POV-Ray : Newsgroups : povray.general : How to ... Server Time
28 Oct 2024 10:18:39 EDT (-0400)
  How to ... (Message 1 to 10 of 23)
Subject: How to ...
Date: 22 Nov 2021 11:23:08
Message: <619bc3ec$1@news.povray.org>
Hello,
I have a surface defined by a set of points <x,y,z> and for each point,
its color.
In your opinion, which object/method is the most appropriate to
represent such a surface?
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: How to ...
Date: 22 Nov 2021 13:40:00
Message: <web.619be376d5fe89401f9dae3025979125@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello,
> its color.
I'm thinking that the most straightforward thing would be to use
smooth_triangles.
Alternately, maybe you could set up a network of bezier patches, and use your
color information to render a separate scene of boxes that would give you an
image to use as an image_map for uv_mapping your bezier patch union {}.
Might be able to do something with splines and functions ....
It all may depend on how many points you have.
Date: 23 Nov 2021 11:30:12
Message: <619d1714$1@news.povray.org>
Bald Eagle writes:
>> its color.
> smooth_triangles.
e your
ou an
For example, *.TRI format of 3D shapes contain <x,y,z> coordinates, and
a color affected to these. If you use TRI2POV it gives a surface like...
	<https://www.youtube.com/watch?v=Yf7q2KdAS-4>
When you use TRI2POV it converts the surface in a set of smooth_triangle
that can render the surface with ray-tracing. That exists since the very
first versions of POV-Ray, and produces a very nice result.
I hope that it is what you're thinking about. Some 3D file formats, like
*.TRI is perfect to describe that kind of colored 3D surfaces. It's easy
Author of Eureka 2.12 (2D Graph Describer, 3D Modeller)
<http://eureka.atari.org/>
Date: 23 Nov 2021 13:40:00
Message: <web.619d3540d5fe89401f9dae3025979125@news.povray.org>
I don't believe I am aware of TRI2POV.  Where is it available?
I'm sure I have asked a similar question in the past, so I'm thinking that there
are a lot of other people who are unaware of this utility.
Date: 23 Nov 2021 15:00:04
Message: <619d4844$1@news.povray.org>
Bald Eagle writes:
d
le
ry
ke
sy
hat there
I have C sources for TRI2POV. But I remembered that it's ATARI software:
TRI-POV Converter Version 1.0 Sept/97
Copyright (c) 1993 by Steve Anger
And 97 by Archimedium
This program converts .TRI files generated by the Atari programs
to POV-Ray or Vivid raytracer scene files. Bounding shapes are
automatically generated for POV-Ray to greatly reduce the rendering time.
Syntax:  tri2pov inputfile[.tri] [outputfile] [options]
Options:
-snnn    - Generates smooth triangles. The boundaries between triangles
            are only smoothed if the angle between the triangles is less
            that nnn degrees. -s0 will not smooth any triangles while
            -s180 will smooth all triangles. Values from -s45 to -s90
            usually work well. If unspecified smoothing defaults to -s60.
-op      - Output to POV-Ray 1.0 format
-op2     - Output to POV-Ray 2.0 format (2.0 is unreleased as yet)
-op3     - Output to POV-Ray 3.0 format (default)
-ov      - Output to Vivid 2.0 format
-or      - Output to Raw triangle format.
-lxnnn   - Set look_at x coord to nnn
-lynnn   -  '     '    y   '   '   '
-lznnn   -  '     '    z   '   '   '
-vxnnn   - Set view_point x coord to nnn
-vynnn   -  '       '     y   '   '   '
-vznnn   -  '       '     z   '   '   '
e.g. tri2pov car.tri car.pov -s60.0
                                   Steve Anger, Guelph, ON, Canada
                                   CIS: 70714,3113
                                   Internet: 707### [at] compuservecom
                                   ADEnet Boards i.e.:TGA: (510)524-2780
Archimedium WEB: http://www.ief.u-psud.fr/~lecoat
E-mail: lec### [at] iefu-psudfr
I modified it a long time ago. It works well. I can send you sources...
Best regards,
Date: 23 Nov 2021 19:30:00
Message: <web.619d872fd5fe89401f9dae3025979125@news.povray.org>
:O
Maybe you can post a zip to the utilities group - then several people can look
it over and play with it.
The C and C++ programmers, the povray macro writers, etc...
It sounds like a great utility to make generally available!
Date: 24 Nov 2021 04:30:10
Message: <619e0622$1@news.povray.org>
Bald Eagle writes:
e:
> :O
an look
> Thanks   :)
The author of TRI2POV is Steve Anger, who is a member of the POV-Team:
<https://www.povray.org/documentation/view/3.6.0/204/>
I can't publish the C sources, because it is copyrighted. I can send
you something, privately. But if it should be opened publicly, we
should ask Steve Anger, about opening his code from 1993...
What do you think of that?
Best regards,
Date: 24 Nov 2021 11:49:18
Message: <619e6d0e$1@news.povray.org>
That part about adding bounding is no longer useful. It was useful to
manually bound things back then, but, the automatic bounding have
improved dramatically since 1993.
Now, not using those bounding often result in better performances.
Remember that adding bounded_by to an union suppress the normal bounding
of it's components. That mean that any ray that enters that bounding box
have to get tested against every individual primitives contained in that
union.
Date: 24 Nov 2021 16:10:00
Message: <web.619ea93fd5fe89401f9dae3025979125@news.povray.org>
> Thanks   :)
> Best regards,
Sure - one would hope that he would be fine with that.
Feel free to send me an email as well.
- Bill
Date: 26 Nov 2021 09:39:25
Message: <61a0f19d$1@news.povray.org>
On 23/11/2021 21:00, Francois LE COAT wrote:
> Hi,
> Bald Eagle writes:
>> that there
> Options:
> Best regards,
This utility looks interesting.
I'd like the sources. If it is not too complicated, the conversion from
C to POV SDL can be considered.
My email address is valid.
Kurtz le pirate
