POV-Ray : Newsgroups : povray.general : Pass array to macro. Server Time
23 Sep 2025 09:40:06 EDT (-0400)
  Pass array to macro. (Message 1 to 5 of 5)
Subject: Pass array to macro.
Date: 12 Apr 2020 05:12:36
Message: <5e92db84$1@news.povray.org>
Hello,
With this code :
#declare ListOfLines = array[nbLines][2];
#macro drawLine(thisLine,lRadius,lColor)
   cylinder {
     thisLine[0], thisLine[1], lRadius
     pigment { color lColor }
     finish { specular 1 brilliance 2 }
#declare lineIndex=0;
#while(lineIndex<nbLines)
   drawLine(ListOfLines[lineIndex],0.05, GreenYellow) <<< error here !
   #declare lineIndex= lineIndex+1;
The array "ListOfLines" contains start and end points of lines.
ListOfLines[i][0]=<x1,y1,z1>;
ListOfLines[i][2]=<x2,y2,z2>;
and so on
Running this code raise en error :
   Parse Error: Expected '[', ,  found instead
for the line highlighted above
The macro drawLine can't understand that "thisLine" parameter is an
array of two elements.
So it seems that i can't pass an array as a parameter to a macro ?
Is my prognosis correct and is there any solution (other than split
array's item into two variables).
Thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Pass array to macro.
Date: 12 Apr 2020 06:15:01
Message: <web.5e92e8fa9cacd3d7827e2b3e0@news.povray.org>
hi,
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello,
> With this code :
"Although it is permissible to reference an entire array as a whole, you may not
reference just one dimension of a multi-dimensional array."
<http://wiki.povray.org/content/Reference:Array>
you could declare an array of arrays, ie
#declare ListOfLines = array [N] {
  array [2] {point, point},
regards, jr.
Date: 12 Apr 2020 08:15:00
Message: <web.5e9306259cacd3d7fb0b41570@news.povray.org>
Correct and expected behaviour.
It does, which is the problem.  It understands that thisLine is an array of the
dimensions that you specified, and you're supplying too few inices for it to
locate the element[s] that you want.
You totally can, I do it all the time.
Hard to understand exactly what you mean, but:
All you do is pass the FULL array into the macro and then define the way you
address the parts of the array that you want to access.
If you only want to access the second dimension, then just hold the first one
constant, but you do have to put that into your ArrayName [index1][index2]
designation.
This I think would also be a way to avoid the error, and might be better, as you
can then have a parent array that is composed of sub-arrays of _different data
types_.    :)
Date: 14 Apr 2020 06:04:28
Message: <5e958aac$1@news.povray.org>
My ListOfLines = array[nbLines][2] is just and array of N lines and for
each line, the start point "array[i][0]" and the end point "array[i][1]".
In my mind, passing array[i], allowed me to pass the two parameters
present in the second dimension.
> designation.
"array of arrays" is not the same as array[][] ?
> types_.:)
For now, the simplest way is to pass two parameters to my macro.
drawLine(ListOfLines[lineIndex][0],ListOfLines[lineIndex][1],0.05,
GreenYellow)
with :
#macro drawLine(thisLineStart, thisLineEnd, lRadius, lColor)
No more complications. Thankss
Kurtz le pirate
Date: 14 Apr 2020 06:40:01
Message: <web.5e95927a9cacd3d7fb0b41570@news.povray.org>
That's a common misconception - which is why "you can't do that" is in the docs.
 There's only so much code "under the hood", and the code that might allow you
to reliably do that - isn't.
It "is", but the point is about content, not form.
Array [][] is just a generic 2D array.
But when you fill the array with data, then it becomes an array of scalars, or
vectors, or ... arrays.
> GreenYellow)
> with :
Correct - OR you could just hard-code the constant parameter in "drawline" if it
doesn't need to be variable.
Glad you got it working.   :)
