POV-Ray : Newsgroups : povray.general : Why only a +1 clamp with VAngle, VAngleD macros in math.inc? Server Time
28 Oct 2026 13:50:19 EDT (-0400)
  Why only a +1 clamp with VAngle, VAngleD macros in math.inc? (Message 1 to 15 of 15)
Subject: Why only a +1 clamp with VAngle, VAngleD macros in math.inc?
Date: 6 May 2021 09:06:30
Message: <6093e9d6$1@news.povray.org>
In creating some testing for include file macros I came across code for
the two VAngle* macros (and two similar rotation related macros):
#macro VAngle(V1, V2)
         acos(min(1, vdot(vnormalize(V1), vnormalize(V2))))
The min(1,..) is obviously trying to protect acos from domain errors.
Why only the clamp to the positive side? Aren't we as exposed to <-1.0?
Often enough in code - including POV_Ray's own - I've seen code clamping
to a [-1..1] range after a dot product into acos() for acos domain
concerns.
I cannot come up with reasoning to clamp only the positive side. Anyone
else? If valid to do, we might be able to slightly streamline some
internal code.
Bill P.
Subject: Re: Why only a +1 clamp with VAngle, VAngleD macros in math.inc?
Date: 6 May 2021 10:28:33
Message: <6093fd11$1@news.povray.org>
> #end
> concerns.
> internal code.
> Bill P.
The reason is quite simple : Normally, the vdot function of two
normalized vectors can not return a value that is less than -1 nor more
than 1.
So, the min() could probably be safely removed.
	acos(vdot(vnormalize(V1), vnormalize(V2)))
Date: 6 May 2021 11:00:00
Message: <web.6094040b3160e21b8e52cc8789db30a9@news.povray.org>
> #end
> concerns.
> internal code.
Perhaps the one that made that macro experienced a problem with at value from
the dot product being slightly higher than one so he inserted that min()
function to deal with it, without thinking through the problem thoroughly.
You are right there should also be a max() function there to discard values
below -1.
Anyway the way that macro calculates the angle is not the best numerically.
I would rather suggest something like this:
#macro AngleBetweenVectors(v1, v2)
    #local v1n = vnormalize(v1);
    #local v2n = vnormalize(v2);
    (2*atan2(vlength(v1n - v2n), vlength(v1n + v2n)))
#end // macro AngleBetweenVectors
I have not tested this macro yet, but the angle() function in my scikit-vectors
Python library seems to work ok. It works in is similar way as the macro above.
https://github.com/t-o-k/scikit-vectors/blob/master/skvectors/cartesian_vectors.py
See "§14: Preconditioning a Cross-Product" in
"Computing Cross-Products and Rotations in 2- and 3-Dimensional Euclidian
Spaces"
https://people.eecs.berkeley.edu/~wkahan/MathH110/Cross.pdf
My opinion is that several of the other math related macros in the include files
need some rework.
Tor Olav
http://subcube.com
Date: 6 May 2021 11:05:00
Message: <web.609404fd3160e21b8e52cc8789db30a9@news.povray.org>
> > #end
> > concerns.
> > internal code.
> > Bill P.
> than 1.
I think that this is only in theory. In practice there will sometimes be
roundoff errors that cause problems.
> #end
Tor Olav
http://subcube.com
Date: 7 May 2021 07:13:18
Message: <609520ce$1@news.povray.org>
>> #end
>> concerns.
>> internal code.
> below -1.
Thanks. What I suspected too, but I don't have near your expertise.
Interesting, thanks. I'll play with it. There will be four sqrt calls
with this vs two so I expect it's a slower approach.
Reminds me I captured fast approximation atan2 code I was thinking of
making an inbuilt function, but I've not gotten to it...
And that thought reminds me of my plans to turn many macros into
"munctions"(1) calling new faster, inbuilt functions. Done only a tiny
bit of that so far.
(1) - Yes, thinking about creating a munctions.inc file breaking out
what are really macro wrappers to functions into that file to make clear
what they are. Maybe all as M_ prefixed so my current F_dents() would
become M_dents(). Angle perhaps then M_Angle.
> Spaces"
> need some rework.
I'd consider alternatives for my branch if you want to offer details.
Suppose I could compare to forms in skvectors?
Something I've done too with the inbuilt function changes is allow
alternative calculations for the same thing. Compiled such conditionals
not that expensive. Most frequently single float options where those are
much faster, but different methods too. For one thing, the alternatives
I can bang against each other as a way to test!
Bill P.
Date: 8 May 2021 19:10:00
Message: <web.609719613160e21be719296489db30a9@news.povray.org>
> > need some rework.
That sounds good.
Today I looked at the statistical macros in math.inc.
Here's how they could be rewritten:
(Please note that have not tested these thoroughly yet.)
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.8;
// Does also work for vectors
#macro Mean(Values)
   #local N = dimension_size(Values, 1);
   #local Sum = Values[0];
   #for (I, 1, N - 1)
      #local Sum = Sum + Values[I];
   #end // for
   (Sum/N)
#end // macro Mean
#macro Variance(Values)
    #local M = Mean(Values);
    #local D = Values[0] - M;
    #local SquareSum = D*D;
    #for (I, 1, N - 1)
        #local D = Values[I] - M;
        #local SquareSum = SquareSum + D*D;
    (SquareSum/N)
#end // macro Variance
#macro Minimum(Values)
   #local Min = Values[0];
   #for (I, 1, N - 1)
      #local Min = min(Min, Values[I]);
   #end // for
   Min
#end // macro Minimum
#macro Maximum(Values)
   #local Max = Values[0];
   #for (I, 1, N - 1)
      #local Max = max(Max, Values[I]);
   #end // for
   Max
#end // macro Maximum
// For population
#macro StandardDeviation(Values)
   sqrt(Variance(Values))
#end // macro StandardDeviation
#macro Statistics(Values)
    #local Value = Values[0];
    #local Min = Value;
    #local Max = Value;
    #local Sum = Value;
    #local SquareSum = pow(Value, 2);
    #for (I, 1,  N - 1)
        #local Value = Values[I];
        #local Min = min(Min, Value);
        #local Max = max(Max, Value);
        #local Sum = Sum + Value;
        #local SquareSum = SquareSum + pow(Value, 2);
    #end // for
    #local M = Sum/N;
    #local Var = SquareSum/N - pow(M, 2);
    dictionary {
        .Count: N,
        .Min: Min,
        .Max: Max,
        .Mean: M,
        .Var: Var,
        .StdDev: sqrt(Var)
#end // macro Statistics
#macro PrintStatistics(Stats)
    #local S = array[6] { "Count", "Min", "Max", "Mean", "Var", "StdDev" };
    #debug "\n"
    #for (I, 0, 5)
        #debug concat(S[I], " = ", str(Stats[S[I]], 0, -1), "\n")
    #end // for
    #debug "\n"
#end // macro PrintStatistics
#macro Histogram(Values, NoOfBins)
   #local Stats = Statistics(Values);
   #local N = Stats.Count;
   #local Min = Stats.Min;
   #local Max = Stats.Max;
   #local BinWidth = (Max - Min)/NoOfBins;
   #local Bins = array[NoOfBins][3];
   #local BinLimitLow = Min;
   #for (I, 0, NoOfBins - 1)
      #local BinLimitHigh = BinLimitLow + BinWidth;
      #local Bins[I][0] = BinLimitLow;
      #local Bins[I][1] = BinLimitHigh;
      #local Bins[I][2] = 0; // Set count for bin to zero
      #local BinLimitLow = BinLimitHigh;
   #end // for
   #for (I, 0, N - 1)
      // Find the right bin for the value
      #local BinNo = int((Values[I] - Min)/BinWidth);
      // Make sure rounding errors do not lead to a non existent bin
      #local BinNo = min(max(0, BinNo), NoOfBins - 1);
      // Increase the count for the bin
      #local Bins[BinNo][2] = Bins[BinNo][2] + 1;
   #end // for
   Bins
#end // macro Histogram
I'm not sure what you mean here.
I'll comment further on the math related macros in the include files later.
Tor Olav
http://subcube.com
Date: 9 May 2021 02:25:00
Message: <web.60977f983160e21b8e52cc8789db30a9@news.povray.org>
I prefer better accuracy before speed. If we need this to go faster we could
compile it into POV-Ray and make it a new command; e.g. vangle().
> bit of that so far.
This sounds interesting. Can you please explain more ?
Are there any benefits from using these instead of new built in commands ?
Are you using this functionality to perform speed tests ?
Tor Olav
http://subcube.com
Date: 9 May 2021 09:22:16
Message: <6097e208@news.povray.org>
>>> need some rework.
> That sounds good.
Thank you. I'll have a look.
Aside: I've been working on adding self testing to all the includes
(Ingo's suggestion and method) and in addition to macros I broke myself
with povr branch changes, Histogram, was a macro long shipped which
already wasn't working... ;-)
I was guessing what you have in your package would be what you consider
solid/better implementations numerically. However, it helps me if you do
the sorting of what might be better implementations of current code.
For reference I'm shipping only the following includes as 'core' ones in
the povr branch.
arrays.inc
functions.inc
math.inc
rand.inc
shapes.inc
strings.inc
transforms.inc
Limit your look to these files for my participation. Further, I have on
my list to move some of the macros in these to munctions.inc or other
include files as 'not core' related / not commonly used.
arraycoupleddf3s.inc - This temporarily needed as it goes with some DF3
related work I did years back which is in the povr branch. Some of it
should end up in arrays.inc; some of it should go away. I've not sorted it.
Aside: My belief is future POV-Ray ray needs to move to a support
structure which breaks things into core-code, scenes, includes,
documentation, ini/configs, helper scripts / programs, (fonts?) and the
web site (also the wiki?) as independent code control structures on
github say ideally all with different primarys though perhaps still
common POV-Ray owners like Chris. I think it would work better having
multiple gate keepers to multiple POV-Ray domains. This model also
matches to a degree what linux package developers are already going
themselves breaking POV-Ray into multiple packages.
Bill P.
Date: 9 May 2021 09:31:42
Message: <6097e43e$1@news.povray.org>
>> bit of that so far.
Unsure how much you've been following my povr branch posts...
For starters, over the last year or two I've replaced most of the
existing 'odd shape' inbuilt functions for which functions.inc defines
the interface and documents the usage with more generic ones. I've also
extended and cleaned up the function<->pattern interface as related
work. New function related wave modifiers for example.
On the idea on munctions.
One old macro always a "munction" is the Supertorus in shapes.inc but in
the povr branch it now calls a new inbuilt function f_supertorus() for
backward compatibility. New users should call f_supertorus() directly.
We've long had simple "munctions" that look like inbuilt capability such as:
#declare clip = function (x,y,z) {min(z,max(x,y))}
which in povr I changed to
#declare F_clip = function (x,y,z) {min(z,max(x,y))}
and I'm leaning now toward calling it M_clip because I want to make
clear it is today a munction and not an inbuilt 'clip' keyword.
Longer term F_clip/M_Clip is educational in being simple, and it will be
left as is on the creation of a proper 'clip' implementation to create
inbuilt include test cases comparing M_clip results to 'clip' ones.
Sometimes. What munctions can today do not at all doable with inbuilts
of the straight keyword kind, or the inbuilt functions, is pre-condition
a larger set of stuff. Stuff being data / partial solutions - or the
particular configuration and inter operation of a collection of
functions(1).
When you say inbuilt command, there are flavors. For performance inbuilt
is 'almost' - but not always better.
I've gotten somewhat comfortable adding inbuilt functions, patterns and
shapes and the associated keywords.
When you talk a something like 'acos' there is an implementation in the
parser and there is a parallel implementation in the vm to create/run
the acos compiled code. Not all things in the parser are in the vm and
visa versa. Things only in the parser cannot as a rule be used with the
vm. Where the vm things mostly (all?) work during parsing.
Though 'acos' like implementations might often be best, I don't
understand the code well enough to pull these sorts of dual keywords at
the moment. In any case, I'd probably go after only a few things in this
way such as: the 'munctions' even, odd, max3, min3, sind,... (Adding the
constant 'e' is another though that I think I can work through today -
just not done).
I can implement inbuilt functions helping simplify/speed or replace many
effective 'munctions.' I've been working largely in this direction of late.
(1) Aside: I want to get to the point where we can tell whether a
function is being run from the parser (single thread) or during
rendering so we can precondition functions too. I have some ideas/notes
around thread ids and such, but I've not worked out how to really do it.
Even today in f_ridged_mf() there is an allocation of memory which I
believe should be done only by pre-conditioning during parsing(1a).
Function equivalents of ripples, waves, wood, etc need a parse time
preconditioning / set up capability too, to best work.
(1a) Depending on how threaded rendering work hits f_ridged_mf() today,
I suspect we are sometimes getting minor memory leaks. In this case to
with respect to functionality / result I think it harmless.
Sometimes, yes.
Aside: I've had several false starts looking at integrating the work you
and I beleive more Alain Ducharme did years ago with quaternions.inc -
as inbuilt capability of some kind, but never gotten very far with the
effort. Always so much on that todo list - and I'm not that smart, so it
goes slowly. :-)
Bill P.
Date: 9 May 2021 10:04:28
Message: <6097ebec$1@news.povray.org>
Dang..., one thing I was going to mention related to the 'munctions'
concept and forgot.
I'm about 95% sure truly macro wrapped functions don't get 'compiled' by
the vm until the macro is called. So, my thinking is there is a parse
time reason to create 'macro wrapped' functions over pure function
definitions of more complex math in our includes...
Not proven as in I haven't yet added throws to the vm code and tried
functions defined both ways.
Bill P.
Date: 10 May 2021 22:55:00
Message: <web.6099f0f03160e21b6d7cc5a589db30a9@news.povray.org>
That's good.
I'm not sure if I have seen Ingo's suggestion for how to test the include files.
Do you have any links to relevant threads ?
I hope that my rewrite of the Histrogram macro works ok in your branch then. I
tried to search for demo scenes that use this macro, but I couldn't find any.
Ok. I may be able to help with that, but it will probably take weeks or months
to go through all the macros and rewrite those that need to be improved.
If am going to spend much time rewriting a lot of macros, then I wish to dictate
the formatting style and the naming of variables in the macros.
> the povr branch.
> arrays.inc
> functions.inc
> math.inc
> rand.inc
> shapes.inc
> strings.inc
> transforms.inc
Ok.
I have noticed at least one macro that duplicates the functionality of another
macro (I suspect that the author was not aware of that) - and there might be
more such macros.
Other macros demonstrate bad programming practice and/or are made in an
intricate way so that they require a lot of effort to redo in a proper way. I'm
reluctant to spend much time on those in the beginning.
Further, there are some macros that there should be no need for (because there
are better ways to do things), and others that there will very seldom be a use
for (or as you say: they are not commonly used).
Then there are macros that could be made simpler and/or more mathematical
efficient/robust/accurate.
New features in v3.8 will make it possible to rewrite macros that do things in a
"clumsy" way (because of earlier limitations in the language) to versions that
work in a more "elegant" and educational way.
The documentation inside the files for some macros are quite imprecise and
therefore need rewriting. Perhaps most of the documentation in the include files
should be moved into a document or to a web page that we refer to inside the
include files.
Some macros are so intricate and so influenced by its creator intricate way of
thinking that I'm having problems understanding what these macros are good for.
And they may be tightly coupled to other macros that do things in non-optimal
ways. I would suggest that the rewrite and inclusion of those is postponed until
we have decided if they really are useful or need.
Some macros use dubious (or obfuscated) "tricks", that are possible in the SDL,
just to save some characters or lines of code. Those can be quite difficult for
new users to understand. I suggest that those "tricks" should be saved for
problems where there are no other good ways to solve the problem.
Then there are macros that use syntax that are legal - and useful for those that
are a bit lazy or sloppy. But often they are not very educational. E.g. "scale
2", "#if (1)" or "ambient 0.2". These should be fixed so that it is easy for new
users to understand what is really going on.
There may be so many changes to the macros in the include files that I suggest
that we make new include files with new names which we move the good and fixed
macros into. The old files can then be left as legacy include files with their
old file names. We could then write that these include files are not recommended
for new scenes made with POV-Ray versions after v3.8.
I see now that I have been a bit brutal in my description of the current state.
Sorry about that.
Ok. I can't remember if I have seen that file.
I think that I agree with you on this. (I'll have to read it again later when
I'm not tired.)
If some include files are deemed to not be 'core', they could be moved into
another git repository that are maintained "on the side". (Perhaps you just
wrote that in the section above.)
Tor Olav
http://subcube.com
Date: 11 May 2021 04:11:47
Message: <XnsAD2767B86AC7Dseed7@news.povray.org>
in news:web.6099f0f03160e21b6d7cc5a589db30a9@news.povray.org Tor Olav
> branch then. I tried to search for demo scenes that use this macro,
This is old stuff, it came from my "variate.inc" file that I can not find
anymore. Iirc there was a test scene for it in there using histogram with
the various distributions.
For testing includes, my like I did in "gradients.inc"
#if(input_file_name="your_include_file.inc")
small test scenes or cases for each inc-item, maybe even render them as an
animation
http://news.povray.org/povray.tools.general/thread/%
3CXnsA9D2EF41831AEseed7%40news.povray.org%3E/
Ingo
Date: 11 May 2021 04:23:03
Message: <609a3ee7$1@news.povray.org>
On 5/10/21 10:50 PM, Tor Olav Kristensen wrote:
Up front, I want to state clearly I don't speak for POV-Ray.
My povr branch is a personal one. Anyone can use any work from it under
the POV-Ray license terms. I consider it work donated to the POV-Ray
team and community should they have use for any part of it.
It's linux/unix only for starters, simply because I'm not a real
programmer and I don't know windows and long not used it day to day.
None handy, but it basically adds a conditional at the very bottom of
each include. There are variations but here is some stuff cut from my
current functions.inc (less the line wrapping...):
//--- Self testing:  povr +mv3.8 +i<this_file>
#if(input_file_name="functions.inc")
     #fopen FID "SelfTestFunctionsInc.txt" write
     #write (FID,"\nExpect value followed by value generated.\nF_
prefixed are pattern/math wrapped equivalents.\n")
     // f_radial
     #write (FID,"\n---\n")
     #write (FID,concat("f_radial  0.000000
",str(f_radial(+1,+0,+0),9,-1),"\n"))
",str(f_radial(+0,+1,+0),9,-1),"\n"))
     #write (FID,concat("f_radial  0.875000
",str(f_radial(+1,+0,+1),9,-1),"\n"))
     #ifdef (F_radial) #undef F_radial #end
     #declare F_radial = function { pattern { radial raw_wave } }
     #write (FID,concat("F_radial  0.000000
",str(F_radial(+1,+0,+0),9,-1)," (raw_wave)\n"))
",str(F_radial(+0,+1,+0),9,-1)," (raw_wave)\n"))
     #write (FID,concat("F_radial  0.875000
",str(F_radial(+1,+0,+1),9,-1)," (raw_wave)\n"))
     #write (FID,"\n")
     #write (FID,"\n")
     #fclose FID
     #error "\n\n===Self testing. Stop before render.===\n"
#end // End self testing
#version Functions_Inc_Temp;
#end//functions.inc
Not set in stone but, the output is in the form:
   name expect_val SDL_created_val comment
for which I created a quick and dirty scanning and report script.
I also found nothing. Not tried yours as yet.
I'm mostly OK with that, but... :-)
Again, I'm not 'POV-Ray' - so measure your efforts here knowing it's not
me that will decide whether any of your include changes become official
ones.
povr specific
The pink elephant in room is that, though configurable, by default povr
limits identifiers to a-z,0-9 and _ characters. I'm trying to make
better the argument name collision exposure of traditional SDL by making
the long recommended rules for identifiers hard parser checks.
Not 100% sure the hard identifier checking will stick, but... When
there, you can use _abc like arguments and not worry about accidental
collisions. And I'm hoping we can get away from macros such as the
Vector analysis macros with all the really long identifier names.
The blue elephant in the room is I want to make use of inbuilt code
where I have it available. I want to make more pure macros, "munctions",
and this can happen only in the povr branch around inbuilt functions
which are not completely settled.
The green elephant in the room with the distributions in rand.inc. I'd
like to move to something using the distributions shipped with c++ since
c++11, but I've not worked out how to best do it.
Many elephants. :-) I can work off anything you publish aimed at a more
generic, eventual v3.8. Perhaps that's a better direction for your work?
>> the povr branch.
> Ok.
> more such macros.
I know there are multiple interpolation macros(1) - and probably others.
(1) - One is outside the core set I think.
Agree.
> include files.
> Sorry about that.
No issues here. I agree with everything you've said - and might even say
more. :-) But, here too I need to make clear my povr branch breaks
compatibility with many old scenes. Not so much in the parser where I'm
trying to stick with v3.8's aim - except for the lower case identifiers
but with other features / inner workings.
It's an include published along with DF3 documentation on put up on the
wiki now quite a few years ago. Consider it povr specific though it was
originally written to work with v3.7 or v3.8.
Yes, that's exactly the idea. :-)
Bill P.
Date: 11 May 2021 04:35:30
Message: <XnsAD276BBE9FC07seed7@news.povray.org>
> in the povr branch.
> arrays.inc
If you see "core" as being "SDL extensions", to be maintained alongside
POV-Ray itself, yes.
The texture and object creation includes are a just as vital part of a
distribution imo. They could indeed be maintained in a different than the
main repository. The same for the insert menu (win only?) and demo scene
files.
Ingo
Date: 11 May 2021 06:05:00
Message: <web.609a569a3160e21b1f9dae3025979125@news.povray.org>
> main repository.
Yes - these are really important for new users as well as acting as a sort of
inbuilt idea-pad and historical record.
qtpovray38 has the insert menu, and since it just uses the GUI to plop the
entire contents of a small file into a scene, those files could in theory be
used as includes, were they written to work that way.
> and demo scene files.
Yes, this is a sort of alternate documentation that is extremely important in
understanding the actual syntax and real-world implementation of various
features.
