POV-Ray : Newsgroups : povray.general : Why is radiosity importance set in the default{} block? Server Time
12 Mar 2026 06:28:38 EDT (-0400)
  Why is radiosity importance set in the default{} block? (Message 1 to 6 of 6)
Subject: Why is radiosity importance set in the default{} block?
Date: 17 Jan 2024 03:29:27
Message: <65a78fe7$1@news.povray.org>
Does anyone know why the global 'radiosity { importance <float> }'
setting ended up in the default{} block rather than in 'global_settings{
radiosity {} }' block along with the other global radiosity settings(a)?
I'm likely going to dump the 'default{}' block altogether in my yuqk
fork(b). Not much in the way of doing it - except, there is this global,
radiosity, importance option sitting in there. It seems out of place to
me and I don't immediately see a reason for the set up in the internal
code...
Am I missing reason(s) it made sense for this importance option alone of
the global radiosity settings to be in the default{} block?
Thanks.
Bill P.
(a) - Or, as one of the effective ini / flag radiosity globals?
(b) - There are too many side-effects to having 'major version defaults'
which are not in fact fixed version defaults.
Subject: Re: Why is radiosity importance set in the default{} block?
Date: 17 Jan 2024 13:24:40
Message: <65a81b68$1@news.povray.org>
> code...
> Thanks.
> Bill P.
My guess :
importance is an object property, just like a pigment, texture or
finish. You set it globally in the default block to set the default
importance value to be used by most objects, and you set it per object
to a larger value for relatively small and bright objects.
The default block is used to set some default properties for objects
that don't have explicit properties.
Originally, it was used to set a default texture or texture component
such as pigment or finish. It have been extended to also be able to set
default interior, SSLT and radiosity properties of objects.
Date: 17 Jan 2024 22:43:30
Message: <65a89e62@news.povray.org>
> code...
default{} is also used for textures, and I find sometimes it useful to
change the default texture as I move onto different parts of a scene.
That capability sounds useful for default radiosity importance as well,
and global_settings{} does not allow that flexibility.
Date: 18 Jan 2024 06:59:17
Message: <65a91295@news.povray.org>
On 1/17/24 13:24, Alain Martel wrote:
> My guess :
I think that's a pretty good guess as to how it came about. To my mind,
it is a global radiosity setting which changes how radiosity works
overall. Expect I'll move it to global_settings { radiosity{} } in yuqk.
Understand.
No. The only options currently available within default{} are:
texture{}, pigment{}, normal{}, finish{}, radiosity{ importance <0..1
float> } and camera{}.
There is an open github issue requesting that default{} support
interior{}, but it's never been implemented(a):
https://github.com/POV-Ray/povray/issues/246
Port of FS319 - Add interior to #default directive #246
No SSLT and radiosity properties have been added to any official POV-Ray
releases of which I am aware. Maybe it's been done somewhere?
Bill P.
(a) One of the things a little clunky with v3.8 is all objects now have
an interior{} created. I think clipka did this to support the finish
level fresnel work which 'requires' a default ior of >1.0 (He tended to
use 1.5 and behavior is somewhat tuned for 1.5). However, today, the
interior default ior is 1.0 - and we are carrying around a bunch of
interior{}s we don't need.
Aside: Somewhat on the github request #246. It should be we can use:
default { finish { ior 1.5 } }
to default the automatically created interior's IORs. However, something
either wasn't maintained correctly over time for backward compatibility
or never implemented correctly. I suspect an order of operations problem
in the object post processing, but who knows. The code below works:
object {
   Iso99
     pigment { rgbt <0,0.1,0,0.9> } finish { ior 1.5 } }
object {
   Iso99
     interior {}
(yuqk is on a path to two IORs. One for interiors / refraction in the
interior{} block. One for surfaces and reflection related effects in the
finish{} block. Started the work a long while ago now... Someday!)
Bill P.
Date: 18 Jan 2024 07:12:53
Message: <65a915c5$1@news.povray.org>
The default/global, radiosity, importance value isn't propagated onto
the objects until Parser::Post_Process() - and then only if there is not
already an importance setting for the object - or the parent-object of
the object. In other words, being able to change the default/global,
radiosity, importance value while parsing is of no use. The last set
value wins for the render.
Aside: the global_settings{} block can be used multiple times too, but
not everything can being updated once it's set.
   global_settings { assumed_gamma 1 radiosity{} }
   global_settings { noise_generator 3 } // This OK
   global_settings { assumed_gamma 2.2 } // This ignored. Warning issued.
On the default{} block I understand how handy it can be. I use it.
However, it's not something we should continue to enable in v4.0 -
especially if we continue to allow the shortcut texture specifications(a).
(a) - I was going to pull these in yuqk, but I agree they are handy
enough to stay.
For a larger stable ecosystem / library of include-able stuff, we need a
methods to access the version defaults - with 100% certainty.
Today one use, anywhere, of default{} and our #version switching is
thereafter broken (there's a warning we have probably all seen, but...).
And, this just one of the issues with default{}. Some I've mentioned,
some not - like there being an issue with multiple uses of default{}
when some exist because of (header include) +hi use.
Aside 2: I wondered while thinking about / looking at default{} how far
back the keyword was enabled. All the way back to v1.0 it turns out!
Anyhow. Dumping default{} in yuqk / v4.0 doesn't preclude some other way
to carry 'current' settings into created objects / textures while
parsing. But, something new would need to be better than what we can
already do with IDs and/or macros I think.
Bill P.
Date: 19 Jan 2024 06:40:26
Message: <65aa5faa@news.povray.org>
Mentioning the bit aboce got me thinking again about global_settings{}s.
There are things with it too which should probably change in any v4.0.
- Maybe it should only be allowed a single use in any given scene for one.
- The global noise_generator settings is deceptive because it's mostly
not true. The setting affects some inbuilt patterns, but not much else.
And that global noise generator setting is problematic to any global /
library ecosystem of include-able stuff. Work up a good agate base
texture with the default noise_generator(a), hand it to a user who has
changed the noise generator in their global_settings{} and that texture
will behave differently...
- If not single use limited there are settings which should act like
assumed_gamma in not allowing settings to be changed, which today do
allow settings to be changed...
- In official POV-Ray releases where using subsurface that
global_settings block needs to be specified once at the top (closely
following #version). There's a related github issue still open.
   https://github.com/POV-Ray/povray/issues/122
- The irid settings should likely be pushed into the irid feature.
Anyhow. :-)
Bill P.
