(v3.8.0 beta 1 in Windows 10)
I was playing around with #ifdef recently; just experimenting.
I put a nonsense string expression into it-- not actually defined anywhere-- to
see what would happen:
#ifdef("htenneK")
....do this...
#else
....do that...
Instead of issuing an error message or even a fatal error as I half-way
expected, it actually fell through to the *first* clause successfully. Without
the double quotes, it works as expected and falls through to the #else.
Should #ifdef behave this way? Is the first double-quote causing some kind of
unforeseen problem for the parser?
> #ifdef("htenneK")
> ....do this...
> #else
> ....do that...
> #end
As I see it, #ifdef() test the existence of an entity.
With the quotes, the string DO exist, IS defined, even if it only exist
locally. So, the test returns true.
Without the quotes, it test if the variable exist, and, if it wasn't
#declare beforehand, will return false.
So, I think that it behave as it should.
hi,
Alain Martel <kua### [at] videotron ca> wrote:
> Le 2023-03-14 ΰ 08:43, Kenneth a ιcrit :
> > #ifdef("htenneK")
agree, ref: <https://wiki.povray.org/content/Reference:Strings#String_Literals>
regards, jr.
> locally. So, the test returns true...
Sorry for the delay in responding; I had to think about this behavior for
awhile.
I guess it must certainly be so, and I sort of sense the logic of it...but it
does seem odd: The string expression is considered to have been created WITHIN
the #ifdef() itself? What seems strange to me is that #ifdef is not the same
'kind' of code construct as a #declare or #local, which would otherwise be
required earlier for any other kind of entity or variable for #ifdef to operate
on. Although, a string expression is not really a 'variable'; here, it exists as
a 'literal'. Yet a 'naked' string literal cannot be used by itself as a line of
code; that produces an obvious fatal error.
So is a string expression the only kind of 'thing' that #ifdef sees as defined?
Nope. Even an arbitrary float value behaves the same way:
#ifdef(7.6)
...do this... // success
#else
...do that...
To me, this would seem to be an unexpected trap, waiting to be 'exploited' by
mistake. I'm not sure how such a mistake might be made by a user, but still...
My two-cents ;-)
Well, it's defined by you, and the parser, and yes, once the parser hits that
closing ", then it's defined, and at that point, when the closing ) of the if
def gets hit - the conditions for TRUE are satisfied.
> on.
But you're not declaring the value of a variable to be the string literal, any
more than you're using a direct string literal in text {} or str {} or any other
operator.
> #ifdef(7.6)
> #else
> ...do that...
> #end
This is the way POV-Ray works with "Boolean" values (and IIRC, so do other
computer languages) O is false, and any non-zero value is true.
Send the str value of true to debug and see what it is. It's a common shorthand
to use 0 and 1 for t&f or the setting of "flags" in code.
I often (ab) use this tool/trick to save some typing when doing loops. If I'm
starting a loop at zero, then all I have to do is #ifdef(loopVariable) instead
of #if (loopVariable > 0). Stuff like that.
(And to head off your purely theoretical complaint, 7.6 IS a number, and so it
IS defined when that ) closes the #ifdef statement.
You might try that with 0 and see what happens, but remember that we have to
have SOME way of signifying certain states, and we don't have proper variable
type casting in POV-Ray, so we rely on numerical values to represent
"undefined"/"null", NaN, and likely others.
Since we also have 2 parsers, you're likely to find other "surprises" in the
function parser behaviour. ;) )
Also keep in mind that some variables that _were_ declared, will not be any more
- such as temporary macro arguments, loop counters, #local variables in include
files, etc.
Other things might be defined, or have defined values other than what you
thought they were, depending on how they've gotten to the point in the code that
you're at. jr and Cousin Ricky have correctly pointed out that you can pass
things into macro calls "by reference" rather than "by pointer".
http://news.povray.org/povray.advanced-users/message/%3C5a02fe60%241%40news.povray.org%3E/#%3C5a02fe60%241%40news.povra
y.org%3E
Simply having a short script that sent all the various test results to #debug
would be a good reference, esp for reminders/new users (and testing new
versions).
> #ifdef(7.6)
> #else
> ...do that...
> #end
> My two-cents π
I agree with three-cents - and now we have five! :-)
I took a quick look just now and v3.7 works as expected in some quick
testing in that only identifiers are OK - which I do believe is the intent.
So, I'd say this is another v3.8 beta 2 bug.
It's something with the changes in parsing, but it must have happened
prior to Christoph's back off point for the v3.8 parser too.
Bill P.
> > as defined?
> > #ifdef(7.6)
> > #else
> > ...do that...
> > #end
> common shorthand to use 0 and 1 for t&f or the setting of "flags" in code.
Yep, I get that-- if the #ifdef is seeing it as boolean, that is. But here's a
weird thing (well, weird to me at this point of my fuzzy understanding):
#ifdef(true)
is apparently seen as NOT defined, and falls through to the #else. Of course,
I'm not even sure if that construct makes any sense code-wise or syntax-wise.
> You might try that with 0 and see what happens...
Strangely(?), this has the same result as above: #ifdef(0) falls through to the
first clause. So maybe the 'boolean' explanation doesn't hold for #ifdef?
oops, sorry---
"Strangely(?), this does NOT have the same result as above: #ifdef(0) falls
through to the first clause" (and so is seen as defined.)
> #ifdef(true)
And you get that to work without a warning?
My few test cases resulted in:
#ifdef ("String") returns true.
#ifdef (1) returns true.
#ifdef (0) returns true.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 13:
Parse Warning: Tried to test whether a reserved keyword is defined. Test result
may not be what you expect, and may fundamentally differ in future
versions.
#ifdef (true) returns false.
#ifdef (tau) returns false.
#ifdef (pi) returns false.
#ifdef (pigment) returns false.
#ifdef (if) returns false.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 15:
versions.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 17:
versions.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 19:
versions.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 21:
versions.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DefinedValues.pov" line 32:
Note that, "Test result may not be what you expect...." because it's a keyword,
not a proper variable.
I also tried:
#ifdef (0a) #debug concat ("#ifdef (", "0a", ") returns true. \n") #else #debug
concat ("#ifdef (", "0a", ") returns false. \n") #end
and get "No matching ), undeclared identifier found instead."
>> 'exploited' by
>> still...
>> My two-cents π
> I agree with three-cents - and now we have five! π
Alright.
A long time ago I created a bunch of statically linked(a) versions of
POV-Ray going back through time. Anyhow. Used these to trace the
introduction of the str/num OK in #ifdef test bug.
Bill P.
(a) - This the old timer's container alternative.
commit 58d51f4911dce5e9021c62b30983902b0aab8b04 str,num OK
Author: Christoph Lipka <c-l### [at] users noreply github com>
Date: Sun Mar 1 02:05:39 2015 +0100
Fixed scrambled warning messages.
// There are only five commits between the one up top and the bottom
// one below. My BIG bet is on the following commit being the problem,
// but I don't have a static compile of it or the one prior to it to
// be sure.
commit a94c1ab61aeb2aa483aa3636736ff1e24ebd8b78
Date: Sun Mar 1 02:03:14 2015 +0100
Implemented tuple extensions to #declare and #local.
commit 3f56c5fb8a54998067a217e54101c799756510b4 Complains.
Date: Tue Feb 3 16:48:11 2015 +0100
Fixed Unix build errors.
> > here's a weird thing (well, weird to me at this point of my fuzzy
> > understanding):
> > #ifdef(true)
I didn't think to look. But you're right, I get the same warning:
"Parse Warning: Tried to test whether a reserved keyword is defined..." etc.
So with a *properly*-working #ifdef instead of the current flaw in v3.8.0 beta 1
or 2 'official' versions, I'm still curious about something you mentioned: Is it
supposed to indeed be a simple boolean comparison? Or is it's operation more
complex than that?
> complex than that?
Wellll.......
I suppose it depends upon what one wants the language to do or thinks it
properly "ought" to do...
One could argue that a keyword is, in some sense, "defined", and as the warning
message states, reserved.
My example (probably me reading the whole post in a haze) of 0 / 1 was really
for _#if_, not #ifdef.
I'm sure that "Real programmers" have a better take on this, and sounder reasons
than I could present.
Aside:
Rather than having to write a whole ifdef/else/end statement for every case I
wanted to test, I had the strong urge to write a macro and maybe use ParseString
to make it work, but we don't have a way to test for data type, isolate
keywords, or any of the tools to write that sort of "meta" code.
William F Pokorny <ano### [at] anonymous org> wrote:
> Alright.
> [clip]
> be sure.
Given the current mix of flaws, the use of a string literal still has me
scratching my head...
#ifdef("...string...")
Alain's and JR's explanation of the expected behavior seems valid; but with a
properly-working #ifdef, should the comparison fail outright (fatal error)? Or
should it still be seen as defined? I'm mostly just curious ;-)
One might suggest:
"Expected variable name, literal value found instead."
-or- "It is what is is." ;)
The correct answer for me has always been OPTIONS.
When everything gets locked into a one-right-answer only format, it usually just
creates new problems in the process of "solving" the old.
I was just reading some old threads concerning this type of thing, and the
degenerate triangle warning vs 0-length fatal error for cylinders was brought
up.
For some scenes it could be a critical thing to stop the render. For others,
you might want to just ignore them all. Usually these things are addressed by
the users with workarounds, but why not have a configuration file that states
how to handle these cases, an additional argument for the object instantiation
that provides for individual control, or an error-trapping mechanism (with error
code) that allows the user to write their own programmatic/logical solution
based on further testing and flow control, and allows the user to issue better
warnings that the cryptic ones currently hard-coded in source?
>> Alright.
>> [clip]
>> be sure.
I'm a little further along in looking at this. It's looking messy.
I think we need to start with the fact #ifdef, #ifndef and #undef have
ALWAYS been #ifIdDefined, #ifIdNotDefined and #undefineId. Going back to
the v3.6 documentation we have:
2.2.2.6.2 The #ifdef and #ifndef Directives
The #ifdef and #ifndef directive are similar to the #if directive
however they are used to determine if an identifier has been previously
declared.
IFDEF_DIRECTIVE:
#ifdef ( IDENTIFIER ) TOKENS... [#else TOKENS...] #end
IFNDEF_DIRECTIVE:
#ifndef ( IDENTIFIER ) TOKENS... [#else TOKENS...] #end
If the IDENTIFIER exists then the first group of tokens is parsed
normally and the second set is skipped. If false, the first set is
skipped and the second set is parsed. ...
So... The up front, not so good, news is the behavior of at least the
#ifdef and #ifndef keywords was partly changed back in March of 2015.
Intentional or accidental? It's not mentioned as an intended change
anywhere I have seen - and I still don't understand how it happened even
with some time reviewing the changes when it happened.
Christoph went on to add a bunch of inbuilt keywords to be considered
'defined' sometime after late November 2018 - which makes me begin to
think he too might have been considering these *def keywords in the
c/c++ coding, macro test sense.
The few 'keywords' I've tested these generate a warning in at least some
versions of POV-Ray. But it's weird, keywords NOT returning immediate
numbers or strings are also considered 'defined' in these versions
though they are in fact arbitrary SDL keywords.
Even this worked in the pre-backed off v3.8 release parser:
#ifdef(#declare V=99;#undef V)
Though without some other mistake it would usually die with a later
unmatched something parsing fail. That said it's not hard to get it to
parse clean - say with an added #if(). I will always die if somebody
tries use the undef'd V.
So, much more was being supported as testing true in povr/v4.0, but
still not some things like raw vectors. Though things like x,y,z are OK.
Christoph backed up the v3.8 parser and again lost the inbuilt keywords
as "defined". I do not know the reasons for the parser backup, but
perhaps this issue it - or big part of it. I don't know.
I do know, I've got a mess with these in the povr parser given my branch
point... :-(
When I test v3.7, v3.8b2 and my povr(v4.0?) code I get:
v3.7
GOOD_ID --> This is a valid ID. (ifdef returning true)
GOOD_ID --> This is a valid ID. (ifndef returning false)
BAD_ID --> This is NOT a valid ID. (ifdef returning false)
BAD_ID --> This is NOT a valid ID. (ifndef returning true)
"STRING" --> Other than an ID. (ifdef returning false)
"STRING" --> Other than an ID. (ifndef returning true)
"" --> Other than an ID. (ifdef returning false)
"" --> Other than an ID. (ifndef returning true)
1.23456 --> Other than an ID. (ifdef returning false)
1.23456 --> Other than an ID. (ifndef returning true)
0 --> Other than an ID. (ifdef returning false)
0 --> Other than an ID. (ifndef returning true)
pi --> Other than an ID. (ifdef returning false)
pi --> Other than an ID. (ifndef returning true)
--> Other than an ID. (ifdef returning true)
v3.8b2
"STRING" --> Other than an ID. (ifdef returning true) ***
"STRING" --> Other than an ID. (ifndef returning false) ***
"" --> Other than an ID. (ifdef returning true) ***
"" --> Other than an ID. (ifndef returning false) ***
1.23456 --> Other than an ID. (ifdef returning true) ***
1.23456 --> Other than an ID. (ifndef returning false) ***
0 --> Other than an ID. (ifdef returning true) ***
0 --> Other than an ID. (ifndef returning false) ***
povr & likely v4.0 and other misc releases before parser backup
pi --> Other than an ID. (ifdef returning true) ###
pi --> Other than an ID. (ifndef returning false) ###
The last case with empty parens is an exposure back to v3.7. In a lot of
code the effective fall through at the #if____ will cause later parsing
problems, but the error are of the more unhelpful sort. It would be best
if the empty parens were themselves a parse error. I 'think' it's
probably also possible to fix the following parsing issues with another,
cleaning syntax (actual bad-syntax) sort of mistake.
My feeling is the right thing to do would be to take the behavior back
to what it has always been with the nearer term v3.8 release. If we want
the most backward compatibility this it. Further, the extra now being
changed currently in the v3.8 code is not consistent with respect to
things like pi - which to the parser is an immediate value of pi. And
datetime would be an example of an immediate string which would test
true, you'd think, if "string" does.
What to do... I could spend a lot of time trying to figure out the
history here, but I think the current state not completely tenable since
2015...
We need functionality which deals only with IDs.
We, perhaps, need some sort of what is in the parenthesis is 'defined'
functionality too, but the generic sort being allowed or not seems
questionable to me. Are people already using this functionality?
With povr I might do something drastic like create 'id' versions and and
'defined' versions - with all new keyword names so users would be forced
to look at potential problems with interpretation and behavior given the
old keywords wouldn't work!
Hmm... We do have new to v3.8 the local and global dictionaries. Could I
just dump the #ifdef and #ifndef keyword for something based on those. I
can't remember at the moment how they work.
Don't know... Whatever it is in povr, afraid at the moment it'll be a
lot of work - because I'll need to digest a lot of the parser code.
Guess it's time to do my taxes... :-)
Bill P.
I think you're going to run into the same hamstringing that an over-concern
about backwards compatibility inevitably results in. If any of this stuff is
going to be fixed, there needs to be a clean break, and a sane, logical,
rational, basis for moving forward.
That looks fine - given someone may have some reason to do that. Some sort of
quick bypass workaround.
> I will always die if somebody tries use the undef'd V.
Yes. Because V is for Victory, and undefining it results in Failure. :P
> 2015...
I use and abuse whatever I can find as a workaround for lack of functionality.
I absolutely don't mind rewriting code to perform with a new and better version.
Currently trying to implement some geometric testing code, it's becoming
increasingly clear that we have plenty of raytracing capability, and missing
programming code to make coding the scenes easier and more capable.
Example:
I'm testing for an intersection. What do I do in SDL if there's a) none, or b)
more than 1? Or if I'm looking at parallel or skew lines. Or the user or the
circumstances require the endpoints of a line to be the same (a point)?
I'm dreaming up workarounds like mixed arrays with succeed/fail flags followed
by the variable number of results (line/line | line/circle | circle/circle).
For data type cast, I'm thinking I need a 2D mixed array with the [0] holding
the data type as a string, and the actual data in the 1[].
It would be so much easier to code these things (and faster) if we had some
tools to deal with variable results.
null, NaN, variable type detection, error trapping, etc.
It would make testing with #ifdef a little more sane if #ifdef (keyword)
returned a versatile value that I could make use of in a broad number of
circumstances.
First - I think POV-Ray needs to sort out keywords vs values, scalars vs
vectors, vs parse/render/function space variable names. It's confusing, and is
contributing directly to the mess you're trying to sort out. You can't. It's
all inextricably mixed. clipka correctly pointed out that all of this stuff
needs to get disentangled in the parser.
So, I would say that "if" should return a value that denotes keyword,
whereas "pi" should return a value that denotes a reserved value. "CONST", or
whatever that compiler one is. "PRAGMA"
It's "nice" that I can swizzle things all over the place between vectors and
colors, etc. But it makes for lazy / bad programming practices. Better the
ability to recast a value from a scalar to a vector to a color, etc.
It would probably take me a month, tops, to adapt to the new requirements, and
I'd be able to write better, shorter, more easily understood and maintained
code. Further, if there were sufficient programmatic capability, "fixes" for
old scenes could be coded, much like TOK and I code custom functions and macros
to handle pow (0, 0), factorial, N choose M, mod () crossing the origin, etc.
Just change the keyword in the old scene to a capitalized version ("We love you,
jr!") and boom - you have a macro that could possibly handle a lot of the
backward compatibility with a simple find/replace on the old scene file.
The first rule of holes is: when you find yourself in one, stop digging.
The second is: climb out.
I'd rather suffer now, and profit later.
Thanks for doing such a detailed series of tests and an examination of the
various code versions! I can imagine that it was a lot of drudgery.
> [clip]
> ...but the generic sort being allowed or not seems
> questionable to me.
I agree; IMO, #ifdef etc. should adhere to the much more strict behavior
described in the docs. Admittedly, I am not as sophisticated a user of these
functions as some others are, but the current behavior seems quite lax and could
lead to unintended scene errors or coding 'mysteries'.
And I would be happier if my silly string-literal example produced a fatal
error! Otherwise, I can't imagine a scenario where a 'naked' string would even
be used there.
I also think that using an *actual* zero or a float (while having some meaning
as boolean values) does not really represent a 'valid ID' as per docs, and so
should fail outright as well. My opinion ;-) HOWEVER... I can see a scenario
where 0 or 1 could be used simply to test whether a scene's specific #ifdef
construct is working properly or not-- in other words, without relying on an
actually-defined identifier for the test. On the other hand...it would be a
simple matter to pre-define a temp dummy identifier for the same use.
Actually, it's not clear to me why any keywords at all would or should be valid
'parameters' for an #ifdef comparison-- but I'm rather naive at present about
what might be such a useful coding scenario. For example, my own rather
meaningless(?) test of
#ifdef(true)
appears to be a flat-out mistaken use of the function, since the comparison will
(or rather, *should*) always invoke the first clause, never the #else. In other
words, this construct should use #if or #while or #switch or etc, not #ifdef.
I am obviously not seeing why a keyword could be meaningfully used there.
In general, I think that most of not all of the non-fatal error messages re:
#ifdef should be changed to fatal-- if only as a guard against using entities
that don't belong there and need changing. Personally, I'm lazy about taking
note of non-fatal messages.
hi,
> 'parameters' for an #ifdef comparison ...
one use I see, though I have never tried/used it, is determining whether a given
keyword (already) exists in the POV-Ray version doing the parsing; if it worked
for, eg, 'tau'. also, fwiw, agree that parsing (generally) should be "strict".
regards, jr.
> One might suggest:
> up.
Or even a global_settings entry, such as :
Ignore_degenerate true|false //default to false
> > be valid 'parameters' for an #ifdef comparison ...
> for, eg, 'tau'.
Ah! Yes, I see the usefulness of that. Thanks. That totally escaped me. My
#ifdef(true) example was a bad choice to illustrate the situation.
> > even be used there.
I hit the 'post' button too soon :-/
> be used there.
Well, on 2nd thought, I do see at least one special-case string use: To try to
easily determine if a particular #include file is actually present in a scene.
Like:
#ifdef("my sphere file.inc")
or maybe a no-string version: #ifdef(my sphere file.inc)
or #ifdef(my sphere file)
Nothing like this works in v3.8xx. Of course, #ifdef may not be the correct
thing to use, but it's the first idea that comes to mind. (I have a vague
memory-- possibly mistaken-- that I did use the string- construct version in the
*distant* past, and that it worked. Or maybe not.) But with the current behavior
of #ifdef("...string..."), it's of no use. And (my sphere file.inc) fails
outright because of the 'dot'; likewise (my sphere file) because of the
spaces.
There IS an obscure built-in identifier (or variable?) called
View_Include_Stack, that can be used to determine if any of POV-ray's *own*
specific include files are present-- ALL that are being used-- by putting the
following at the top of a scene, running it, then looking afterward in
'Messages' (in Windows GUI versions, that is):
#declare View_POV_Include_Stack = true;
I can't find it in the documentation; but take a look here...
https://news.povray.org/povray.general/thread/%3C5c0827cd%241%40news.povray.org%3E/
Unfortunately, it will not list any user-made #includes-- even if they are
placed in POV-ray's 'includes' folder; I just tested it. That seems strange.
(The link above actually discusses the topic of how to determine the presence of
such user-made files, but the various methods seem to require that code snippets
be added to each and every file first. A simpler #ifdef scheme would be much
easier!)
I'm having a hard time seeing a good reason for the capability. If you
are trying to do something like swap in simple stand in for a complex
model while developing a scene, it seems like you should just set that
up on a declared true false variable ahead of time.
Maybe you'd want to automatically use a simple stand end until the
include of the complex model is created. Well then you could use
file_exists() and the complex model will be included as soon as it exist
somewhere POV-Ray can find it.
A failing include stops parsing.
Folks often include far more than they need (stnd.inc ?) for any given
scene. While that slows down parsing, it usually isn't a fatal mistake.
Unfortunate undefs or re-declares to the same IDs do happen, and that is
the one place where a user might want to throw an error if, say, he
knows POV-Ray's color.inc has the potential to undo his flavor or Red.
But, then maybe, MyBetterThanPOVRayRed is a better name... :-)
Not arguing you couldn't use the functionality, it's just hard for me to
see the return on investment.
Aside: Even checking the name there is a search order for the file too
and, if there are multiple files called color.inc available, the next
feature request will be something about knowing which actual color.inc
POV-Ray included.
I'm thinking, jr, about a keyword_exists() kind of feature.
Aside: I'm digging around more on the - since 2015 - ifdef(), ifndef()
v3.71/v3.8/v4.0 behavior; I noticed when keywords are passed, Christoph
made updates to some releases to kick out a warning:
Parse Warning:
Trying to test whether a reserved keyword is defined.
(or a similar message depending on releases)
I take it as evidence he was playing with looking at more than IDs - or
perhaps he realized there was an unintended an unintended behavior he
needed to back out (a part of it he did for v3.8). For povr I'll likely
leave the message in place on restoring v3.7 and prior behavior; Users
can get different results depending on what release code they run on
testing keywords.
Yep, I need to look at how he made the inbuilt keyword determination for
the message - there are hidden reserved words too which are not visible
SDL 'keywords' / reserved words. Msg method might offer a way to an
iskeyword().
Bill P.
> View_Include_Stack...
Well... In the light of a new day, I remembered that I had seen that
*somewhere*; it's not an "obscure built-in identifier" :-[ It's just 'a name'
or variable-- part of an #ifdef block at the top of every 'official' POV-ray
include file, with a simple #debug statement:
#ifdef(View_POV_Include_Stack)
#debug "including arrays.inc\n"
It's just a useful/descriptive phrase that someone came up with in the past.
Which explains why adding #declare View_POV_Include_Stack = true; at the
top of your main scene file results in a list of those #included files in
'messages'. Duh. No special magic.
> I can't find it in the documentation...
...because it's, uh, not part of POV-ray.
That's because my personal #include files don't have the added #ifdef block.
Until now, I never gave much thought as to why I should add that. NOW I see why.
It's a good way to see which files might be buried in a large scene with lots of
nested #includes.
I haven't yet tested it to see if it will flag *multiple* instances of the same
#include. That would be useful too.
> *somewhere*; it's not an "obscure built-in identifier" π
It's just 'a name'
> #end
With my povr branch I have for a while been set up with two basic
targeted compiles.
One is a debug option with a lot of extra checking and reporting
enabled. The other is the day to day rendering version to be used when
things are going well.
The idea is to use the faster one as a rule.
However, on seeing flaky behavior, or when just wanting to do more
robust checking of your scene to find what evil is lurking - run the
debug compile version.
On reading your post I had the thought, why not add some detailed
include information to the targeted debug compile version of povr. I did
- and the output currently looks like:
==== [Parsing...] ==============================================
Debug: #include "functions.inc"
Debug: #include "/run/shm/tmpDir/povrayB/include/transforms.inc"
Debug: #include "/run/shm/tmpDir/povrayB/include/math.inc"
Debug: #include "/run/shm/tmpDir/povrayB/include/setidtypes.inc"
Debug: #include "/run/shm/tmpDir/povrayB/include/vectors.inc"
Debug: #include "/tmp/otherInc/whackJob.inc"
This information which I'll find useful on occasion too! Oh, the scene
has only these four includes:
#include "transforms.inc"
#include "math.inc"
#include "whackJob.inc"
So, the larger reported set is due some of those includes having
includes too. With well formed include files, only the first in the
debug output is really used.
On using: #declare View_POV_Include_Stack = 1; we see:
including function.inc
including transforms.inc
including math.inc
including setidtypes.inc
including vectors.inc
We don't see whackJob.inc just above because the guy who wrote it did
not add the debug code that is in all core shipped include files.
Aside: There are exposures with the View_POV_Include_Stack method in
that the name reported is whatever is in the debug statement and not
really the name of the file included. They should align, but...
With regards to the #ifdef(), #ifndef(), the povr fork has been reverted
to v3.7,v3.6 behavior in looking only for declared IDs. With the one
exception that empty parenthesis now returns false or true,
respectively, without introducing odd, hard to understand parsing fails
as a rule.
Bill P.
Yes! I was a 'victim' of that user error myself, while I was testing things :-[
A sloppy cut-and-paste job. I spent half an hour (!) tracking it down, ha.
This old method is certainly not an ideal way to report the presence of a user's
personal #includes. The special code block is 'one more thing' that has to be
added to a file. I probably have several hundred includes of different kinds
that I have written over the years, many written hastily (or even auto-generated
by POV-ray like mesh_2 files.)
> personal #includes.
Found the new debug compile reporting all the include read attempts has
an issue too.
Specifically where people use that Parse_String() macro hack. It works
by creating and including a small include file of the same name, but
with different contents.
In trying again to debug that flaky csv read file problem from early
2022 of jr's, I was getting thousands of debug include messages per
frame of a long animation! So, I commented out that nice debug code I
just added.
I'm unsure what to do for anything shipped.We'd need a custom
configuration option or a new run time flag/option - neither of which is
attractive.
It's hard to get simple, clean, code wins. :-)
Bill P.
hi,
> I was getting thousands of debug include messages ...
a '#pragma [no-]feature-warning;' would be real nice, to get rid (selectively)
of spline + rtr "experimental feature" warnings, for instance :-)
regards, jr.
> of spline + rtr "experimental feature" warnings, for instance π
Hmm. Yeah, maybe some more general mechanism to turn off messages would
be helpful(a,b). Features like this will slow down the parser some though.
Bill P.
(a) - The was some support for warning levels for a time, but it's
eroded on the implementation side over time - unsure if it still works
at all in fact. Plus, I cannot remember how the level was specified at
the moment.
(b) - Unrelated to parsing, but for the isosurface only I added a report
<true/fase> option in povr for gradient messages. The 'report' keyword
has always intended to be a more general thing which could be used with
all the shape primitives. Something where, by shape, you can turn
reporting on and off. I never seem to get back to working on the concept
though...
> > This old method [of 'View_POV-Include_Stack'] is certainly not an ideal
> > way to report the presence of a user's personal #includes.
> I'm unsure what to do for anything shipped. We'd need a custom
> attractive.
I was thinking the same thing: something built-in. HOW to do it-- and how
difficult it would be to code without introducing other problems-- are the
bigger questions, of course ;-)
I'm rather surprised that, in all the years of POV-ray's code development, some
kind of internal mechanism was not introduced to do this... because knowing
automatically which #includes are actually being used in a scene would be a
useful bit of info, IMO.
In the 'official' Windows versions, the GUI uses something called CODEMAX, as
far as I understand. Perhaps the lack of such an #includes feature is a
limitation of the POV-ray/CODEMAX interaction? I do remember Clipka and other
developers mentioning 'difficulties' or restrictions between the two.
Seems to me (a non-source-code-programmer) that it would work as part of the
#include directive itself, and we already have internal things like recursion
stacks, etc. So it wouldn't really be a problem to prevent multiple parsing of
includes, etc.
As for parse time, how much extra could there possibly be to check the include
stack to see if the file has been included yet, or if the "view include stack"
flag is set or not?
But perhaps for some reason it's non-trivial.
- BW
> flag is set or not?
Mostly very little as you suggest.
Excepting where someone is using the Parse_String hack or similar and so
doing potentially gazillions of small includes - as is happening in the
animation code of jr's. The clean fix for that problem is to change that
hack into some immediate, interpret this 'string' feature - but that's
not all that easy to do.
In any case, I was thinking more of jr's general #pragma capability for
turning off say 13 warnings, but not any of the other remaining 3,852 (I
made that number up).
We introduced the possible errors category too as something I believe
new to v3.7/v3.8/v4.0, but I didn't go check the v3.6 source.
Thinking aloud...
In compilers most all warnings are introduced with a general, less
general and selective control capability(a), but also various categories
of warnings. These are almost all on command line flags and often inline
with code too. In code these optionally to some local region (like a
file or particular functions) in the form of #pragma settings. That
said, such message controls are not all that standardized between
compilers. What you do for one compiler might or might not work for
others. And sometimes there are conflicts between compilers.
POV-Ray is a little different from compilers in that we have a parse
phase, which is compiler like is some respects, and then we have a
render phase for both stills and animations. Those two modes differ in
behavior and cost.
Aside: We have too a nascent RTR capability too not sharing much with
the control structure of regular animations.
The issues start with the code base not having a generic set up for
anything like an in code #pragma capability - which probably would apply
to SDL only I'd say.
We have too what looks like common functionality in things like pow()
that have multiple forms internally. One for the SDL and another for
functions running on the vm at parse time or render time.
We have warnings and errors around both command line options and ini
settings too. These perhaps more an issue for animations where you might
get some warning for each frame.
The error messages don't all go through the same message systems or
message handlers today. In povr, I use the fancier ones when they are
there and ready to use, but when they are not, I don't!
I've made use of writing to stderr, for example, when it's the expedient
thing to do to get messages about behavior where we are today just
letting things go. Often things which were historically reported in
earlier single thread versions of POV-Ray. Yes, this means sometimes
each thread kicks out exception messages, but I feel getting the
information is more important than not.
That's sort of the really rough lay of the land for info / warning /
possible error / error / messages. The thinking aloud, I expect, more
helpful to me than anyone else. :-)
All that said, adding a few select controls, #pragmas, not all that hard
to do. Maybe we aim to control the most annoying (or most useful)
messages first.
Where these might bleed over to render time functionality there is a
significant cost to turning on or off checks when that 'control test'
gets done millions (or billions) of times while rendering. Such testing
costs less for animations where you might have only a thousand frames.
For stills such control tests might cost little or be significant if
happening inside a loop placing thousands of objects.
Yes, issuing and tracking information for the messages costs too.
Sometimes we'll win when the messages are off - even if running the
control test a great many times.
Sometimes messages are situation-ally useless as happens when users
create isosurfaces with functions having a high gradients - well away
from the all of the actual roots. In such cases the gradient warnings
have no 'useful' meaning and in povr 'report false' turns them off by
isosurface.
There are situations where better more controllable warnings absolutely
helps limit warnings to those probably useful.
Bill P.
(a) - Aside. When I re-worked povr's gnu, autotools based build, I
turned off all the compiler warnings by default. To me, it didn't make
sense for users grabbing the code to do a quick ./configure, make -j4,
make check, make install; to see hundreds of warnings they aren't going
to try and fix anyway.
My my, you _have_ been busy :O
Is there a way to identify and collect all of the places in source where errors
get raised, and group them by parse / render/ etc?
That might help folks get a better idea about how much there is an how often
some warnings might need to test conditions and fork flow control.
While working on the lemon, I also stumbled upon a dev manual in the 3.8 github
stuff - haven't had a chance to dig through it - might any of that already be in
there?
- BW
:-) Hmm. Asking questions to which to which the only strict answer is
yes.
If you mean quickly, you can grep strings like Warning, PossibleError,
Error and see quite a bit of text fly by. When and whether you actually
get any particular ones depends on more. Some too get formed indirectly
where a function like Not_WithPattern() might be what is actually
getting called and it will assemble some final Error or Warning.
The parsing related stuff these days is mostly in the source/parser
directory. Just counting lines with those strings in povr, Warning 171,
PossibleError 32, Error 609.
> there?
Assume you are talking about the contents of source-doc directory.
Many years ago I did read through those files. I don't recall much of it
truth be told and a lot of it was 15 years old already when I read it. I
see a povms.md file. It would have stuff on the threaded messaging
system - one of several ways messages get generated - so yep some in
there. :-)
Bill P.
Here's another example of an #ifdef feature that would be useful, IMO. I
recently had a need for it:
#ifdef(AA & BB)
Apparently, it doe not (yet) work with 'tuples' like the newer v3.8 #declare
does, for example. Nor with boolean operators, so it seems.
I tried several workarounds for this, in various syntax forms. My first attempt
was with nested #ifdef's, possibly using an #elseif somewhere-- but I am not
very familiar with the #elseif construct and could not come up with a code
block that seemed 'reliable' or logically consistent:
#declare AA=3;
#declare BB=7;
#ifdef(AA)
#ifdef(BB)
... do this...
(or #elseif ...do this... ?)
#else (?)
... do that...
My 2nd attempt was with an enclosing #if, again in various syntax forms-- but
this causes fatal errors, and I'm not sure that I understand why:
#if(#ifdef(AA) & #ifdef(BB)) // this line does not work, even though an #if can
// itself use boolean operators
...do this...
#else
...do that...
For the first line, a simpler #if(#ifdef(AA)) does not work either, nor does
#if(#ifdef(AA)=true))
Any suggestions or comments? It seems to me that at least one of these schemes
*should* work, unless I'm making a basic error or wrong assumption somewhere.
The current v3.8 operation of #ifdef is...ill-defined... so maybe that's part of
the problem(?)
hi,
suggestion. write '#if(defined(AA) & defined(BB))' (ie both exist)
regards, jr.
Yes, that's a great workaround! Thanks. I had forgotten about the 'defined'
function, as I don't use it very often.
> I recently had a need for it:
> #ifdef(AA & BB)
Depending on how many variables you need to test, you lump them all together
into an array and cycle through them, using the product of the result as a sort
of Boolean AND result.
Not sure I knew about "defined" - that's a handy keyword.
#declare AA = 1;
#declare BB = 3;
#declare Variables = array {AA, BB}
#macro And (_Array)
#declare Elements = dimension_size (_Array, 1)-1;
#declare AndResult = 1;
#for (Index, 0, Elements)
#declare AndResult = AndResult * defined (_Array[Index]);
AndResult
#if (And (Variables))
#debug "All variables are defined. \n"
#error "No objects in scene"d
> > #ifdef(AA & BB)
> as a sort of Boolean AND result.
> #declare AA = 1;
> #declare BB = 3;
> #macro And (_Array)
> #end
> AndResult
> #end
> #end
I had to think about this one (and had to take a temporary break because of all
of the new Spring pollen in the air, here in the South. Sneezing uncontrollably!
Me no likey!)
This is an interesting way of attacking the problem, and works fine as-is. But
if I add an UN-declared variable to the array (i.e., wondering if I had
previously declared it or not), this line fails:
#declare Variables = array {AA, BB, CC}
"Cannot pass uninitialized identifier to non-optional array initializer."
(What a mouthful!)
But I'm probably going outside the scope of my simpler #ifdef(AA & BB)
question. JR's #if/#else code allows a more graceful exit though: I could add a
#debug like, "One or more of your variables is undefined."
