POV-Ray : Newsgroups : povray.general : Enabling debug output to console under Windows Server Time
23 Nov 2026 14:02:08 EST (-0500)
  Enabling debug output to console under Windows (Message 1 to 20 of 20)
Subject: Enabling debug output to console under Windows
Date: 4 Feb 2023 08:15:00
Message: <web.63de5a03b584c4734ad5859710800fb2@news.povray.org>
Can anyone help me to enable debug prints to console under Windows(POV 3.8),
please ?
Spent 2.0 hours trying to find solution, command line options +GA +GD gives
nothing, scene has only one string:
#debug "----------------- DEBUG -----------------------------"
Console output in attachment, thanks in advance.
YB
Download 'output.txt' (4 KB)
Subject: Re: Enabling debug output to console under Windows
Date: 4 Feb 2023 08:20:00
Message: <web.63de5b016feb0ae988a828ca6cde94f1@news.povray.org>
hi,
> please ?
under Linux you need to supply the newline explicitly, ie "string\n".
regards, jr.
Date: 4 Feb 2023 08:30:00
Message: <web.63de5ce16feb0ae94ad5859710800fb2@news.povray.org>
Thanks, but it's not working for me, unfortunately now I'm tied to Windows by
Matlab license.
Date: 4 Feb 2023 08:45:00
Message: <web.63de60ad6feb0ae988a828ca6cde94f1@news.povray.org>
hi,
> Matlab license.
should work, no CLI options needed.  (thinking, platform actually should make no
difference)  however, if you use the 'all_file' option, all (console "#debug")
output should be in that (too).
regards, jr.
Date: 4 Feb 2023 09:05:00
Message: <web.63de64f06feb0ae94ad5859710800fb2@news.povray.org>
Unfortunately, not, I've tried both:
#debug "----------------- DEBUG -----------------------------\n"
#debug "----------------- DEBUG -----------------------------\r"
and don't set 'all_file' option.
YB
Date: 4 Feb 2023 09:20:00
Message: <web.63de691f6feb0ae94ad5859710800fb2@news.povray.org>
btw, under Linux works fine.
Date: 4 Feb 2023 09:25:00
Message: <web.63de6a496feb0ae988a828ca6cde94f1@news.povray.org>
curious.  have attached a zip, run (in clean directory) the ini file.  does the
'alltext.out' created not show the '#debug' output? (at least of the first line,
ie '\n' terminated)
regards, jr.
Download 'yb.zip' (1 KB)
Date: 4 Feb 2023 09:50:00
Message: <web.63de6ffe6feb0ae91f9dae3025979125@news.povray.org>
You want:
input_file_name = try1.pov
all_file = true
output_file_name = try1
Debug_File=try1.txt
https://wiki.povray.org/content/Reference:Text_Output_Options#Directing_Text_Streams_to_Files
Date: 4 Feb 2023 09:55:00
Message: <web.63de71386feb0ae94ad5859710800fb2@news.povray.org>
looks like parsing problem:
/* try1 */
#version 3.7;
global_settings {assumed_gamma 1}
box {0,1}
// #declare s_ = "a string to display"; // This works
#declare s_ = "----------------- DEBUG -----------------------------"; // This
not
#debug concat(s_, "\n")
#warning "end-of-file"
YB
Date: 4 Feb 2023 10:05:00
Message: <web.63de73516feb0ae91f9dae3025979125@news.povray.org>
Yep, just get rid of the other stuff and only use:
Debug_File=try1.txt
I'd also replace the #warning with
#error "No objects in scene"
To stop the render phase
Date: 4 Feb 2023 10:25:00
Message: <web.63de787e6feb0ae988a828ca6cde94f1@news.povray.org>
hi,
> not
fwiw, cannot reproduce, works on the Linux box.  as a workaround (perhaps), will
breaking the string in to "{hyphens}", "DEBUG", "{hyphens}" inside the concat
work?  (in my own macros I tend to use the brackets, eg '--[someword]--' to
surround the (key)word)
regards, jr.
Message: <web.63de78c86feb0ae988a828ca6cde94f1@news.povray.org>
hi,
(there is one, though)
regards, jr.
Date: 4 Feb 2023 10:30:00
Message: <web.63de799b6feb0ae94ad5859710800fb2@news.povray.org>
/* try1 */
#version 3.7;
box {0,1}
// #declare s_ = "a string to display"; // THis works
not
// #warning "end-of-file"
Gives:
"C:\temp\povtest\try1.pov" line 14: Parse Error: Parse halted by #error
directive: No objects in scene
without console output, but with debug print in try1.txt (attached).
Download 'try1.txt' (1 KB)
Date: 4 Feb 2023 10:35:00
Message: <web.63de7a946feb0ae91f9dae3025979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> regards, jr.
#declare your = 0;
#declare ears = 1;
// imma gonna
box {your, ears}
I was suggesting suppressing the render output until the other issue got
resolved  :P
I'm gonna get you a pendant that reads "Pedant".
Message: <web.63de7b176feb0ae91f9dae3025979125@news.povray.org>
> /* try1 */
> #version 3.7;
> box {0,1}
> not
> Gives:
Hi Sergey,
Excellent.   Now you can comment out the #error message and get on with what
you've been trying to do for the last several hours.
This is "fun", eh?
-Bill
Date: 4 Feb 2023 10:50:00
Message: <web.63de7e8a6feb0ae94ad5859710800fb2@news.povray.org>
Thanks, this is a part of the profession )
> This is "fun", eh?
No doubt )
Final word: number of hyphens are matter - threshold is 14:
#declare s_ = "--------------";  // This works
#declare s_ = "---------------"; // This not
YB
Date: 4 Feb 2023 11:10:00
Message: <web.63de82e66feb0ae91f9dae3025979125@news.povray.org>
> "Final word"
HAhahahahahahahahahahahahahahahahaha!  Famous last words.  :D
I'm dying over here.
I'm getting output with:
#debug
-------------------------------------------------------------------------------\n"
But there is definitely something strange going on with the string size, the
output to the file, and possibly with concat ().
Message: <web.63de82f56feb0ae992a18f0689db30a9@news.povray.org>
> Hi,
> > This is "fun", eh?
> No doubt )
I just tested in the official Windows v3.7:
If there are several lines with 15 or more minuses, the first one is
converted to a solid horizontal line and the others are not shown.
It might be a feature - but I would consider it to be a bug.
Also, if you do not add a "\n" after the last debug line, it is
not shown.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Message: <web.63de83196feb0ae988a828ca6cde94f1@news.povray.org>
hi,
> > This is "fun", eh?
> No doubt )
BE's not wrong though.  the parser is full of "surprises", and I think it's
pretty cool you should have managed to run into your first, so quickly :-).
re '#debug', although you can make strings longer than 255 chars, #debug will
silently truncate lines to its "preferred" limit; I once ran into this, if in
doubt emit short(er) lines/text.
regards, jr.
Date: 5 Feb 2023 10:39:45
Message: <63dfcdc1$1@news.povray.org>
Op 4-2-2023 om 16:32 schreef Bald Eagle:
> #declare your = 0;
> #declare ears = 1;
> // imma gonna
> box {your, ears}
LOL!
