POV-Ray : Newsgroups : povray.general : Lighting used by the Wolfram Server Time
31 May 2026 08:14:04 EDT (-0400)
  Lighting used by the Wolfram (Message 1 to 10 of 12)
Subject: Lighting used by the Wolfram
Date: 21 Jan 2024 11:20:24
Message: <65ad4448$1@news.povray.org>
I've tried to reproduce the lighting model used at Wolfram.
I used this example : "Phyllotaxis Spiral Pattern on a Sphere"
<https://demonstrations.wolfram.com/PhyllotaxisSpiralPatternOnASphere/>
I can't do any better than the attached image.
There are a few explanations here :
<http://reference.wolframcloud.com/language/tutorial/TheStructureOfGraphicsAndSound.html#20392>
Maybe some ideas ?
Kurtz le pirate
Compagnie de la Banquise
Download 'psp01.jpg' (54 KB)
Preview of image 'psp01.jpg'
Subject: Re: Lighting used by the Wolfram
Date: 22 Jan 2024 08:30:00
Message: <web.65ae6dcb31196ee21f9dae3025979125@news.povray.org>
> Maybe some ideas ?
I gave it a go, after reading a few threads that seemed to quote what the
lighting layout is, but all I got was something a lot worse that you.
Maybe someone has a lighting demo online, or you could post to a mathematica
forum and have them make you a few test renders to analyze.
- BW
Date: 22 Jan 2024 09:51:09
Message: <65ae80dd@news.povray.org>
On 21.01.2024 19:20, kurtz le pirate wrote:
> Maybe some ideas ?
Shadowless? Maybe trying some negative light?
Ilyich
Date: 22 Jan 2024 10:28:07
Message: <65ae8987$1@news.povray.org>
On 22/01/2024 15:51, Ilya Razmanov wrote:
> Shadowless?
already used in my sample
hum... definitely not
Kurtz le pirate
Date: 22 Jan 2024 10:37:40
Message: <65ae8bc4$1@news.povray.org>
I've explored (not everything, of course)
<https://mathematica.stackexchange.com/> and
<https://community.wolfram.com/> and I found nothing.
Only a nut like me would ask that kind of question.
Kurtz le pirate
Date: 22 Jan 2024 12:40:00
Message: <web.65aea85c31196ee21f9dae3025979125@news.povray.org>
https://mathematica.stackexchange.com/questions/119804/what-is-the-default-lighting-in-3d-graphics
https://mathematica.stackexchange.com/questions/27616/what-is-the-default-colorfunction-for-3d-plots
Date: 23 Jan 2024 13:00:00
Message: <web.65affd8831196ee216bed5696e741498@news.povray.org>
> Hi,
> Maybe some ideas ?
> Kurtz le pirate
Hi Kurtz. I tried to replicate the example on the reference page. (Their
explanation was confusing, but I think I got the gist of it.) Here's my attempt:
// +fn +f +a0.03 +am1 +r3 +w640 +h480
#version 3.7;
global_settings{assumed_gamma 1.0}
background{rgb 1}
camera{
 right x*1.333 up y
 location <5, 7, -9>
 look_at 0
 angle 35
#macro Light(Pos, RGB)
 light_source{
  Pos, rgb RGB
  parallel
  point_at 0
  shadowless
union{
 #local Boost = 0.3;
 Light(<0, 1, 0>, x+Boost)
 Light(<1, 1, 0>, y+Boost)
 Light(<1, 0, 0>, z+Boost)
 rotate <0, 10, 10>
union{
 sphere{<-1, 0, -1>, 1}
 sphere{<1, 0, -1>, 1}
 sphere{<-1, 0, 1>, 1}
 sphere{<1, 0, 1>, 1}
 pigment{rgb 1}
 finish{brilliance 1.5}
#include "shapes.inc"
Wire_Box_Union(<-2, -1, -2>, <2, 1, 2>, .004)
Download 'wolframlightingtest.jpg' (21 KB)
Preview of image 'wolframlightingtest.jpg'
Date: 23 Jan 2024 13:05:00
Message: <web.65afff5b31196ee216bed5696e741498@news.povray.org>
"Samuel B." <stb### [at] hotmailcom> wrote:
> my attempt
The colors and gamma are all wrong, partly due to the 'Boost' value. You can
change assumed_gamma to 1.3, which helps, but still isn't quite the same.
Date: 24 Jan 2024 04:24:45
Message: <65b0d75d$1@news.povray.org>
> [snip]
Hi Samuel,
Good job too.
I made nearly the same code as you ;)
And still not the same look.
With a link given by BW, i found more infos about lightning :
Graphics3D [
 Sphere[],
 Lighting -> {
  {"Ambient", RGBColor [0.40, 0.20, 0.20] },
  {"Directional",RGBColor [0.00, 0.18, 0.50],ImageScaled [{2, 0, 2} ]},
  {"Directional",RGBColor [0.18, 0.50, 0.18],ImageScaled [{2, 2, 3} ]},
  {"Directional",RGBColor [0.50, 0.18, 0.00],ImageScaled [{0, 2, 2} ]},
  {"Directional",RGBColor [0.00, 0.00, 0.18],ImageScaled [{0, 0, 2} ]}
I didn't really understand the ImageScaled[] syntax, but even with these
parameters, the rendering is different.
Kurtz le pirate
Date: 24 Jan 2024 06:35:00
Message: <web.65b0f4bf31196ee21f9dae3025979125@news.povray.org>
As I understand it, ImageScaled is used as a multiplier, and is a value based on
the screen coordinates of the image.
So, if you had a sphere at <4, 0, 0> and it was right at the edge of the screen,
the x coordinate of ImageScaled would be 4.   Same with y.
So it seems to be like <image_width, image_height> only in POV-units perspective
screen space.
https://reference.wolfram.com/language/ref/ImageScaled.html
- BW
