POV-Ray : Newsgroups : povray.general : Round to nearest integer Server Time
25 Oct 2026 14:29:42 EDT (-0400)
  Round to nearest integer (Message 1 to 8 of 8)
Subject: Round to nearest integer
Date: 27 May 2021 07:20:56
Message: <60af8098$1@news.povray.org>
Has someone written a macro that rounds a float to the nearest integer?
Thanks!
Mike
Subject: Re: Round to nearest integer
Date: 27 May 2021 07:31:39
Message: <60af831b$1@news.povray.org>
> Thanks!
> Mike
Or, to the nearest multiple of n, where n is any number.
Mike
Date: 27 May 2021 09:14:53
Message: <60af9b4d$1@news.povray.org>
Am 27.05.2021 um 13:20 schrieb Mike Horvath:
`floor(FOO + 0.5)` should do the trick.
Date: 27 May 2021 09:17:26
Message: <60af9be6@news.povray.org>
Am 27.05.2021 um 13:31 schrieb Mike Horvath:
>> integer? Thanks!
try `floor(FOO / N + 0.5) * N`.
Date: 27 May 2021 09:32:07
Message: <60af9f57$1@news.povray.org>
>>> integer? Thanks!
I found this on web and adapted it to POV:
   #macro round(number, base)
     (((number + base/2) / base) * base)
Not sure which of the two is preferable.
Mike
Date: 27 May 2021 13:42:49
Message: <60afda19$1@news.povray.org>
Am 27.05.2021 um 15:32 schrieb Mike Horvath:
>    #end
You mean, aside from the fact that yours won't work, unless you put a
`floor` between the first and second opening parentheses? ;)
Mine, I'd guess. It is comprised of only 10 tokens as opposed to 16
(including the missing `floor`), and only 3 variable references as
opposed to 4, so it will parse faster. The expression tree is also a bit
simpler, so it will also execute faster, even if written as a function
rather than a macro. (Remember, macros are parsed over and over again
every time they are called. In general, functions are faster.)
Yours - especially with the lack of `floor` - looks like it was
specifically designed for operating on purely integer values (i.e. not
only is `number` expected to be an integer, but each operation
automatically rounds down to an integer). In such a setting, it would be
spot-on, to the point that you couldn't come up with a more efficient
solution than that.
POV-Ray doesn't even know what an integer is.
Date: 27 May 2021 14:50:23
Message: <60afe9ef$1@news.povray.org>
«ceil(FOO - 0.5)» should also work.
Date: 27 May 2021 15:04:01
Message: <60afed21$1@news.povray.org>
Am 27.05.2021 um 20:50 schrieb Alain Martel:
In a technical sense, yes. However, values exactly halfway between would
be rounded down, rather than up as per the common convention(*).
(For positive values, that is. For negative values, the common
convention is to round such numbers towards negative infinity, making
the `ceil`-based formula more true to conventional rounding in the
negative domain.)
