POV-Ray : Newsgroups : povray.general : chr(0) problem Server Time
23 Oct 2026 06:39:11 EDT (-0400)
  chr(0) problem (Message 1 to 24 of 24)
Subject: chr(0) problem
Date: 28 Feb 2002 05:35:57
Message: <5m0s7usm1t32sajav9eou78e4tbfr9f21v@4ax.com>
any idea how to add to string or write into file chr(0) ?
it is the only limit to write binary files :-(
(treat it as feature request if it is not possible)
ABX
Subject: Re: chr(0) problem
Date: 28 Feb 2002 06:10:04
Message: <3C7E1031.F8CEFDE9@namtar.qub.ac.uk>
> ABX
"\0" writes the null character.
signature{
Date: 28 Feb 2002 06:14:07
Message: <3c7e10ff@news.povray.org>
In article <5m0s7usm1t32sajav9eou78e4tbfr9f21v@4ax.com> , W„odzimierz ABX
As you might know, you are not supposed to be able to write binary files...
    Thorsten
e-mail: tho### [at] trfde
Date: 28 Feb 2002 06:27:04
Message: <0n4s7ug2ce25efi7tli2vv7vdpt345ac0g@4ax.com>
On Thu, 28 Feb 2002 12:14:05 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Yes, I suppose there wasn't such idea in design of POV. Anyway I wan't try to
write DF3 file and use it within the same parse. It's just the 3d version of
image function and I found it useful in my current task.
ABX
Date: 28 Feb 2002 06:44:45
Message: <0u5s7uoktp549usmnn8sn3q1rtugp730e2@4ax.com>
On Thu, 28 Feb 2002 11:10:41 +0000, Grey Knight <s16### [at] namtarqubacuk>
#write(DF3,"\0" <----ERROR
Parse Error: Illegal escape sequence in string.
ABX
Date: 28 Feb 2002 07:03:23
Message: <3C7E1C7D.C4F9EC96@namtar.qub.ac.uk>
Oh dear. What exactly was \0 put in for if you can't write it to a file?
It's not like it makes any sense to put it in a text string...
> ABX
signature{
Date: 28 Feb 2002 07:14:18
Message: <9h7s7uovnvah261sdpgrhgoar29fd73o4m@4ax.com>
On Thu, 28 Feb 2002 12:03:09 +0000, Grey Knight <s16### [at] namtarqubacuk>
From documentation: "Depending on what platform you are using, they may not be
fully supported for console output. However they will appear in any text file
if you re-direct a stream to a file."
When I tried it with #warning it produced the same error message.
So, does it means bug ? Should I repost it into beta-test ?
ABX
Date: 28 Feb 2002 07:28:43
Message: <3c7e227b@news.povray.org>
In article <9h7s7uovnvah261sdpgrhgoar29fd73o4m@4ax.com> , W„odzimierz ABX
Well, whatever the documentation wants to say with this, a "\0" is converted
to a backslash in at least 3.1 and 3.5.  It is obvious that "\0" cannot be
supported because C strings use it as terminator, so it should probably be
removed from the documentation altogether.
BTW, note that the quote you provided only talks about output streams, not the
file #write directive!
    Thorsten
Date: 28 Feb 2002 07:36:32
Message: <8r8s7u07h0qd6lipk3pfd4ltae7i3pgoai@4ax.com>
On Thu, 28 Feb 2002 13:28:42 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Worse luck!
Yes, I noticed. But of course I tested it with #warning before quoting.
The solution I choosed is to limit range to 1-255. I hope it will be
sufficient.
ABX
Date: 28 Feb 2002 08:57:06
Message: <3c7e3732@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c7e10ff@news.povray.org...
files...
By the way, why there is such a limitation? It should be useful.
Gleb
Date: 28 Feb 2002 09:06:12
Message: <ctds7u8u46hhf0crd5uaond5jsb9so71l9@4ax.com>
You know, POV-Ray is a raytracer not... everything.
It is supposed to take script as input with SDL and produce image as output.
Writing binary files with SDL is like writing viruses with it - erhaps
possible but more efficient with external, specialized tool.
For example in my case I can export all values as text and produce proper df3
file with external tool written in any free compiler. The problem is my
laziness :-)
ABX
Date: 28 Feb 2002 10:18:27
Message: <3C7E4A40.365ADF05@gmx.de>
> files...
Portability is the main concern.  As soon as writing binaries includes
more than just writing single bytes the behaviour will be strongly
platform dependant.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 28 Feb 2002 10:35:30
Message: <3c7e4e42$1@news.povray.org>
"W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:ctds7u8u46hhf0crd5uaond5jsb9so71l9@4ax.com...
output.
Well, I agree, maybe it was before, but now it is almost... everything.
Now it takes not only a script as input, but also some binary files
(images, dencity) and possibility to interact with them (trace).
Moreover, POV SDL has almost unlimited abilities for creation such a files
with unique effects.
The danger of viruses is not a point at all, you know, there are pure
text-looking ones.
From the other point, for example, possibility of reading
binary data into array and loading a "binary image" of
once parsed huge complex object would save a lot of time and/or space.
df3
> laziness :-)
I do appreciate this, but again, to create some files one need POV or
similar
engine. By the way, a binary file produced with your recent beta-test code
looks very interesting when interpreting as an image.
I like POV as it is, but imho tendency of the development itself
will take it's own anyway.
Gleb
Date: 28 Feb 2002 10:41:22
Message: <3c7e4fa2$1@news.povray.org>
news:3C7E4A40.365ADF05@gmx.de...
> platform dependant.
Do you really mean that storage device drivers are more complex in access
than display ones?
Gleb
Date: 28 Feb 2002 10:46:34
Message: <3C7E50DA.A9B7F6F4@gmx.de>
> than display ones?
This does not have anything to do with device drivers.
Date: 28 Feb 2002 10:52:23
Message: <3c7e5236@news.povray.org>
> platform dependant.
  But writing bytes is all one needs.
Date: 28 Feb 2002 11:09:54
Message: <3c7e5652@news.povray.org>
news:3C7E50DA.A9B7F6F4@gmx.de...
access
> > than display ones?
Same question: :is graphic portability more complex thing? Sorry, if the
question looks stupid and/or has well-known
answer. I just want to get the real reason.
Date: 28 Feb 2002 11:20:05
Message: <3C7E58B5.F6B0933C@gmx.de>
There is no graphics output in Povray, only some versions call API
functions of the OS to display the render in the platform specific code.
This has nothing to do with the rendering program itself.
Date: 28 Feb 2002 11:43:42
Message: <3c7e5e3e$1@news.povray.org>
news:3C7E58B5.F6B0933C@gmx.de...
This is exactly what I mean: there is no graphics in Povray, but there is
somehow binary images output
 and and input, isn't it?
Date: 28 Feb 2002 11:52:36
Message: <3C7E6052.BB0F78AB@gmx.de>
Yes, but this is platform independant due to precautions in the image file
format definitions.  Simply writing your floats and vectors to a file as
binary with some IO functions would be different.
Date: 28 Feb 2002 11:58:07
Message: <chrishuff-09342C.11580228022002@netplex.aussie.org>
> the question looks stupid and/or has well-known answer. I just want
Graphics are completely platform dependant...the only standard interface
is for unstyled text. There is no standard way of drawing a pixel on the
screen, these facilities are provided by the operating system.
There *are* standard interfaces for writing binary files, but there is
no guarantee that a binary file will be readable on platforms other than
the one it was created on. The only way to guarantee that is to write
things byte by byte, so the exact order and format of the data is known.
The POV language isn't really capable of handling this right now...it'd
probably require reworking the file I/O syntax, and because of the
simplifications required by the POV language, it probably wouldn't be
useful for interacting with other programs.
Date: 28 Feb 2002 12:03:12
Message: <3c7e62d0$1@news.povray.org>
news:3C7E6052.BB0F78AB@gmx.de...
code.
is
OK, thank you, the reason is much clear now. Format of floats is really
platform dependent,
but byte strings i/o would be enough in this case, and it is almost there
already.
Date: 28 Feb 2002 12:08:28
Message: <3c7e640c@news.povray.org>
<snip>
Am I right that this issue is about limiting the portability of scripts, rather
than the pov-application?
Date: 28 Feb 2002 12:10:28
Message: <3c7e6484$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c7e640c@news.povray.org...
rather
or, more accurately, the portability of the binary output of scripts...
