May 2024 20:15:16
Message: <663d6714@news.povray.org>
Hi, Droj.
Francisco Goya. 🙂
Happy poving,
YB
Hi YB
Yes, you are right. I will lower the aa and see what happens.
> Francisco Goya. 🙂
Yeah, Francisco Goya would have been my next choice.
Could you please share the code for your fractal03.png? It's amazing!
And do you have an idea how to code power 3, power 5 and power 7?
Happy tracing
Droj
Date: 10 May 2024 14:21:17
Message: <663e659d$1@news.povray.org>
With pleasure - see attachment :).
Did not thought about it, but if you have some cool ideas, please feel
free to send me scenes and I will render them on my fast server.
PS:I am mostly working at the night and sometimes afraid to open newly
rendered fractal image, feeling like opening door to inferno :).
All the best,
YB
Download 'fractals.pov.txt' (3 KB)
Download 'povray.ini.txt' (3 KB)
Hi YB
thank you for sharing.
I realised that your camera position is on positive z-axis while mine is on
negative z-axis. That explains why some of your images look different.
I also took your advice and changed my 'aggressive' aa settings - and yes,
rendering times decreased a lot. Thanks for putting me on the right track.
Yes, see attachment - 3 fractal beasts - well, I am not too happy with it as the
fractals look a bit 'truncated'. I can't perform any experiments with the code
like use larger contained_by values. Maybe, you can with your excellent server!
Same here: Seeing the image slowly evolving at night is somtimes like watching
the movie 'Hellraiser' :))
Happy tracing
Droj
PS: Did you try to rotate any of the fractals? I would like to know your
experience.
Download 'mandelbulb_pow3_5_7.pov.txt' (3 KB)
Date: 11 May 2024 19:44:42
Message: <664002ea@news.povray.org>
On 11/05/2024 22:27, Droj wrote:
Hi, Droj.
Always welcome :).
I've played width them a little, results in attachments. I like 'pow3'
most of all. To make them more smooth and less boring I changed
threshold and increased AA.
> experience.
No, but idea is interesting - will try soon. Also, I guess, threshold
animation can give interesting results (two 640x480 attached), need to
try it too, when I will have a break in my present project.
If you have another set of beasts, I can also render them with pleasure.
Good luck with explorations,
YB.
Download 'mandelbulb_pow3_5_7_mod_pow3_tr1.8.png' (291 KB)
Download 'mandelbulb_pow3_5_7_mod_pow5_tr2.png' (330 KB)
Download 'mandelbulb_pow3_5_7_mod_pow7_tr1.png' (325 KB)
Download 'mandelbulb_pow3_5_7_mod_pow7_tr2.png' (117 KB)
Download 'mandelbulb_pow3_5_7_mod_pow7_tr05.png' (145 KB)
Download 'mandelbulb_pow3_5_7_mod.pov.txt' (3 KB)
Preview of image 'mandelbulb_pow3_5_7_mod_pow3_tr1.8.png'
Preview of image 'mandelbulb_pow3_5_7_mod_pow5_tr2.png'
Preview of image 'mandelbulb_pow3_5_7_mod_pow7_tr1.png'
Preview of image 'mandelbulb_pow3_5_7_mod_pow7_tr2.png'
Preview of image 'mandelbulb_pow3_5_7_mod_pow7_tr05.png'
You guys may want to check out Inigo Quilez's page, and look at the "Fractals &
complex dynamics" section.
https://iquilezles.org/articles/
Articles:
Continuous iteration count
The M1 bulb of the Mandelbrot set
The M2 bulb in the Mandelbrot set
Area of M1 in the Mandelbrot set
The symmetry of the Mandelbrot set
Introduction to the Mandelbrot set
They might offer some insights into how to speed up your renders.
- BW
hi,
a less "hellish" bulb, derived from the work of Chris M. Thomasson.
mp4, approx 12M: <https://photos.app.goo.gl/Us3fXASWaMPWDEhc9>
regards, jr.
"jr" <cre### [at] gmail com> wrote:
> hi,
> regards, jr.
Hi jr,
thanks for the link.
Looks like 'The Ghost in the Bottle' ;)
regards, Droj
> Articles:
> - BW
Hi Bill,
thank you for the link to Inigo's website.
I read some of his articles and understood - zilch.
The problem I had with these Mandelbulbs was that - what Paul Nylander called
'inefficient code' - it gave Povray a really hard time.
And when I added an include file Povray crashes as soon as I started rendering.
Well, I guess I put that Mandelbulb topic on ice until I have a more powerful
computer.
Regards, Droj
hi,
[OT] an idle search on this found <https://www.youtube.com/watch?v=jt-hkyxDJQg>.
regards, jr.
